Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
02-11-2009, 08:55 AM | #61 (permalink) |
The way I avoid hot starts is to always start in throttle hold. The only way I get bitten that way is if I've forgotten to restore the throttle trim after the previous flight, in which case the engine simply dies when switching out of TH.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Protos Max Evo 700 (Brain 2), Protos Max V2 770 (iKON 2), Synergy 516 (Brain 2), Oxy 2 (Falcon 12) Graupner MZ-32 Experience is something you gain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
02-11-2009, 11:28 AM | #62 (permalink) | |
Yes this is the kind of tip... But I'm also looking for a procedure that I can burn into my head in case of mechanical/electrical failure..... A hot start is happening. I...... 1) Scream like a girl.......then 2) Hold on to the head.....then 3) pinch off the muffler.....then 4) pull off the fuel line....then 5) run home for a change of shorts...... Am I close? |
02-11-2009, 09:49 PM | #63 (permalink) |
C R, dont try to fool around with the muffler, go direct to the fuel line, it is the fastest... and always hold the head when you start... always... Have you ever seen a mule kick? A out of control hotstart is as bad. I once started my 30 size, the engine ran bad and died, raised the throttle a little thinking it was too cold and when I started it, it went crazy. I was half holding it and the blades tuned several times before I could grabe them and by then the tail came and smack me on the harm... tail rotor in first. Hold the head and position your body to block it if possible.
And, when you say to your self " Hey buddy, that engine is a little cold today, give it a little gas..." remind your self that: a little mean a little and take off that fuel line pincher... mule do kick hard and jack ass still feeling the pain... |
02-12-2009, 04:22 AM | #64 (permalink) | |
But: 1) Hold on to the rotor head anytime the starter is spinning the engine. 2) Setup and USE Throttle Hold. 3) Double check throttle IDLE. 4) Hold TIGHT to the rotor head. 5) Place Tx within easy reach. 6) Go for Tx or Fuel Line. I find if the Tx is placed right, I can easily move the throttle to idle if I hot start. And yes, I did hot start my Vibe first time at the field. After starting properly twice at home.
Terry AMA#47402, IRCHA # 3395 Blade CP "Pro", Trex 450SE, PiccoZ, Quick of Japan EP8v2 EX, Hurricane 550, Hurricane 200, JR Vibe 50, Blade mCX, Bergen Intrepid Gasser, Pantera 50, Blade mSR, Novus CP |
02-12-2009, 12:32 PM | #65 (permalink) | |
Just a guy and his heli.... |
02-12-2009, 01:10 PM | #66 (permalink) | |
Trex600N & Trex450SE. Dang! Another Radio Glitch! |
02-13-2009, 12:17 PM | #67 (permalink) |
GOOD point. Move the stick and see if the servos work FIRST.
02-13-2009, 11:33 PM | #69 (permalink) |
Only if you do it wrong.
02-17-2009, 10:07 AM | #70 (permalink) |
Pine great vids man...The one on dial indicating is just what I needed. My Vibe went together perfect without needing any dial indicating but I did buy the indicator just in case and now I know how to use it properly lol
02-21-2009, 01:50 AM | #71 (permalink) |
Hi Pine and all,
Not too sure if I'm suppose to post my question here. If it's not, my apologies and please forward me to the right one . I've been looking at mixes prog on the tx with confusion, tried it on sims but doesn't seem to work. What I was trying to do is to programe mixes on my tx to get a constant head speed on all moves without using governor. Is it possible? I'm using a DX7 and a JR9PCMXII. thanks in advance |
02-21-2009, 02:36 AM | #72 (permalink) | |
02-21-2009, 07:23 AM | #73 (permalink) |
Thx Pine, by adjusting throttle curve with a tach won't compensate the aileron on rolls also it will be too hard to try to compensate both aileron and elevator or even rudder. I was reading thru the JR9 manual and find it very interesting, futher searching thru the nett I found this, http://www.raptortechnique.com/throttlemix.htm#3
Its easier to have a govt but this kind of interest me. It's actually on throttle mix on JR9 radio where else DX7 have only prog mix and not throttle mix. I haven't tried it on real yet but on sims it doesn't work. |
02-21-2009, 11:06 PM | #74 (permalink) |
The 9303 has built in Aileron -> Throttle and Elevator -> Throttle mixes. You just have to set the mix amount, and again, that requires taching.
So on a DX7 you do the same thing, set a Aileron -> Throttle and Elevator -> Throttle mix. You should also do a Rudder -> Throttle mix, that increases the throttle when you move the tail against the torque and reduces the throttle when you rotate with the torque. Or even easier, get a Gov.
02-22-2009, 02:24 PM | #75 (permalink) |
I've noticed the guys at the field will start without hold and if the idle is a little high, they'll trim the throttle down a couple clicks, and if its low, they'll trim up... quick and easy. However, on my DX7, there is no throttle trim in hold. So if I start it in hold I don't have the option of quick trim adjustments. If the idle is too high or too low, I have to either take it out of hold and adjust the trim a couple clicks, or go into the Hold position menu and modify it. This is kind of a pain and I notice that most at my field don't bother with Hold so they are free to tweak the trim when necessary.
How should this be dealt with? Do I need to to be messing with the idle needle every time it seems a little off, or trim it out of hold then go into the hold menu to adjust every time so I can actually put it back in hold? I've been doing the latter... Which really only needs doing the first flight of the day then it seems ok after that, but then the next week if temps are different, or if I haven't flown it for a couple weeks it needs trimming again. What I'd really like is some way of trimming the throttle while in hold, without going into a setu menu... any way of doing that? -David Haven't watched the vids yet, but will when I get a chance
Trex500 sk360 | Logo400 vbar | Logo500 vbar | logo 600se vbar | Synergy N9 sk360 | E-Aurora vbar | Mini Protos beastX | mcpX |
02-22-2009, 09:48 PM | #76 (permalink) |
Not 2 sure. As I'm new I use the hold to kill the engine, lol. I'll set it up once I'm ready for autorotation. In the mean time, engine failure in mid air not an option plz, lol.
By the way, what is the ideal headspeed for normal and idle 1 & 2? Also how do one take a rotor headspeed when a heli is flying around rather hovering? |
02-23-2009, 08:32 AM | #77 (permalink) |
If you don't use hold, make VERY sure that your throttle is low and you are in Normal. Otherwise you will get to learn about hot starts.
I normally start in Hold, and if needed, pop it out and adjust the trim. I do wish that JR/Spektrum allowed trim in Hold.
02-23-2009, 09:15 AM | #78 (permalink) |
I just go into the TH menu and change the percentage while the heli is idling. I have to do it so seldomly that I don't mind.
03-04-2009, 11:03 AM | #79 (permalink) |
Would like to know..
Hey Bob!
has anyone or you for that matter made a review on the older Hawk30 size, mine has an OSX eng. JR 700 receiver, just added the HH gyro from my ol HBK2, hoping I can add a matching crystal to the receiver and use the el cheapo TX from the HBK2 which is has you know 6 channel. hope I find out about the hookup on the gyro, I just read,read read, would like to find info on the History of the Hawk! have yet to find stuff like that online with pic's, I also hv a sweet fiberglass Augusta 109 fuse minus fin's don't know who made it, maybe the pic's here would help identify. I would like to add more detail, but past experience with the HBK has taught me to be careful! Bigrick Proud to have served "Bigred" the One and only ONE! |
