Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Like Tree4Likes
Old 09-29-2014, 11:47 PM   #41 (permalink)
CHC Benefactor
Originally Posted by Coolheli View Post
I’m very much interested in the reasoning for those long tail blade bolts.
Every time I look there I think and I want to ask. Let’s not waste any more valuable time on this.
Please help me build it faster by pointing to the answer or explaining it.
My guess is a simple implementation of Chinese weights. Cheers.
Edit: Richard beat me to it and explained the purpose of Chinese weights as well!
Old 09-30-2014, 07:51 AM   #42 (permalink)
Thumbs up
Originally Posted by Wh1teAfr1can View Post
It has to do with physics. by placing masses outside the rotational axis of the tail rotor you induce a force that helps to cancel the blades natural tendency to return to zero pitch this reduces load on the tail servo and makes for a better responding tail because a larger portion of the tail servos torque can go to changing pitch rather than having to hold against the blades natural tendency.
Thank you for an excellent explanation.
Coolheli is offline        Reply With Quote Quick reply to this message
Old 09-30-2014, 12:46 PM   #43 (permalink)
Question
Carbon windshield decal looks way too big. Are we supposed to cut it to size?
ID:	539336   Click image for larger version
ID:	539346   Click image for larger version
Old 09-30-2014, 01:31 PM   #44 (permalink)
On the site there is a video showing how to install it. They are oversized so you cut up the joint to match them
http://www.peakaircraft.com/Manuals.cfm
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 09-30-2014, 03:20 PM   #45 (permalink)
And go sloowwwwwwww with that.. Slllllooooooowwwwww.. Lol
Diabolo S #41
TDR 2
The others come and go..
craigdieselmac is offline        Reply With Quote Quick reply to this message
Old 10-01-2014, 08:20 AM   #46 (permalink)
Thanks for adding valuable info to this thread
As per your advice
This was the only clear alcohol I had.
The canopy got degreased so well that I become naturally slow.
ID:	539513   Click image for larger version
ID:	539514   Click image for larger version
ID:	539515   Click image for larger version
Old 10-01-2014, 03:46 PM   #47 (permalink)
Mmmmm.. I would do have used very little for the canopy.. And the rest for me! I do love to drink and tinker.. puts me in my zone.. Slows me down.
Diabolo S #41
TDR 2
Old 10-01-2014, 04:34 PM   #48 (permalink)
Slowing down isn't a bad thing cause building is one of the most fun parts. To me at least it is
wes likes this.
Richard Zappe
Old 10-01-2014, 04:48 PM   #49 (permalink)
The older I get.. The more I like the build, when I was younger it was more about the finished product and getting it done so I could fly it.
Diabolo S #41
TDR 2
Old 10-03-2014, 10:24 AM   #50 (permalink)
Package with bits and pieces needed to complete the build is to be delivered today.
18 tooth pinion is the one I'll start with. Custom Kosmik bullet connectors for direct motor connection are there as well. Can't wait.
Old 10-04-2014, 01:20 PM   #51 (permalink)
Tail servo is finally in place for good. Fitting the X8 servo in there properly presented a challenge to start with. The frame opening limited the number of servo arm styles that could be used. I decided against enlarging the bottom part of the opening due to close proximity of the frame edge. At the end I cut and filed the stock arm that came with the servo. Ball is set at 17.5mm from the centre.
ID:	540170   Click image for larger version
ID:	540171   Click image for larger version
Old 10-04-2014, 01:46 PM   #52 (permalink)
As mentioned before I will start with 18 tooth pinion.
Custom Kosmik connectors cut the connection resistance to the bare minimum while making the installation look sooo.... clean.
ID:	540180   Click image for larger version
ID:	540181   Click image for larger version
ID:	540182   Click image for larger version
ID:	540183   Click image for larger version
ID:	540188   Click image for larger version
Old 10-05-2014, 10:55 AM   #53 (permalink)
Hi
I have been reading this thread.
Looks super cool.
I have a Diablo on order and will do it "UAE Style"......
I am getting the steal 2nd stage gear and 3rd bearing on the 1st stage gear.
I also ordered a XNova 4535-520..... To test out and compare to my Pyro 800.
I have MKS X8 servos, VBar, Kontronik Pyro 800-48, Kosmik 200..
Can't wait.
Regards
Paul
pwood is offline        Reply With Quote Quick reply to this message
Old 10-06-2014, 05:59 PM   #54 (permalink)
Stock power leads that come with Kosmik were about 3 inches short for this specific installation on the diabolo. They were replaced with JR heavy duty (36”) extensions cut to required length. No extensions/unnecessary connections allowed!
ID:	540870   Click image for larger version
ID:	540871   Click image for larger version
ID:	540872   Click image for larger version
ID:	540873   Click image for larger version
Old 10-06-2014, 06:07 PM   #55 (permalink)
I always make my own custom ones and put the cores under the electronics tray next to the boom
Richard Zappe
Old 10-06-2014, 06:27 PM   #56 (permalink)
For the first test Kontronik governor is set to 1760 and 1895rpm for idle up 1 and idle up 2 respectively.
Bail out is set on a separate switch at 26%, almost as per Kontronik instructions (25%) and it works flawlessly.
Old 10-06-2014, 06:46 PM   #57 (permalink)
Nice job on the build!! First class!!
Magneto is offline        Reply With Quote Quick reply to this message
Old 10-07-2014, 04:35 PM   #58 (permalink)
The moment has arrived. Diabolo is ready.
ID:	541148   Click image for larger version
Old 10-07-2014, 04:43 PM   #59 (permalink)
Question
Just as I put the heli away I noticed that the canopy didn’t sit properly when locked in place.
Take a look at the pics. Left side is almost touching the swash ball link.
Anyone else noticed that on the other diabolos?
ID:	541153   Click image for larger version
ID:	541154   Click image for larger version
Old 10-07-2014, 04:49 PM   #60 (permalink)
Yes but it was caused by something being stuck in the teflon locking thing causing it not to go on all the way.
I could also see how that could happen if one was slightly cocked more than the other. Loosen it up, stick it back on, then fully tighten them down.
BustedRaptor77 is offline        Reply With Quote Quick reply to this message
