Old 12-24-2013, 01:37 PM   #1 (permalink)
Default First time Mini Protos builder with a few questions (Now problem with 1way b)
Hi guys! I'm in the process of putting together my MP and I have a few questions. First, where can I get the washer in the main grip PN MSH40087. Does it come with any of the replacement part kits? Its the one just before the outer BB. I had 2 .
Second, the swash links bind on the canopy posts. Should I be using the shorter swash balls for FBL?
Third, Is the MKS DS8910A+ a good tail servo for this bird? I have one laying around I want to use.
Fourth, anyone have a setup for the HC3SX they want to share?
I also have a 450SEv2. So far I like the way the MP is designed over the SE, but the proof is in the sky. Cant wait to take it out. Savox SH0255MG servos, 3S, Castle ice lite 50, Align 3G blades(for now), stretch kit on the way.
RaptorFuel is offline        Reply With Quote Quick reply to this message
Old 12-24-2013, 02:15 PM   #2 (permalink)
More questions. Thick or thin spindle spacer for FBL? Are aftermarket tail blades worth it?
Old 12-24-2013, 02:39 PM   #3 (permalink)
I will answer where I can.
Use the shorter balls yes, the longer ones apparently can cause binding as you found out.
Yes you need to use the thicker spindle spacer for FBL setup.
DX8 - Gaui X7 - Gaui X5 - Gaui X3 - Mini PRÔTOS
Blade 130 X - mCP X BL - Blade nCP X
grovey is offline        Reply With Quote Quick reply to this message
Old 12-24-2013, 02:54 PM   #4 (permalink)
DS 8910A+ works well with the Mini.
Washers are included with MSH41039 (main blade grips with hardware)
ScottS runs a HC3SX I believe, he might chime in.
MSH-Direct is offline        Reply With Quote Quick reply to this message
Old 12-24-2013, 03:52 PM   #5 (permalink)
I have owned several Align and one MA 450. It took a parts issue for me to "jump ship" from MA. Now with the Mini I look back and think about ALL the reading I did on the Mini. It really should have been in my fleet much sooner. I LOVE the way this thing sounds (or doesn't sound) compared to the others. I replaced the plastic bearing blocks and went with the lower head. Something I think should be a "kit" option. Not a big deal though.
LOGO 200, DIABOLO 550, DIABOLO 800, SOXOS 7.1
VCONTROL*NEO*TRIBUNUS*MKS*VTX*DPL8 W/BUMP CONTROL*MEANWELL
Corvette & Copter Guy is online now        Reply With Quote Quick reply to this message
Old 12-24-2013, 05:00 PM   #6 (permalink)
Yup. I am new here and only have 5 flights on it now, but I am hooked already and believe the hype. This thing is plain awesome. Such a smooth operating helicopter and like you said. Sounds (or doesn't) amazing.
OP, you are gonna love this helicopter. Just take your time through the build.
Old 12-26-2013, 06:10 PM   #7 (permalink)
Haha I'm also new here, and also only 5 flights on it, I haven't flown anything similar in size so I can't compare but it's definitely real quiet. Plenty quiet for some insane blade noise
I'm really loving it
I have had one single issue until now : my OWB gets stuck when I fly it. It's not very hard to get it unstuck by hand, but I'm not sure if an autorotation would generate power to get it working. I don't have enough confidence in my skills to try it.
It's not really a major problem but still a bit annoying.
I have another 16t pinion in the mail so i'll probably give that one a try, if I manage to get the current one out
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 12-26-2013, 10:37 PM   #8 (permalink)
The thick spacer for FBL and the Lynx tail blades will give you great bite! The stock blades little soft.
Enjoy 1 of the most awesome 450s out there!
Rick,
Team pilot ,
EGODRIFT, KST, Helidirect, Lynx/Oxy
crickr1 is offline        Reply With Quote Quick reply to this message
Old 12-27-2013, 02:43 PM   #9 (permalink)
Its all together and I tried spinning it up. One way bearing is a no way bearing. I tried spinning the motor both ways. The bearing slips in both directions. Did i install it wrong or is it broke? looking it over it looks like I installed it right.
Old 12-27-2013, 03:02 PM   #10 (permalink)
You mean the motor is always spinning the main blades or never.
If it's always spinning them, you can try turning the motor anti-clockwise while holding the main blades (or the pinion), it could just be a bit stuck.
Shoot us some pics and we'll tell you if it's installed the wrong way, I don't really see how that's possible though.
Old 12-27-2013, 03:09 PM   #11 (permalink)
[QUOTE=Aryemis;5522335]You mean the motor is always spinning the main blades or never.
Shoot us some pics and we'll tell you if it's installed the wrong way, I don't really see how that's possible though.[/QUOT
The main blades never spin. I tried spinning the motor in both directions. Pictures will probably have to wait until morning.
Old 12-27-2013, 03:11 PM   #12 (permalink)
Have you checked if your pinion was cracked ?
The pinion I got with the kit was cracked. I sent a pic of it to my LHS and got another back for free so it was fine.
Old 12-27-2013, 03:36 PM   #13 (permalink)
I don't see a crack. Even under a magnifying glass.
Old 12-27-2013, 03:39 PM   #14 (permalink)
Well then unless the pics prove otherwise, you need another pinion.
Old 12-28-2013, 02:43 AM   #15 (permalink)
When you turn the pinion by hand on the motor shaft, does it engage (ie lock up) in one direction?
2x MCPX I Gaui »X1« I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
Old 12-28-2013, 04:33 AM   #16 (permalink)
I can spin it by hand in both directions.
Old 12-28-2013, 10:20 AM   #17 (permalink)
Old 12-28-2013, 10:42 AM   #18 (permalink)
Well It looks like it's been properly mounted, your pinion is most certainly broken.
Send a mail to your LHS and he should send you a new one for free.
Old 12-31-2013, 02:05 PM   #19 (permalink)
New pinion is on its way.
I have an HC3SX mounted under the main shaft. I'm guessing I should spring for the metal servo mounts right? I searched but I cant find an instance where the main shaft was shoved all the way down in a crash. Anyone have a link to this happening?
Old 12-31-2013, 02:36 PM   #20 (permalink)
Can't remember this happening on a Mini - maybe it has, but on the Protos 500 I'm pretty sure it's happened.
Mini Protos, Voodoo 400, Protos 380, Protos Leggero 700 & 700X, Diabolo 700
Chris Nifty is offline        Reply With Quote Quick reply to this message
