Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 500/570
SAB Goblin 500/570 SAB Heli Division - Goblin 500/570 Helicopters
Like Tree6Likes
Old 03-27-2014, 08:05 AM   #1 (permalink)
Default Whats your Goblin 570 setup
Well don't know if I can get this started but I think we need a setup thread!!
Please designate 6s or 12s!
Please make a sticky?..
Guiwee is offline        Reply With Quote Quick reply to this message
Old 03-27-2014, 08:21 AM   #2 (permalink)
Well heres mine!
  • Flight Style: Big air,Mild 3d
  • FBL System: Ikon
  • Motor: Scorpion 4025-11000kv
  • Pinion: Stock 21t
  • Target Headspeed(s): 2200/2300/2400
  • ESC: Jive 100lv
  • Governor: Jive gov
  • BEC: Jive
  • RX Pack: none
  • Cyclic Servos: Bk full size
  • Tail Servo: see above
  • Main Blades: Rail 556s
  • Tail Blades: Rail 96mm
  • LiPos: Pulse 6s 5000mah 45c
  • Anything Else: Optipower ultra-guard 430 back-up (hear nothing but good things about this)
Old 03-27-2014, 08:26 AM   #3 (permalink)
mine will be
goblin 570 yellow/red
stock blades
compass 5026-540kv motor
kontronik jive 80hv with backup nimh
Align ds610s
Futaba bls251
mini vbar 5.3 pro with dsm2 sats
optipower 2700 x2
cupracing is offline        Reply With Quote Quick reply to this message
Old 03-27-2014, 08:46 AM   #4 (permalink)
- Yellow/Fluorescent Orange (either I am color blind, or everyone else is... Sure doesn't look red to me in person)
- Stock main and tail blades (for now)
- KDE-550XF-1200
- HeliJive 120
- bavarianDEMON 3SX
- Futaba BLS-451's and a BLS-256 powered by the Jive BEC
- OptiPower Ultra Guard
- Pulse Ultra 7S 4500's - Revolectrix 6S 5000's - Spyder 6S 4000's
- JLog 2.6 for full telemetry to Jeti DS-16 radio
Team - "Self Interests" -
Old 03-27-2014, 10:53 AM   #5 (permalink)
Well heres mine!
  • Goblin 570: Yellow/Red
  • Flight Style: Mild 3d (learning Hard 3d)
  • Tx: DX9
  • Rx: AR8000 with dsmX sat
  • FBL System: bavarianDEMON 3SX
  • Motor: KDE-550XF-1200
  • Pinion: 20T / 21T (havent decide)
  • Tail Pinion: 21T (recommended by Bert for lower HS < 2400)
  • Target Headspeed(s): 2000/2200/2300
  • ESC: Heli Jive 120+ HV
  • Governor: Jive Mode 4
  • BEC: WR Hercules super BEC / internal Heli Jive 120+ HV (have not decide)
  • RX Pack: None
  • Cyclic Servos: Torq BL9180
  • Tail Servo: Torq BL9188
  • Main Blades: Stock & Rail R-556
  • Tail Blades: Stock & Rail R-96
  • LiPos: Pulse 6s 4500mah 45c / ZIPPY Flightmax 5000mAh 6S1P 45C
Grittner is offline        Reply With Quote Quick reply to this message
Old 03-27-2014, 01:51 PM   #6 (permalink)
Nice would be to add the weight of your 570 ready to fly.
Jeti DC-16, Goblin 570, Protos Strech, Neuron, Accurc, Powerlab8v2
BorisFF is offline        Reply With Quote Quick reply to this message
Old 03-27-2014, 06:08 PM   #7 (permalink)
Mine:
  • Goblin 570: white/grey
  • Flight Style: big air/speed
  • Motor: Quantum 4125-560
  • Pinion: 24T
  • Tail Pinion: stock
  • Target Headspeed(s): 2200/2400/2600
  • ESC: CC 80HV
  • Governor: CC Set RPM
  • BEC: YEP 20A
  • RX Pack: none
  • Cyclic Servos: Savox 1267SG HV
  • Tail Servo: Savox 2272SG HV
  • Main Blades: Rail 556 - new Sab black line 1D
  • Tail Blades: KBDD White
  • LiPos: 12S Pulse 3000mah 45c / Turnigy 3000 40C / Revo 3300 - 40C
  • Weight: in some days...
Under construction, something could change on the road.
