Like Tree3Likes
Old 06-29-2014, 11:11 PM   #521 (permalink)
Can you get just the bearings? From MS Heli you have to get the whole tail hub setup
jmtyndall is offline        Reply With Quote Quick reply to this message
Old 06-29-2014, 11:20 PM   #522 (permalink)
I use these in the tail grips http://www.gobrushless.com/shop/inde...how&ref=B-3625
Dylan ~ www.AstroidDesigns.com
Old 06-29-2014, 11:49 PM   #523 (permalink)
I guess I can look up the bearing sizes in the manual and shop. The blade grips are fine but the bearings arent smooth, so im going to throw a full set of bearings at it, and not replace the plastic parts
Boca carries everything but the thrust bearings for the main blade grips. Even HD is out of the stock set of those.
Old 07-03-2014, 05:51 PM   #524 (permalink)
Default Re: Share your Mini Protos Pictures and Videos!
Starting my build finally. Can't get much further without my new bearings and main shaft. So I'll be going into a holding pattern
ID:	519768Click image for larger version
Old 07-11-2014, 01:22 PM   #525 (permalink)
The Lynx tail is awesome! I am hoping it will go for hundreds of flights!
[ame]http://youtu.be/vVi7mFPwo8Y[/ame]
Fly... crash... rebuild... repeat... Fly hard my friends! Team Lynx Mini Protos
Trexwilly is offline        Reply With Quote Quick reply to this message
Old 07-11-2014, 03:12 PM   #526 (permalink)
Awesome! Smacked a few weeds with it around 2:50.
Chris Boultinghouse
Old 07-11-2014, 03:30 PM   #527 (permalink)
Yeah I finally got her locked in sweet, now I just need a pinion to handle the power!
Old 07-11-2014, 03:53 PM   #528 (permalink)
Don't we all.
Chris Boultinghouse
Old 07-11-2014, 03:56 PM   #529 (permalink)
I am working a deal with a fellow freak to rewind a motor for me to try and get 1100KV I am hoping using the bigger 16-18T pinions will help?
I am going to get a Warp 16T and try that if the rewind larger stock pinion doesn't work...
I wish I was more knowledgeable on motors workings, I would have built my own with the scorpion kits by now!
Old 07-20-2014, 07:03 PM   #530 (permalink)
Well after another 30 flights nursing the mini along, limiting collective, and keeping power down, I said enough and made the front side of the belt over tight, yup you geussed it, now the belt will hold, but the OWB slips
But I was able to push a little harder on it.
[ame]http://youtu.be/zgiLsJ_OVWI[/ame]
Old 07-23-2014, 12:44 AM   #531 (permalink)
some fun with the last battery before grill party on sunday.
my holdfinger is a bit too fast i didn't have to think i just listened the instructions from the crowd "there is still some roots left" "auto all the way down!"...
rotos ojailee (5 min 0 sec)
miniProtos, Protos380, Goblin SPEED red carbon, G380KSE, G_Black_Nitro, V-BAR, MKS, Kosmik, YGE, BK, X-Nova XTS
Tohtori R is offline        Reply With Quote Quick reply to this message
Old 07-23-2014, 07:26 AM   #532 (permalink)
Default Share your Mini Protos Pictures and Videos!
Mini Abuse! And I love it! Exactly what 450s are for: fun!
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis
Thanks to Oxy Heli and MSH-Direct.com
Former Username: Code3Medic
Russell Harding is offline        Reply With Quote Quick reply to this message
Old 08-17-2014, 01:22 PM   #533 (permalink)
Nothing impressive:
Mini Protos Flight #0003 (4 min 20 sec)
Mini Protos Flight #0004 (4 min 16 sec)
Old 09-06-2014, 06:28 PM   #534 (permalink)
Did a quick flight this morning. Using warp 360 16 tooth pinion, stock 6S motor, 3300 rpm governed with Ikon.
Mini Protos 9.6.14 (4 min 33 sec)
jimsdpugs is offline        Reply With Quote Quick reply to this message
Old 09-08-2014, 03:35 AM   #535 (permalink)
some night fly from last weekend. nightflying equipments are for pussies
i have my headlamp
only problem was that the air was cold and humid so when i exhale there was lots of water wapor in front of my face in the lightbeam needed to hold my breath
My miniP @ night with headlamp. only. (4 min 16 sec)
Old 10-19-2014, 11:48 PM   #536 (permalink)
Wow. Just on this page there are some sweet flights! First post to the video section for Mini Protos. Been flying about a year. Love my Mini and Protos 500!
This vid from today shortly after finishing stretching my Mini. She also got a much needed tail servo upgrade. And the Align 410Ms on the cyclic are due soon too....probably before I even take her 6S. Yep that's right...this bird is still 3S AND now on stretch. Def slows the bird down, but I am really digging the slower flight envelope for the small park/field flights. Also will likely help me dividends in developing my skills having a bit more time to think HAHA!! At first, the stretch was not impressive to me with the 3S, but after dialing it in with the new tail it is quite enjoyable. Def requires better collective management so not a bad thing to work on, but hey...she actually does some pretty decent tic-tocs even on 3S still (check out 1:10...I'm not anywhere near best with them, but I'm getting better)
https://www.youtube.com/watch?v=MreepfVXv_E
adambowersva is offline        Reply With Quote Quick reply to this message
Old 01-10-2015, 07:06 AM   #537 (permalink)
Rescued a Mini, In the process of rebuilding/updating.
Still need a few parts, but things are moving along nicely.
ID:	561762   Click image for larger version
ID:	561764   Click image for larger version
MSH-Direct is offline        Reply With Quote Quick reply to this message
Old 01-10-2015, 09:05 AM   #538 (permalink)
Nice color scheme!
Chris Boultinghouse
Old 01-19-2015, 03:35 PM   #539 (permalink)
Put a couple of flights on my mini yesterday testing out the Lynx dfc head. Very crisp, and I think I may need to come down a smidge on head gain because of how rigid it is now.
Either way, first flight on 3s went well, even though I got stupid with it and needed all 14 degrees of pitch to keep it out of the dirt.
" frameborder="0" allowfullscreen>
Second flight in 6s. Going well until I dialed the headspeed way up and the belt let go. Despite the heli being on its side at the end of the video it actually hit flat on the skids. Tail fin had dug into the mud about an inch, and the nose/esc hit the dirt. The only damage is 1) belt, 2) a few cracks in my pretty new canopy 3) capacitor on the esc is LOOSE. So I'll either fix or replace it.
Old 01-19-2015, 09:51 PM   #540 (permalink)
Cool, did you just get the DFC version, or do you have the standard style AL version too?
