Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > JS TZ-V2 Frenzy
JS TZ-V2 Frenzy JS Models TZ-V2 Frenzy Helicopters Discussion
Old 01-20-2009, 06:49 PM   #1 (permalink)
Default JS Model TZ-V2 "3D Frenzy" Helicopter Kit
A Main Hobbies announced availability of the second generation TZ-V2 .50 size pro level helicopter kit from JS Model, affectionately called the "3D Frenzy"! Featuring strong and lightweight G-10 main frames, 120 or 140 degree swash-plate, full metal main blade grips and other "Pro" level features, the TZ-V2 "3D Frenzy" helicopter will surprise you with its low cost and superb flight performance! The narrow-profile design of the fuselage and main frame helps reduce drag for smoother, faster flight in all directions.
Building this kit is fast and easy as many of the sub-assemblies come pre-assembled at the factory. The initial flight characteristics when assembled out of the box are extremely smooth and stable, making it perfect for beginner and intermediate level pilots. For the more advanced 3D pilots, adding a set of lightweight 3D paddles and blades (such as the Curtis Youngblood "Stick Bangers" and "Super Stubz"), this helicopter becomes a 3D monster! Even the most advanced pilots will enjoy how quick and agile the "3D Frenzy" becomes! On top of the awesome performance, the low cost of replacement parts makes the TZ-V2 "3D Frenzy" the perfect .50 sized nitro helicopter for pilots of any level. From "Mild to Wild", the "3D Frenzy" delivers what you're looking for!
Check out the HD video of the prototype helicopter in action on You Tube! Don't forget to watch the video in HD mode for maximum quality:
http://www.youtube.com/watch?v=757Sqvy-41I
The helicopter kit will sell with a street price of $219.99, without main blades. Helicopters are expected to arrive in the first or second week of January.
You can find this product listed here:
http://www.amainhobbies.com/product_...ducts_id/33176
Key Features
* Strong and lightweight G-10 side frames
* Three point metal mainshaft bearing mounts
* Metal main blade grips
* Strong A-Arm style CNC machined elevator linkage
* CNC machined aluminum engine mounting block
* Push-pull linkages on all cyclic servos
* Forward mount engine for easy glow plug access
* 120 or 140 CCPM swashplate control system
* Front mounted radio mounting frame
* Low maintenance belt driven tail
* Easily removed, vibration-isolated fuel tank
* Pre-painted white fiberglass canopy with decals
Specifications
* Type: .50 size glow powered 3D Pro Helicopter
* Control System: 120/140 degree CCPM
* Rotor Blade Length: 600mm
* Tail Blade Length: 84mm to 95mm
Kendall Bennett
A Main Hobbies.com
KendallB is offline        Reply With Quote Quick reply to this message
Old 01-20-2009, 06:50 PM   #2 (permalink)
Parts are now available on the web site also. Kits will be back in stock soon:
http://www.amainhobbies.com/index.php/cPath/2_375_1072
Kendall Bennett
A Main Hobbies.com
Old 03-01-2009, 09:22 PM   #3 (permalink)
Default Tail boom question
Hey Kendall
I just finished building my Frenzy and I have a question. The boom did not have a slot where it entered the boom block yet the blocks had the tabs for alignment so I just notched the boom to fit is that the right thing to do or am I missing something. Great Helicopter looks really good and I cant wait to get it finished up and flying I just wanted to make sure I didn't mess up and need to order a new boom.
Raymond McFaul
Team Grand RC
BigMc70 is offline        Reply With Quote Quick reply to this message
Old 03-28-2009, 03:03 PM   #4 (permalink)
I am assuming you already solved this problem. They have changed the tail booms to not have a slot in them anymore to avoid cracking the booms. The slots in them make them weaker. The new tail cases have a small hole drilled when the boom pin would normally be, and you should remove the pin to get the boom in there properly.
If you got one of the old tail cases, give us a call and we can send you out a replacement tail case with the pin removed.
Kendall Bennett
A Main Hobbies.com
Old 04-01-2009, 06:26 AM   #5 (permalink)
Hi kendall,
I just wondering is that the plastic/aluminum swash plate comes with the kit?
cybertk is offline        Reply With Quote Quick reply to this message
Old 04-01-2009, 09:08 AM   #6 (permalink)
Yes. The composite plastic/alum swash comes with the kit. The all alum swash is sold separately as an upgrade.
