Like Tree8Likes
Old 04-02-2009, 09:11 PM   #101 (permalink)
Here's my Protos with the blue Canomod canopy. As someone on Helifreak suggested, I moved the mounting posts forward and I did not need to do any trimming on the canopy.
ID:	89562   Click image for larger version
ID:	89563   Click image for larger version
ID:	89564   Click image for larger version
ID:	89565   Click image for larger version
Glimmung23 is offline        Reply With Quote Quick reply to this message
Old 04-03-2009, 09:06 AM   #102 (permalink)
I moved the mounting posts to the front and I could mount my Canomod without trimming as well. I also put some spacers under the front skids to allow the canopy to slip under the frame. I don't like how close to the edge the grommets are so I think I'm going to do a little trmming so I can move the grommets farther up.
Gscott is online now        Reply With Quote Quick reply to this message
Old 04-03-2009, 12:15 PM   #103 (permalink)
Sweet looking Protos you've got there Glimmung23. The Canomod canopy is beautiful.
I put the "__" in lazy
Jetleaf is offline        Reply With Quote Quick reply to this message
Old 04-03-2009, 06:38 PM   #104 (permalink)
Thanks! I wish I had pics of it flying because the canopy looks really great in the air.
Old 04-04-2009, 02:56 AM   #105 (permalink)
Beautiful! Had a look on this canopy before as well! I'm not sooo much with the blue - would like the design with red instead of blue even more.
But your Heli looks great!
With V-Stabi 4.0: THREE DEE RIGID
With MicroBEAST: T-REX 550
, PRÔTOS 500, T-REX 450 Pro
Chorge is offline        Reply With Quote Quick reply to this message
Old 04-04-2009, 04:55 AM   #106 (permalink)
Finally some pic's of my Prôtos during a meeting yesterday thank you Z !
My Canomod and my fluor plastic self painted canopy,platic may not look good from close up but in the air you can see it very good
ID:	89742   Click image for larger version
ID:	89743   Click image for larger version
ID:	89744   Click image for larger version
De GooF is offline        Reply With Quote Quick reply to this message
Old 04-04-2009, 05:38 AM   #107 (permalink)
I like your flouro paint job DeGoof, nice work.
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is offline        Reply With Quote Quick reply to this message
Old 04-04-2009, 09:03 PM   #108 (permalink)
de goof, the maniacs look nice in the sky indeed!
Old 04-06-2009, 10:20 AM   #109 (permalink)
Here are a couple pics of my Protos'.
The original Protos (SAB Blades) is near 100% stock. I did add the Aluminum Pitch Plate, Aluminum FlyBar Carrier from Infinity Hobbies to it. I also added a Support Bridge to the boom supports. It is fitted with Stock Motor, Align 60 amp ESC, JR 3517 MG on swash, JR 770 Gyro with the JR 3500G tail servo.
The other Protos (RotoTech Blades) is a CF Frame and boom from Infinity Hobbies. It also has the Metal Grips (main and tail), mixer arms, pitch plate, washout hub, hard dampeners all from Infinity Hobbies. I also picked up all metal pullies from Duzi Models. It is fitted with Stock Motor, Align 60 amp ESC, JR 3517 MG on swash, Spartan 760 Gyro with the Futaba S9257 tail servo.
They both fly awesome but I really like the Carbon one better. Both are flown with FilghtPower EVO 6S 2500. Both have the static mod from the motor mount to the boom and static guard is applied to the belt.
ID:	90261   Click image for larger version
Sold them all...... No longer flying.......
AMA - 839073 / IRCHA Member - 3735
heli is offline        Reply With Quote Quick reply to this message
Old 04-09-2009, 09:38 AM   #110 (permalink)
Here are some shots of my quick-n-rough paint job done today on a (slightly damaged) white plastic canopy. I would love to get some MSH and Protos stickers, are they available ?
My design goal was "improved visibility" and my solution included fluorescent yellow and orange on the canopy and tail fins. As an experiment I used some cheap rattle-can fluoro marker paint. It is not sticking too well to the tail fins (migh thave to find some of the infamous auto bumper undercoat perhaps) but seems to have bonded to the (sanded) plastic canopy OK. I hope to fly it tomorrow to see whether the design goal has been met.
ID:	90782   Click image for larger version
ID:	90783   Click image for larger version
Kenneth
Old 04-09-2009, 12:16 PM   #111 (permalink)
You also got a nice fluor canopy !
Old 04-09-2009, 10:59 PM   #112 (permalink)
Thank you
It works well, not nearly as stylish but much better against grey skies than the original canopy. The cheap spray paint is flaking off the tail fins which doesn't suprise me. So far after half a dozen flights (canopy on-off each time) it seems to be holding OK on the canopy which is more important.
Kenneth
Old 04-10-2009, 09:14 AM   #113 (permalink)
Getting paint to stick to plastic is always hit or miss. The bumper stuff is called Bulldog Adhesion Promotor. If you try it make sure you give it a few days to dry or you will end up with a big mess.
Old 04-10-2009, 11:10 AM   #114 (permalink)
OK, thanks for the tip.
Kenneth
Old 04-10-2009, 05:49 PM   #115 (permalink)
Default New Paint!
Here is my Protos, Scott at Ace Helis painted the Canopy and I painted the skids. The canopy shows up great in the air! I really like it now, before I could not see the stock canopy well at all unless it was inverted!
Thanks Scott for the great paintjob!
ID:	91007   Click image for larger version
ID:	91008   Click image for larger version
ID:	91009   Click image for larger version
xlpro is offline        Reply With Quote Quick reply to this message
Old 04-10-2009, 08:37 PM   #116 (permalink)
Very nice! What kind of paint did you use on the skids?
Hey, wait just a darn minute... I recognize the rest of that Protos. You had it at Austin, it's the crazy insane one!
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 04-10-2009, 11:44 PM   #117 (permalink)
Default Skids
yea that's the one! Fun Fun! I just used Krylon out of a spray can and the Automotive clear on top of the white. It was pretty easy and really helps with orientation.
Old 04-13-2009, 04:34 PM   #118 (permalink)
Is that your amazon.com bill for all your heli expenses in that first pic?
srhadden is offline        Reply With Quote Quick reply to this message
Old 04-13-2009, 10:55 PM   #119 (permalink)
What if the wife sees it!?
Align T-Rex 450SE V2 (AR6100 / 3 x HS-65MG / S9650 / GY401) | MSH Protos (AR6200 / 3 x S9650 / S9257 / DS760)
Blade mSR BnF | Blade mCPX BnF
RC Helicopter Wiki
kitsched is offline        Reply With Quote Quick reply to this message
Old 04-14-2009, 03:44 PM   #120 (permalink)
Here is mine, USB powered
Wesp
wespen is offline        Reply With Quote Quick reply to this message