Someone of you made this for G500
It would be nice having one for G570
sescot is offline        Reply With Quote Quick reply to this message
Old 03-27-2014, 07:10 PM   #8 (permalink)
  • FBL System: ikon or vbar
  • Motor: Scorp 4025-1100
  • Pinion: 22T
  • Target Headspeed(s): 2400-ish
  • ESC: Heli Jive 120HV+
  • RX Pack: 2S LiPo
  • Cyclic Servos: BK 7001HV
  • Tail Servo: BK 7005HV
  • LiPos: X-Treme Power 5000mah 35C
Low speed, high drag
Otto Rotation is offline        Reply With Quote Quick reply to this message
Old 03-27-2014, 08:29 PM   #9 (permalink)
My Setup, she's a blast
~ Goblin 570: Yellow/Red
~ Flight Style: 3d and fast big air stuff
~ FBL System: The 'Bar
~ Motor: Scorp 4025-1100
~ Pinion: 21T (stock)
~ Tail Pulley: 21T
~ Target Headspeed(s): whatever 80% throttle curve is
~ ESC: Heli Jive 120
~ Governor: Mode 4 w/bail out
~ BEC: Heli Jive 120
~ RX Pack: 2/3AAA 4 celll NiMH as a buffer pack
~ Cyclic Servos: BLS451
~ Tail Servo: BLS256HV
~ Main Blades: Cyclone 555
~ Tail Blades: Stockkers for now
~ LiPos: 5000mAh 45-65C packs
~ Timer: 3:40
~ Weight: 93.5oz/2.65kg without flight pack
Landing with about 15-20% left in the packs
Keith
Goblin 700C Gasser -- Goblin 700C -- Goblin 570 -- Gaui NX4
#29
gcac399 is offline        Reply With Quote Quick reply to this message
Old 03-28-2014, 02:40 AM   #10 (permalink)
  • FBL System: Brain
  • Pinion: stock
  • Target Headspeed(s): whatever floats the boat
  • ESC: Master Mezon 120 RPM
  • BEC: Esc built-in
  • RX Pack: Scorpion Safeguard
  • Cyclic Servos: Futaba BLS 451
  • Tail Servo: Futaba BLS276SV
  • LiPos: Raiden 5300mah
He who shall be last, shall be sideways and smiling
Within is offline        Reply With Quote Quick reply to this message
Old 03-29-2014, 10:55 AM   #11 (permalink)
Goblin 570: Black/White/Silver
FBL System: Ikon or Vbar
Motor: Hyperion 4025-630 (will switch to Kontronik later)
Pinion: stock
Target Headspeed(s): 2500/2600
ESC: Helijive 120HV
BEC: Esc built-in
Cyclic Servos: BK
Tail Servo: BK
Main Blades: Stock
Tail Blades: Stock
LiPos: 12S 3000mah pulse
Weight: unknown, still building
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep.
alexmit is offline        Reply With Quote Quick reply to this message
Old 04-06-2014, 01:58 PM   #12 (permalink)
Goblin 570 Yellow
  • FBL System: Brain/Ikon
  • Motor: Quantum 4125-560kv (350 grs)
  • Pinion: Stock 21t
  • Tail pinion: 21t (upgrade, target rpm < 2400)
  • Target Headspeed(s): 2000/2300
  • ESC: YGE 90HV
  • Governor: Ikon
  • BEC: none
  • RX Pack: 2S Lipo 850mha 35C
  • Cyclic Servos: MKS BLS HV 950
  • Tail Servo: MKS BLS HV 980
  • LiPos: Dynogy 2 x 6S 3300 65C + straps + tray: 1070 grs
  • Rcv: JETI RSAT2
empty with stock blades aprox. 1700 grs
2590 grs without batteries
Total rdy to fly 3660 grs
Old 04-07-2014, 08:02 AM   #13 (permalink)
Which Quantum motor would be good for this Heli. Have one on my 500 and like how cool it runs. Also will the Jive 80 be enough? Or the 100 LV?
johnnyo7 is offline        Reply With Quote Quick reply to this message
Old 04-08-2014, 08:34 PM   #14 (permalink)
Default 570 Specs
Goblin 570: Red/yellow
Flight Style: big air/ mild 3d
Motor: KDE 550XF 1200-G3 (Monster)
FBL System: Vbar
Pinion: Stock
Tail Pinion: Stock
Target Headspeed(s): 2200/2350/2450
ESC: CC 130 Edge
Governor: Vbar
RX Pack: Pulse 2250
Cyclic Servos: BK Full size
Tail Servo: BK mini/full
Main Blades: Stock
Tail Blades: Stock
LiPos: 6S Thor 4400/5000/45c
Radio: Futaba 14sg
robertvizzo is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 12:23 PM   #15 (permalink)
Motor: Scorpion 4025 550KV
FBL System: Ikon
Pinion: Stock
Tail Pinion: Stock
ESC: CC 80HV Edge
Governor: Ikon
Main Blades: Stock
Tail Blades: Stock
LiPos: Turnigy 3000 40C 12S
Radio: DX8
Goblin 420 Ikon
Compass Warp 360 Ikon
RCHN# 229
weelee is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 06:55 PM   #16 (permalink)
What times are you all getting on 6c and 12 c. What to get one of these helis soon and what to be able to get 5+ mins fly time
Trex 700 DFC and FL All on Vbar
zelman is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 07:43 PM   #17 (permalink)
I could fly it for 5+ minutes if I backed off the hs and hover.... but that's just no fun Getting 3:40...see above for setup
Keith
Keith
#29
Old 04-09-2014, 07:52 PM   #18 (permalink)
Originally Posted by BorisFF View Post
Goblin 570 Yellow
  • Pinion: Stock 21t
  • ESC: YGE 90HV
  • Governor: Ikon
  • BEC: none
  • Rcv: JETI RSAT2
Boris...with the Quantum is 2300rpm's with a 21t at 100% or governed?
I forgot to pick up some different pinions.
Sent from my iPhone using Tapatalk - sorry for typos!!!
audacity is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 08:08 PM   #19 (permalink)
Keith
A little over 3 mins is over in no time. So if I went to 12c on 3300mah should get the 5+ mins
Old 04-13-2014, 08:46 AM   #20 (permalink)
YGE Gov 80% for 2300
