Old 06-05-2007, 12:07 AM   #81 (permalink)
Must be my balancer screwing up because I reset (restarted) and everthing ended up balanced and charged so I must have a glitch in the balancer that I will address with TP
Thanks for the input
Mark
odieser is offline        Reply With Quote Quick reply to this message
Old 06-05-2007, 12:40 AM   #82 (permalink)
Team Taco VP
No you dont... this is a glitch I see all the time! If I restart the charger and not reset the balancer then I too get screwy readings.... The charger code can be updated but NOT the balancer..... Just reset EVERYHING and you should be good!
Bob
Old 06-23-2007, 06:37 PM   #83 (permalink)
The Capi
If i ask really nice Bob can we get an updated video on using the charger with nimh and/or A123 ? And if that doesnt work i can ask really jackassory
Old 06-24-2007, 10:02 AM   #84 (permalink)
How do you check which firmware your charger has?
lour is offline        Reply With Quote Quick reply to this message
Old 06-24-2007, 10:03 AM   #85 (permalink)
The Capi
it says when you first power up the unit.
Old 06-24-2007, 10:07 AM   #86 (permalink)
If you do need to update your 1010 how do you go about loading it with the latest Firmware?
Old 06-25-2007, 08:23 PM   #87 (permalink)
The Capi
YOU have to buy the USB programmer for it. If you can find someone with it in stock tell me
Old 06-25-2007, 08:24 PM   #88 (permalink)
Team Taco VP
I cant find it in stock ANYWHERE myself... Been borrowing a friends
Bob
Old 06-25-2007, 08:32 PM   #89 (permalink)
The Capi
Why couldn't they have used a USB connector on the dang thing ? Or if they don't wanna go that extra mile why not just use an RS232 ?
Old 06-25-2007, 08:43 PM   #90 (permalink)
Team Taco VP
Well they do use a USB but also a converter to talk to the main board over a propritary interface
Bob
Old 06-28-2007, 03:57 PM   #91 (permalink)
Default A123 please
Yes that is what I need also. Video to use with A123.
DX18 ; Forza 450 , Energic Slope/E glider , Snipe DLG
jyheli is offline        Reply With Quote Quick reply to this message
Old 06-29-2007, 01:51 AM   #92 (permalink)
Bob
DraganFly has them in stock most of the time, that's where I got mine.......
http://www.rctoys.com/rc-toys-and-pa...RS-WIRING.html
Jeroen -
Just fly it!
BarnOwl is offline        Reply With Quote Quick reply to this message
Old 07-02-2007, 08:28 PM   #93 (permalink)
I have never been able to get the charger and balancer to work on any of my 9 different 3S 2150 packs. They are different brands (align, FlightPower, and DN) and the only thing that will happen is the balancer reads the pack levels, but when I initiate the charge cycle with 3 cells at 2.1 Amps the charger starts off correctly and then after reaching 1.9 to 2.0 amps it shuts down completely with no message at all. Only once was I ever to get it to work and that was without the balancer on just one try out of about 40 attempts. I even bought new EVO 25 packs this weekend and it would not work on either of them. But they are balanced almost perfectly and charge just perfectly on a different charger I have that also indicated they are taking the appropriate amount of charge. I am very frustrated to spend that kind of money and not be able to get them to work on all my packs. The combo unit has worked quite well charging my TP 5000 with only one error and I reset the charger balancer and it worked fine. But still no luck at all with the 3 cell 2150's.. Any ideas would be appreciated, My next move is take it back and ask to exchange it or at least try another one.
doug
TRM Power - RC Racing Engines - - Blackout Mods Conversions - - VP Racing / Powermaster Fuels - - Gas-Powered-Helicopters.com
Doug Darby is offline        Reply With Quote Quick reply to this message
Old 07-03-2007, 10:03 AM   #94 (permalink)
Team Taco VP
Hmmmmm no idea really... Works fine for me and all my FP packs from 3S up to 10S. Since your having this problem on more than one pack I have to assume something is wrong with your charger or balancer.
What code level is your charger? If it is an old version that might be it?
Also what are you using for input power? Have yo tried a car battery? The charger is picky about input power if it is noisy or low in voltage.
Bob
Old 07-03-2007, 01:57 PM   #95 (permalink)
I have a high end power supply but I also tried it on my Truck battery with no luck. Where can I find the code level? I will check the display when I start it up to see if it says it there.
doug
Old 07-03-2007, 05:55 PM   #96 (permalink)
Team Taco VP
yes it says there on power up.
Bob
Old 07-04-2007, 11:25 AM   #97 (permalink)
Version 2.0c.. I don't think that would be the problem???
doug
Old 07-04-2007, 11:30 AM   #98 (permalink)
Team Taco VP
No that is an OK version. Sounds to me like you got a bum charger. If you dont hook up the balancer does it do the same thing?
Bob
Old 07-04-2007, 10:12 PM   #99 (permalink)
Yes... Only once out of about 40 attempts did it function on a 3s and that was one of many tries without the balancer.. The power supply provides 13.8 V at up to 30 Amp. But the truck battery yielded the same results. Still worked fine for the TP 5000 mah 6 cell I charged 3 times today..
doug
Old 07-06-2007, 10:14 PM   #100 (permalink)
Problem solved... The charger was bad.. Exchanged it to day for a new one that worked perfectly..
Thanks for the suggestions Bob..
doug
