Old 02-19-2009, 10:11 AM   #41 (permalink)
Question
Hi Howard,
I ordered the CPII-c3 yesterday, will this work on the raptor 50 without modifiying anything like the digital servos? Im really just a newbie in this field of hobby so I dont understand a lot of terms in the heli side (ccpm, psm...). Thanks guru.
Thunder Tiger Raptor 50 Titan, E-Flight Blade 400, E-sky Belt CP, E-sky Honey Bee King 2, Heli Max AXE CPv3, AH64 3ch Co-axial
"To EaCh HiS oWn"
Black Sparrow is offline        Reply With Quote Quick reply to this message
Old 02-19-2009, 12:20 PM   #42 (permalink)
Originally Posted by Black Sparrow View Post
Hi Howard,
Hi,
It's a little dangerous to mix up CPD4 information with CPII information in the same thread. I have answered questions on both systems within this thread. While the two systems both use IR thermo technology to facilitate stabilization, that's where the similarities end. Comparing these two systems is like comparing an '09 Cadillac CTS to a '01 Toyota Corolla. Both good cars, but not in the same class. Let me be very clear about this. The original Co Pilot (CPD4) was designed in the early 2000's. Due to major advancements in microcontroller technology, and 1000's of hours of R&D, the new CPII does not suffer from any of the limitations associated with the older CPD4 design. It is fully compatible with all radio systems, all analog or digital servos, and virtually any aircraft configuration. No workarounds such as the use of analog servos or servo buffers are required when using the CPII system. Here is a couple of shots to show the size difference of the systems:
Top View - New Sensor vs. CPD4/FS8 Sensor
Side View - New Sensor vs. CPD4/FS8 Sensor
Top View - FS8 "Z" Sensor vs. CoPilot II Vertical Sensor
Side View - FS8 "Z" Sensor vs. CoPilot II Vertical Sensor
New 3 wire cable (standard aileron extension) vs. CPD4/FS8 ribbon cable
Howard Matos is offline        Reply With Quote Quick reply to this message
Old 02-19-2009, 09:05 PM   #43 (permalink)
Thanks Howard. You've been a lot of help specially explaining the difference in these two system. I cant wait for it to arrive and mount on my heli. Now I know I made the right choice in getting the CPII instead of the cpd4.
"To EaCh HiS oWn"
Old 02-20-2009, 10:50 PM   #44 (permalink)
Is it available yet?
"To EaCh HiS oWn"
Old 02-21-2009, 12:44 PM   #45 (permalink)
Hi,
Not yet but I'll let you know as soon as they are!
E2C_Mech is offline        Reply With Quote Quick reply to this message
Old 02-21-2009, 07:25 PM   #46 (permalink)
keeping this thread alive...
"To EaCh HiS oWn"
Old 02-23-2009, 12:26 AM   #47 (permalink)
until it arrives...
"To EaCh HiS oWn"
Old 02-23-2009, 09:13 AM   #48 (permalink)
So in terms of functionality, this device is no different than the AP2000i?
Pat L
makiedog is offline        Reply With Quote Quick reply to this message
Old 02-23-2009, 10:22 AM   #49 (permalink)
Apparently you didn't read the responses to my questions. It is functionally better if it flies over snow better and doesn't react to low sun on the horizon.
Swift .46 on 6S,Homebuilt Swift HELICAM on 5S,TREX 450 HDE (Mech mix),TREX 450 custom HDE to direct CCPM conversion helicam with stretch boom and 350's, Blade3D with custom frame and belt drive .
aramsdell is offline        Reply With Quote Quick reply to this message
Old 02-23-2009, 11:14 AM   #50 (permalink)
Yes I did read the reply: "There is no problem flying over snow, cold sky, or low sun on the horizon.".
Seems like a general statement to me. I'm sure AP200i could claim the same, it has no problem flying in these conditions, just not optimal when compared to ideal condition.
I guess I was looking for a more detail explanation as to why this device will perform better. Is it because of a different sensor technology? Software? Or the integration of the vertical sensor?
