Old 08-21-2010, 06:11 PM   #81 (permalink)
Anyone use Mikado head? If you are using MIKADO HEAD you change dampers ? The shafts are same the ALIGN ?
Trex 700E 12s Pro DFC
Trex 600E 10s with Vbar
Trex 450 Pro with Vbar
Trex 250 with scorpion 3600Kv
VDFS is offline        Reply With Quote Quick reply to this message
Old 08-22-2010, 10:22 PM   #82 (permalink)
Yes Mikado.
Shaft is different from align
Did not change dampners, they are very soft.
But it has the right geometry for Vbar
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
Old 08-23-2010, 07:54 AM   #83 (permalink)
I use this head too. But on second flight blades touch on tail boom but heli do not crash. I need change dampers. What pitch, motor and pinion you use? Where i find this shaft?
I use V5 v-bar.
How i increase speed the tail? How i change agility the heli? What flight style is more agressive? What gain you use?
Old 08-23-2010, 11:51 AM   #84 (permalink)
12 deg pitch
Neu 1107/2Y
11T Pinion
60 main rotor gain
KBD tail blades
Tail servo on boom
325mm Radix
ReadyHeli has mikado spindle shaft
Old 08-25-2010, 12:24 PM   #85 (permalink)
I ckeck head and i see spacers and i have other doubt. This spacer is a "cone" the part that have biggest diameter touch on bearing the grips or it touch on dampers? I can use part with smaller diameter touch on dampers?
Old 08-28-2010, 11:55 PM   #86 (permalink)
I took some pictures of my Trex 450 Pro this evening. Mini V-bar 5.0 with align 3G head.
ID:	176801   Click image for larger version
ID:	176802   Click image for larger version
ID:	176803   Click image for larger version
ID:	176804   Click image for larger version
DX18
nCPX
Skype: LogoFreak
LogoFreak is offline        Reply With Quote Quick reply to this message
Old 09-04-2010, 04:11 PM   #87 (permalink)
well i ordered my fbl set up... its been a month after i initially set out to order but work got me busy. i went with the mini v 5.0 and the align head i think this is a gonna be good combo. i also ordered some edge fbl blades as well.
one question though are you guys using your spektrum RX or are you using Sat. RX's? if you are using the sat. RX are you using 1 or 2... tia
cant wait to get my new stuff in
KidHeli is offline        Reply With Quote Quick reply to this message
Old 09-04-2010, 08:55 PM   #88 (permalink)
I started out with one Sat, but after upgrading to MiniV Ver. 5.0 and seeing all the Antenna Switches in the Log, I switched to 2 sats. Would stick with Normal Spectrum mode, not Hi Res 2048 Mode, as having issues with that mode.
The align 3G head is nice, Geometry is not as good as Mikado Head, I just switched from Align 3G head to Mikado, as fighting a Elevator Bobble...Both work ok.
Old 09-04-2010, 10:02 PM   #89 (permalink)
o man... i wonder if i should get my order changed to the mikado head
what do you mean the geometry is better? the guy at readyheli said that the align would work best...
Old 09-05-2010, 01:30 AM   #90 (permalink)
Mikado has a geometry tool where you input the distances between swash balls, blade grip arm length ect. And it calculates how well it will perform flybarless.
The Align 3G Head has shorter arms than the Mikado Head, thus does not score as high in the geometry calculation.
I like the design of the Align 3G head, but it's dampening is too stiff, and geometry not as good.
THe Mikado Head dampening to very soft, which I do not like, and no thrust bearings.
Nothing is perfect,
Old 09-05-2010, 11:42 AM   #91 (permalink)
Smile
Definitely easier to fly... less correction in hover, less twitchy... I would recommend it to any beginner... Setup is also much easier, all the guesswork is taken out of it (well that's if you use mini v-bar 5.0)
DX18
nCPX
Skype: LogoFreak
Old 09-06-2010, 01:37 PM   #92 (permalink)
Nothing is perfect,
I've heard that the TB red dampers were good so that's what I'll be using in my build with the 3G head. Have you tried those?
T-Rex 250SE 3G
T-Rex 450Pro V-Bar
T-Rex 500ESP 3G
T-Rex 700E 3G
PatrickH is offline        Reply With Quote Quick reply to this message
Old 09-06-2010, 08:47 PM   #93 (permalink)
^^^ dont have the red but have the green....
Old 09-06-2010, 09:15 PM   #94 (permalink)
I have the red, the green, the black. The stock dampner is soft rubber but is still very stiff dampening due to the head design. I don't see how the harder red, green dampner could help
Old 09-08-2010, 12:16 PM   #95 (permalink)
Does the mini v-bar 5.0 work the same as the Skookum SK-720 6-axis Flybarless System im a new bi and want to convert my 450 pro to fbl . i know the SK-720 is a little more expensive but if its better for a new bi i would rather pay it?
Neotacoma is offline        Reply With Quote Quick reply to this message
Old 09-08-2010, 05:21 PM   #96 (permalink)
For anyone who has setup the Mini-V with Satellites: How are you getting the servo's square'd up? I don't have a spare receiver and the instructions state that you should start with servos unplugged. I'd hate to have to remove them half way through the setup.
T-Rex 250SE 3G
T-Rex 450Pro V-Bar
T-Rex 500ESP 3G
T-Rex 700E 3G
Old 09-08-2010, 09:07 PM   #97 (permalink)
I did it in Trim Mode with head off and swashplate leveler.
You can tell of the servo's are at 90 deg by leveling the swash at mid stick, then.
Then I went to expert and moved collective high, if swash was not level I went back to normal(happy face) mode and adjusted the trim on the servo that was either high or low. Then I checked collective low and repeated.
I did not adjust trim at Collective high and low. If the Servo's are at 90 deg then travel to positive and negative collective swash should remain level.
Kind of a pain as you have to do it for each servo and go back and forth.
Old 09-08-2010, 09:11 PM   #98 (permalink)
Can you get to trim mode with Express or do I need to upgrade to Pro?
T-Rex 250SE 3G
T-Rex 450Pro V-Bar
T-Rex 500ESP 3G
T-Rex 700E 3G
Old 09-08-2010, 09:36 PM   #99 (permalink)
You can just go thru the setup when you need to setup the servos, then when the servos are all installed into the frame and the heli finished just go thru the setup again to get all the other settings all done. You don't need the pro version.
DX18
nCPX
Skype: LogoFreak
Old 09-16-2010, 05:34 PM   #100 (permalink)
Default Rod length from blade grip ro swash
i was wondering if some one could tell me what the approximate length the rods should be between the swash and the blade grips. almost done with my FBL t-rex 450 pro.
TEAM:
CYCLONE BLADES
matt blaisdell is offline        Reply With Quote Quick reply to this message
