Old 06-09-2013, 02:53 AM   #21 (permalink)
"The Gov still works perfectly with CC120HV, the auto bailout didn't appear to work but my ramps are at 80, 80 so i will up them and try again."
Increase the "high ramp" rate, it's used only for the last half of spoolup, and for bailouts.
Skookum is offline        Reply With Quote Quick reply to this message
Old 06-09-2013, 03:03 AM   #22 (permalink)
Fantastic, thanks.
Logo 400SE - Chase 360
Synergy E7SE - Chronos
JR XG8
Hardsy is offline        Reply With Quote Quick reply to this message
Old 06-09-2013, 03:20 AM   #23 (permalink)
Default SL ALWAYS ON- CONFIRMED WORKING ON MY SETUP ON Rev 3.40
Just took my MT out to test the new Firmware.
Put the heli inverted and hit SL. Heli righted itself perfectly.
Repeated a couple of times and got good results.
Well done Skookum:-)
Would be worth someone else who had experienced problems on the old FW giving this a test too.
Cheers.....back to peace of mind flying again with my trusty bailout switch.
Nick
Flying your heli the world is still out there, but at least for the time it hasn't got you by the throat.
Mini Titan E325 FBL, Blade Nano Cpx
nickyd is offline        Reply With Quote Quick reply to this message
Old 06-09-2013, 04:29 AM   #24 (permalink)
Flew all day with my warp and 550 on the new firmware. Both flew really really well. The sk gov on the warp with the YEP speedy works much better now. I was having some initialization issues with the warp though. One of the dsmx sats would only faintly flash every few power ons.... Worked fine otherwise
Beater Helis - MCPX BL & TREX 450 Pro DFC
Warp 360 - SK540, MKS DS92A+ / DS95i, YEP45
TREX 550 DFC v3 - SK540, Radix V2 554's
Goblin 700 - HPS, 4530-500, SK720 & GPS, MKS HBL 950's/980, ICE2 160HV
demon1300 is offline        Reply With Quote Quick reply to this message
Old 06-09-2013, 04:55 AM   #25 (permalink)
Default SBUS issue
Is this sw version 3.40 working with Futaba FASSTest Mode 14 and 18 now?
Cheers Olaf
Prôtos MAX 700 V2, Prôtos500 speciale, BRAIN
Goblin700 SRC burn out edition, BRAIN
Diabolo700, BRAIN; DIABOLO 700UL
Pampaflieger is offline        Reply With Quote Quick reply to this message
Old 06-09-2013, 05:11 AM   #26 (permalink)
Default Rev 3.40 is up
So the so bailout feature will only work with a esc that has a bail out feature like the castle? Will the sk bailout work with all esc? Like my YGE?
6hv (fb)
7hv
DX8
snaaakeey is offline        Reply With Quote Quick reply to this message
Old 06-09-2013, 06:00 AM   #27 (permalink)
Tom. Try it and report back. I would but I'm on holiday so its over to you
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 06-09-2013, 07:46 AM   #28 (permalink)
Originally Posted by Slyster View Post
Thank you Art! I can't wait to test it out on my Goblin 700.
I can't wait to see your results Slyster. I read all about your ele bobble problem, I hope the new firmware fixes it so you can enjoy how awesome the 540 is.
YS Powered Rave ENV Stretch Protos 500, Stretch Mini Protos, 180 Trio
gitbse is offline        Reply With Quote Quick reply to this message
Old 06-09-2013, 08:37 AM   #29 (permalink)
Mine is a 540. Far as I know it doesn't have logging. I have to take some time and look into the whole system before I really know what's going on. I'm running a HW 120 on my 700, which has been great since day one. It appears to be giving me issues now as well.
Align Trex 700 V2 DFC
Skookum SK540
I don't want no stinking Goblin!
Eddge is offline        Reply With Quote Quick reply to this message
Old 06-09-2013, 09:09 AM   #30 (permalink)
Originally Posted by agjoe View Post
Hi sorry dumb question do i have to delete old pc software first
No you do not need to delete older versions, I know because I have multiple versions on my PC for different helis.
thank guy what i do is uninstall the older software and download the new one.as soon back from my holiday i will upgrade my sk540 and see if it fix my nx4 ele problem(dolphin)
A BAD DAY OF FLYING BEATS A GOOD DAY AT WORK !!!
agjoe is offline        Reply With Quote Quick reply to this message
Old 06-09-2013, 09:17 AM   #31 (permalink)
Always best to delete the current desktop short cut and install the newest version.
Old 06-09-2013, 09:48 AM   #32 (permalink)
Same here, I don't have a chance to test it and both my Goblin 700 and X5 do the elevator bobble. I realllly don't want to change controllers!
X5 / Goblin 500 / Goblin 700
psylence519 is offline        Reply With Quote Quick reply to this message
Old 06-09-2013, 09:52 AM   #33 (permalink)
Larry227:
Can you please send a log file showing a no-blades spool up, if you have one?
Sent log files to your info@ address
Trex 700 Pro DFC - Compass 6HV - Vcontrol - Neo
#nodroneshere - 104
Larry227 is offline        Reply With Quote Quick reply to this message
Old 06-09-2013, 10:49 AM   #34 (permalink)
I installed version 3.40, but SL section do not occurs .Has anyone happened that?
ID:	427144   Click image for larger version
SJM 400 V2 now FBL _my first love
HC 500 SE _my fiancée
Gaui X4 ll _my mistress
Outrage 550 _my big love
flydoc is offline        Reply With Quote Quick reply to this message
Old 06-09-2013, 11:03 AM   #35 (permalink)
=] what does it show when you are connected to usb?
Old 06-09-2013, 11:17 AM   #36 (permalink)
I did not upgrade to 3.40 yet,so I'am not connected usb to see what happens.
Old 06-09-2013, 11:22 AM   #37 (permalink)
=] what you are looking at is the 540 screen, SL will show when connected to a 720....
Old 06-09-2013, 11:26 AM   #38 (permalink)
Strange thing. Same happened to me on my SK720. The SL stuff didnt show until I connected my unit up.
Nick
Old 06-09-2013, 11:55 AM   #39 (permalink)
Right. It seems as if the software defaults to the 540 screen, and SL comes in when it detects a 720.
Old 06-09-2013, 12:13 PM   #40 (permalink)
I made upgrade the software and SL appeared,but I do not find normal this.
Thanks to all.
