RealFlight Flight Sim All versions of RealFlight Sim |
07-13-2004, 10:57 AM | #1 (permalink) |
Fury Tempest for G2
For those of you that still fly G2. I have perfected my Fury Tempest. It flys EXACTLY like mine did(It's a box of parts at the moment) I have 2 carbon blade files with it. NHP Razor Pro Symetrical Carbon 720mm & RotorTech Carbon 720mm. The colorscheme I used was created from a picture sent to me requesting a G2 colorscheme. I liked it so much that I had to use it for mine.
Rob |
07-13-2004, 01:41 PM | #2 (permalink) |
OK, Just so you know. The Fury Tempest is based on the sun dog (though the pic is of the foiler) because I got the sundog to fly just like mine. I wasn't able to get the foiler to fly quite rite, the flight characteristics where just off. The canopy is from the foiler though. I felt the foilers canopy looked more like the fury. So I altered the .Heli file to use the foiler canopy on the sundog air frame.
Rob |
07-13-2004, 01:57 PM | #3 (permalink) |
Registered User
I LOVE your Tempest!! Killer. Thanks for sharing it!!
Best flying G2 Heli I have tried yet!!
William James Crazy wife still trying to kill me. |
07-13-2004, 03:51 PM | #4 (permalink) |
Cool. Glad to hear it. I might host a session a little later tonight. Maybe around 8-9pm. I thought that maybe the fioler canopy on the sundog air frame would throw some people off but I just couldn't get the foiler as close as the sundog. Like I said the foiler canopy looked more like the Fury so I just changed the .Heli file to use the foiler canopy. Maybe I'm TO anal about detail but then my work wouldn't be as nice. Half assed just isn't my style :glasses2:
Rob |
07-13-2004, 03:56 PM | #5 (permalink) |
Registered User
I don't care how it looks really, just want it to fly well and it does!!
Thank you!!!
07-13-2004, 08:24 PM | #6 (permalink) |
Is my Fury a Heli Freak or what?
Rob |
08-04-2004, 10:04 PM | #7 (permalink) |
Just installed the Tempest. The head speed stalls under load. Is there a way to fix that? Has anyone had the same issue? If I make a hard turn, the blades stop! What to do?
08-05-2004, 10:28 AM | #8 (permalink) |
I haven't had that happen to me. Try looking at the engine settings. You might need to add a little higher value to the engine power. Is this happening in idle up or in normal mode? Normal mode is set at 1600 and can be bogged or stalled under hard manuvers. Idle up is set at 1900 and can do hard 3D without bogging or stalling to an extent. If you do not manage the collective well the heli will let you know ie. if you put the sticks in the corners in hard manuvers you will hear the head speed decrease as you would expect. I tried to get the power setting as close to real as possible so you have to manage the collective as you would in real life.
Rob |
08-05-2004, 01:58 PM | #9 (permalink) |
I realy enjoy the way the way that tempest flys . You have to remember to use collective managment in 3D on this machine. I haven't had that happen to me either??
Team Align Team Futaba Team V-Blades Team Flightpower Team Duralite Team Powermaster Fuels Team RHR |
08-05-2004, 04:29 PM | #10 (permalink) |
G2 sucks! I can't believe that with Reflex out people are still using that sim. Talk about "old school".
08-05-2004, 05:40 PM | #11 (permalink) |
I downloaded your Tempest. It can't handle a load, what so ever. If I make a FFF turn, the blades stop. Am I missing a setup, or what?
08-06-2004, 03:21 AM | #12 (permalink) |
just add more power in the engine setting. That should be enough.
Rob |
08-06-2004, 12:24 PM | #13 (permalink) |
OK I figured out the problem with the tempest. It was actualy the blade file for the NHP Razors, that was the problem. Some how the airfoil in the file got changed. Just go to the mainblade then click on the edit button and change the airfoil to NACA-0016 that's it. It should be fine then.
Rob |
08-06-2004, 09:17 PM | #14 (permalink) |
Rob,
I fly both a tempest and Extreme and wanted to make your model fly more like the Tempest I fly so I made the following changes to your model: My dad helped my with some of the mathematical calculations to design my own set of blades that are replicas of the MAH 700 dual-taper blades. I found that the airfoil NACA 0011 works very well. I also decrease the cyclic roll deflection to 8.5 as well as alter the paddle airfoil to NACA 64-012. This thin airfoil is similar to the MAH paddle which produces a faster yet solid cyclic control. I run 9252s so I increased the speed by dropping the values to .14 for roll, pitch, and cyclic. I can keep my head speed between 1850 and 1890 for most maneuvers. The Tempest flys much different - solid, snappy, and precise. My changes don't make it the best - just alittle different. Besides, this is a very powerful feature of G2 that makes it fun!!!
08-06-2004, 11:00 PM | #16 (permalink) |
I'm still looking forward to seeing Robert's IRCHA demo after this weekend. Hopefully it will rock!
08-06-2004, 11:20 PM | #18 (permalink) |
Ok. Just flew that gem for a few. NICE! Thanks again!