Pat L
Old 02-23-2009, 06:43 PM   #51 (permalink)
Howard,
Any chance the manual will be available via .pdf anytime soon?
Thanks!
1fastt2 is offline        Reply With Quote Quick reply to this message
Old 02-23-2009, 08:47 PM   #52 (permalink)
Originally Posted by 1fastt2 View Post
Howard,
Thanks!
Hi,
We're working on the manual now, but it probably won't be ready until close to the time that the product ships, which is still slated for end March '09. But we do have a really good flow diagram already. Check the following link:
http://www.fmadirect.com/other_technical.htm
From the above link, click on the document titled "Co Pilot II Flow Diagram". If you take a minute to go over this, you can see how all the menu systems work for the Co Pilot II using the IRNet programmer. You'll need to zoom in and scroll around. It's really simple to set up. Of course, if you're interested in knowing how the sensors mount, you can check the photos presented earlier in this thread. Also, for background information on Co Pilot technology, you can check the manuals for the older systems. Although setup, features (like 3D modes) and compatibility are vastly improved and simplified, the basic principles have not changed; meaning the system still uses FMA patented thermo technology for stabilization as opposed to gyros for instance.
CPD4 Manual -
http://www.fmadirect.com/support_docs/item_1126.pdf
FS8 Co Pilot -
http://www.fmadirect.com/support_docs/item_1239.pdf
The FS8 differs substantially from either the CPD4 or the CPII in that it included an 8 channel FM receiver. The new CPII is similar to the CPD4 in that it is a stand-alone system to be used with your existing radio receiver.
Old 02-24-2009, 05:32 AM   #53 (permalink)
Howard,
Thanks for the quick reply. Would you be able to briefly explain the calibration process required for the CPII?
Old 02-24-2009, 09:36 AM   #54 (permalink)
Howard,
Hi,
If the customer purchases the vertical sensor, calibration is continual and automatic. Just fly the model. If the vertical sensor is not included in the purchase, the system knows it is not connected. An extra menu option comes up on the IRNet programmer for manual calibration. In this case, customer's are advised to calibrate the unit once per flying day or whenever the weather changes significantly during a flying day. Calibration in the CPII is reduced to a weather check only now. Put the aircraft on it's nose, tail, or one wing down, then press the ENTER button on the programmer. The system records the weather reading. That's it.
Either with or without the vertical sensor, the temp differential between earth and sky is presented as a temperature variance on the LCD. It is available any time the system is operational. If the weather is extremely poor, the system warns the customer. If the temperature variance is inadequate for stabilization to work properly, the system notifies the customer and disables stabilization. If you check the flow diagram, you will see these warnings under the main menu option "CHOOSE TASK? >PREFLIGHT".
Old 02-24-2009, 11:24 AM   #55 (permalink)
Thats exactly what I was looking for. Sounds like a great unit and I cant wait to recieve mine. Maybe your post of how easy this unit will be to operate will sway some more customers to purchase one.
Thank you!
Old 02-24-2009, 06:07 PM   #56 (permalink)
Still waiting...Sound really a product. Can't wait for it to arrive.
"To EaCh HiS oWn"
Old 02-25-2009, 11:53 PM   #57 (permalink)
Im having dreams at night installing the copilot II on my heli. Now I cant wait to sleep so I can have the same dream again. Any news yet when it will be shipped .
"To EaCh HiS oWn"
Old 02-27-2009, 03:50 PM   #58 (permalink)
Do all the sensors require a clear view of the horizon ?
Is the forward part of the tailboom the only mounting alternative ?
Darkside41 is offline        Reply With Quote Quick reply to this message
Old 02-27-2009, 04:58 PM   #59 (permalink)
Jay
Default copilot 2
Ordered mine yesterday, look forward to testing it out
Jay is offline        Reply With Quote Quick reply to this message
Old 03-01-2009, 11:57 AM   #60 (permalink)
It's March!!! Just a few more days...
"To EaCh HiS oWn"
