Old 12-15-2013, 04:58 PM   #21 (permalink)
Nope! This " flashing yellow light" make me crazy too. Couple of hours today... No luck!
Even setup from my previous video, now NOT work!
Tarot? WTF with this ZYX-S2? How to bind with satellite? How to setup? How to (re)set?
Shame!
3Daemon is offline        Reply With Quote Quick reply to this message
Old 12-16-2013, 04:31 AM   #22 (permalink)
Shame!
Anyone knows who to contact @tarot for this issue ? Maybe they are not aware of this and it's a bug or something ?!
fw114 is offline        Reply With Quote Quick reply to this message
Old 12-16-2013, 05:20 AM   #23 (permalink)
Shame!
Mabye they are not aware of this issue and it's a bug. Anyone with an idea how to contact tarot and ask them if there is any solution ?
Old 12-16-2013, 07:08 AM   #24 (permalink)
Sats have to be bound to your tx first via rx.
There are some teething problems i think!!
I can add my servos and sat and motor esc etc all ok red solid light. Servos all work as should in the right direction but no power to motor! Tried different esc and same but this time the motor fires away with no inputs from tx in bursts! The tx did speed the motor up though!
I tried the exact same set up with both esc on an AR7200BX worked as should. Motor spun up with tx inputs. Stopped on zero input. So must be the S2.
I have a replacement on the way so hope that's better and works as should do!
If not then yes Tarot have serious problems on their hands and updates will be needed for the software/ firmware!
Hope you get some luck! I'm still trying to be lucky
Oxy 2 FE, 180cfx spartan lynx pro tail,130x stock, Goosky S1 x 2 , mcpx stock x2, mcpx bl mod, nano cpx dbl bl, nano cpx wild bl, nano cps, DX8. For fpv Phantom 3 pro.
Bhujang is offline        Reply With Quote Quick reply to this message
Old 12-18-2013, 05:47 PM   #25 (permalink)
BT adapter for ZYX-S2
look here
Old 01-10-2014, 09:10 AM   #26 (permalink)
Default XYZ S2 flashing yellow light
I have this same problem. I bound the Spektrum satellite to the Spektrum receiver and then tried to get the S2 to work. Everything I have tried results in a flashing light. Chinese documentation sucks. I'm just bit the bullet and bought a AR7200BX and have had no problem. Yes, 4 times t he cost but at least you don't waste a lot of time with a product like the ZYX S2 that doesn't work.
HLHAMNER is offline        Reply With Quote Quick reply to this message
Old 01-15-2014, 03:24 PM   #27 (permalink)
44 flights with ZYX-S2 (DSM-2 sat) for now. So far so good. Couple days ago also got the ZYX-BTM module, work fine with Android app (usability IMHO better then previous), so now able to adjust settings on field.
Old 01-15-2014, 03:27 PM   #28 (permalink)
I've just finished setting mine up. All working as should do electronics wise. Just need to tidy the cables, secure the esc and sat and start test flying. I intend to use my laptop to make adjustments via USB cable provided.
Anyone know how the failsafe button is supposed to work? I think it's the second tab on the software...
Old 01-15-2014, 03:32 PM   #29 (permalink)
Originally Posted by HLHAMNER View Post
AR7200BX
To be honest, I have two T450 Pro v2, one with AR7200BX, second with ZYX-S(ZYX-S2 now). The ZYX controlled, by my opinion, flies better!
Old 01-15-2014, 03:41 PM   #30 (permalink)
Move sticks on TX to positions which you want to have according to your opinion in case of signal lost and press Set failsafe button. ZYX should move servos and throttle signal for this remembered state if lose TX signal. You can check that, just switch your TX off after ZYX-S2 properly configured. DO NOT FORGET DISCONNECT MOTOR WIRES BEFORE this test! At least remove pinion or blades!
Old 01-15-2014, 04:06 PM   #31 (permalink)
That's cool! So what's a safe setting? Any suggestions? Just above mid stock on collective may be?
Old 01-15-2014, 05:43 PM   #32 (permalink)
There's no right answer here, but I set all my fail safes to zero throttle, collective at or slightly below 0°, cyclic and tail centered. Having collective a bit below 0 allows the possibility that a signal failure with the helicopter right side up and within a few degrees of horizontal might end up looking like an autorotation, therefore minimizing crash damage. But, of course if you're inverted when it happens it would be less pretty, that's why sticking close to 0° makes sense; then go a few degrees negative if most of your flying is upright, go closer to 0° if you fly a good mix of upright and inverted.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote Quick reply to this message
Old 01-15-2014, 06:06 PM   #33 (permalink)
Personnally, I go for a little bit of positive collective and zero throttle. My reason for this is, the more head speed you can wash off before the heli hits the grounds the better. Probably not the safest approach, however, as the heli could travel a little further.
Gaui X2 FES ZYX, Gaui X3 MB, Gaui X4 II VBar, Gaui X5 FES MB
250 DFC ZYX, 450 DFC Sport MB, ALZRC 450L Pro VBar, Devil 450 FAST VCTRC FBL
500E DFC Pro VBar, 500E SDC ZYX-S
KDS 550 VBar, 550E DHPS VBar, 550E DFC Pro VBar, 700E DFC HV iKon
beenflying is offline        Reply With Quote Quick reply to this message
Old 01-19-2014, 04:13 PM   #34 (permalink)
Still working through the settings time will tell...
Old 03-13-2014, 07:49 PM   #35 (permalink)
well i got mines to bind and the issues are amazing
i emailed this video to tarot as well
Tarot zyx s2 flybarless gyro if you dont use 1520us servos (6 min 15 sec)
Ama # 932491
Fun, Learning, Friendship, and Mutual Respect
wc_wickedclown is offline        Reply With Quote Quick reply to this message
Old 03-13-2014, 08:27 PM   #36 (permalink)
The first part looks like the collective/cyclic tail pre-compensation is doing something weird.
FYI, the thread on RCG has a Tarot customer service person (cannat) replying to issues with the S2.
Old 03-13-2014, 09:13 PM   #37 (permalink)
+1
pre-compensation is or should be off i have zeros there
and thank you ill look for him
Ama # 932491
Old 03-15-2014, 03:09 PM   #38 (permalink)
i messaged cannat days ago but he has not replied yet the ebay seller is sending me a 3rd
s2 gyro i feel sorry for his looses
here is another video with 1 tx and the zyx and a zyxs2 plugged in at the same time
you can see the s2 pre comp is disabled
i am still waiting on the tarot CEO to have a look at my vids but im sure he should already know about the issues with this gyro its all over the web
here is another zyx s2 video i am using 1 radio and i have a zyx and a s2 plugged into the pc you can see the monitor software shows on the s2 side the rudder monitor flickers .
you can also see the s2 has zero precomp
http://www.youtube.com/watch?v=h5wGWdbHVfE
Ama # 932491
Old 04-16-2014, 06:40 PM   #39 (permalink)
finally got my s2 figured out
you have to use 1520us cyclic servos
i am in love now
https://www.youtube.com/watch?v=ka3f_Ak7E8E
Tarot ZyX- S2 gyro Bad to the bone thank you tarot usa =wc= approved (5 min 24 sec)
did a field test but i blow out my oneway bearing
second field test blew out the one-way bearing zyx s2 fbl gyro exi tarot align 450 pro (2 min 52 sec)
Ama # 932491
Old 04-16-2014, 07:09 PM   #40 (permalink)
contact tarot usa
http://tarot-rc-heli.com/index.php?route=common/home
Ama # 932491
