Compass Helicopters Rage RC Hellicopter Discussion |
06-25-2010, 12:41 PM | #21 (permalink) |
I'm still at stock on the timing and it's insane. I think once I get used to it then I will change the timing to 22.5 but at the moment I can't imagine this being any more powerful.
It can catch you out quick enough now!!
The difference between knowing your s**t and knowing you're s**t! Optipower - Kontronik Drives
06-28-2010, 06:01 PM | #22 (permalink) |
Only downside to doing timing for full power is it gets your motor really hot (or at least in my case it does). I temp'd it out after a flight and it was at like 145f, but that was after a short delay. I plan on bringing the gun with me next time so I can have a better reading as soon as I land. Also, as I wait for my packs to get broken in, I hope to get more power out of them. As of now, I have one Hyperion 35C 2600 and it doesn't feel any better than my two 3S, 2200 Turnigy 30C's, so I'm a little disappointed to say the least. I do wish I'd gotten the 2950's but only found out about that size after I'd already gotten the 2600.
Tim KBDD TEAM PILOT --Si vis pacem, para bellum-- |
06-28-2010, 07:19 PM | #23 (permalink) | |
Atom 500 VBar (Takes a licking), MCPx 2s (Flying ), Atom 7HV-Bar (Flying LARGE!!) |
06-28-2010, 07:43 PM | #24 (permalink) |
Is that with stock ESC or Castle?
06-28-2010, 08:10 PM | #25 (permalink) |
Stock 60amp Platinum Hobbywing.
06-28-2010, 08:20 PM | #26 (permalink) |
I'm surprised you get such a long flight on 10T.
06-28-2010, 08:28 PM | #27 (permalink) |
Well I'm not a 3D flyer more of a hard sport flyer with some weak attempts at 3D. I normally put 2400 to 2700 back into the packs and if I go over 5min. it's higher but I try to stay around 80% discharge. I did have some Hyperian's 25C 26?? Amh packs but when I went to 10 tooth they puffed.
06-28-2010, 09:11 PM | #28 (permalink) |
Maybe it's just the nasty heat where I live then? I haven't had much of a chance to really get out and fly the Atom because I've had nothing but problems with my electronics since last year. I finally tracked most of it down to a faulty motor of all things! (who'da thunk it, right???). Anyways, I'm going to try and have a sit-down with Bob at the Miramar event and see if I can't get the last bits of it hammered out. If I get it ripping again, the Pro goes on the chopping block to make room for the upcoming 6HV! (just have to sneak it past the wifey )
06-29-2010, 02:24 AM | #29 (permalink) |
Its 110F out.. I fly for 3:30-4:00 min with the stock motor, stock esc on 22.2 timing, 11T pinion, 100% throttle curve and 45C packs.. Motor is about 200+F after a flight
AmainHobbies - Protek RC |
06-29-2010, 07:46 AM | #30 (permalink) |
I bet it is hotter inside the motor than 200 F during the last seconds of flight. Mine was measured 190 F thru a vent at the top, but it had a minute to cool down, so I'd say it was over 200 F at some point. I only use the 10T pinion and ambient was 85* F.
What a great hobby...even better, its people! Be blessed, friends. |
07-03-2010, 02:20 AM | #31 (permalink) |
My 6HV gets hot, but my Atom 500 doesn't see that kind of heat. Maybe when I stretch it?
07-03-2010, 10:24 AM | #32 (permalink) |
My Atom stays cool (approximately ambient temperature).
The motor in my 6HV runs a bit warmer, but definitely not hot (I have not measured the temperature). My timing is still at 12.5 degrees, at the moment (not sure what I would do with even more power).
KBDD-Team Captain, JR DFA Team Pilot. Forza 450, Forza 600N, Forza 700, Compass 6HV-U, Warp, 7HV,Knight Pro,Knight 3D, Atom, Odin II, 6HV, 3D Plus, Knight 50, Chronos, Velos, Steam 550 and 600, OMP M2 (and anything else I can get my hands on...). |
07-03-2010, 08:20 PM | #33 (permalink) |
200f sounds waaaay too high to me. Not as in I don't believe you, but no es bueno on the motor man! My Atom was temping at 135 a couple minutes after the flight (was too slow on grabbing the gun again doggone it!). I lowered my timing down to the stock setting of 15 degrees, but that only seemed to bring it down a little bit. I also got a lot more flight time, so that seemed pretty promising. I still have to tweak things out on it, but 160 is the highest you should probably let your motor get.
07-04-2010, 04:37 AM | #34 (permalink) |
280 is critical.. I wouldn't let it get over 290F
07-06-2010, 09:30 AM | #35 (permalink) |
Ahh hell I thought mine was running warm but it's 155F (inside the motor) right after a 6 minute flight on a 75F day.
It still looks to me like the motor could use a cooling fan arrangement on the bell. |
07-06-2010, 11:43 AM | #37 (permalink) |
That's at 2000 headspeed, 10 tooth pinion, gov mode on the ICE HV. Timing is medium, I believe.
I tried 8khz and outrunner mode for the pwm settings, both seemed the same in flight and temps were the same. 16khz didnt work out well... |
07-07-2010, 12:57 AM | #38 (permalink) |
I'm thinking of trying 15 degree timing as some are having success there and gaining flight time. If I can squeeze 6 minute flights out of my 6HV with decent power, I'll be one happy man. Right now the beep @ 4.30 is just bumming me out, although I could do 5.5 minutes, no problem as I'm only putting back 1500mAh.
07-07-2010, 07:59 AM | #39 (permalink) |
I am using the hyperion 2950's, so my batteries are about 45 seconds bigger than most. 6 minutes and I have to put 2100 - 2200 back into the packs; I did 6:30 once and I put 2500 back in, a little too much. All this at 2000 rpm.