- James -
www.RCTodayShow.com Host
James Kovach is offline        Reply With Quote Quick reply to this message
Old 06-16-2009, 10:07 AM   #7 (permalink)
What is the gear ratio on Frenzy?
dyoo is offline        Reply With Quote Quick reply to this message
Old 06-16-2009, 12:50 PM   #8 (permalink)
The main gear ration is 8.5:1 and the tail ratio is 4.56:1
aka: Upside_dan
Frenzy 50 with SK-360, AR7100R, BLS451, Edge FBL Blades, Spartan DS 760.Frenzy 90 with SK-720, AR7100R, BLS451, OS 91 HZ-PS. ELY-Q Vision 90 with BeastX, AR7100R, BLS451, OS 91 HZ-R, Radix FBL. JR X9303
heartnspirit is offline        Reply With Quote Quick reply to this message
Old 05-21-2010, 12:07 PM   #9 (permalink)
Are you people recommending this kit?
Azalin is offline        Reply With Quote Quick reply to this message
Old 05-27-2010, 03:49 AM   #10 (permalink)
Hi Kendall,
Do you think if .30 size engine is powerful enough for this frame? I mean for Beginner Pilot, I'd assume he's not gonna do any of the fancy 3D (maybe by accident)
Naden is offline        Reply With Quote Quick reply to this message
Old 05-28-2010, 11:21 AM   #11 (permalink)
I wouldn't try to run a .30 size engine in the Frenzy. If you could make it work you'd have one seriously under powered bird. Hyper .50s can be had cheap now, new or used, and would be good in bird for a beginner. I think this would be a better way to go. If you are really underpowered you stand a chance of not having the power to pull you out of a mistake. I know having extra power actually helped me when I was learning. The frenzy is pretty docile in stock config and would work for someone who is learning. No need to under power it.
Mr Nice Guy is offline        Reply With Quote Quick reply to this message
Old 05-30-2010, 10:34 AM   #12 (permalink)
Mr Nice Guy, Thanks mate.
A friend of mine handed me a crashed Kyosho Nexus .30 heli and wanted me to fix it up for him. I told him out of it as it's not worth fixing that old bomb. I convinced him to build new one using his .30 OS max engine, JRs servos and Futaba radio gear. He has a window of about AUD$400. Please tell me what heli can I get him?
PS, I also have to get him a glow plug starter/regulator, new Lipo + Charger.... all in that $400
Thanks again mate.
Old 05-30-2010, 11:39 AM   #13 (permalink)
Thunder Tiger Raptor .30 would be a good one.
Old 12-10-2010, 06:57 AM   #14 (permalink)
Thanks again mate.
Old bomb You have got to be kidding! The Concept 30 series is probably one of the best trainers ever designed. Sure It won't do 3D but as far as a trainer goes there's nothing on the market today that can compete with it.
blazen1024 is offline        Reply With Quote Quick reply to this message
Old 12-11-2010, 12:36 AM   #15 (permalink)
Hi guys, I just finish my JS Frenzy 50 V2 and I love the heli, well done all around. I notaced that there is a couple extra holes in the head arms where you can change the set up (Im guessing) was wondering if someone has some info in this and if someone has made any changes on the out of the box set up. I read that the closer holes on the flybar arms help with quicker response, but Im not sure. If any of you have any info will be nice if its share with us.
Thank you
crgonzalez08 is offline        Reply With Quote Quick reply to this message
Old 12-11-2010, 08:19 PM   #16 (permalink)
Think servo arms...See this video, scroll down. At the 8:40 mark he explains it.
http://allthingsthatfly.blogspot.com...v2-frenzy.html
Minion Mini Quad 4S / Mini Talon V-tail Drone / Micro H Quad on Taranis FPV
Rollin_3z is offline        Reply With Quote Quick reply to this message
Old 01-07-2011, 08:33 PM   #17 (permalink)
is amain going to get the fb version of the .50 back in stock anytime soon?
hamstar78 is offline        Reply With Quote Quick reply to this message
Old 02-13-2011, 07:35 PM   #18 (permalink)
Thanks again mate.
Replace it with a century hawk pro 30. Their now yellow though not white so it look better. The body
is strong and it going for 200 dollars at tower. Theres no body bitching about this helicopter notice
not to much thread about the heli because nobody doesn't really have any problem. Anyways this
helicopter can also do 3d. I've seen them fly also I had raptors. [ame]http://www.youtube.com/watch?v=tlxS4yVXDkg&feature=player_embedded[/ame]
Hi my name is Jim and I am a Heliholic. Darn Heli-Crack Addiction!! lol
The heli virus has infected me and i hope that there is NO CURE!
rcjames is offline        Reply With Quote Quick reply to this message
