Gasser Helicopters Gasser Specific Discussion |
06-28-2015, 10:07 PM | #1 (permalink) |
Couple of more questions about gv1 with dx9
Guy's I can manage to get everything to work with changing the different head speeds with the flight mode switch and using aux 2 on the ar7200bx, but I would also like to get the on and off switch to work. Does this line plug into aux 3? If so what is the radio setup cause I can't get the switch to work on aux 3.
06-29-2015, 09:10 AM | #2 (permalink) |
On/off switch
It can plug into any channel that switches from the high side to the low side, as long as its over the middle point threshold it doesn't matter how much to the high or low side it goes.
Check your monitor screen and make sure that you have a switch assigned to aux3 channel and that its working. -=>Raja.
MA 1005, Hanson 270, 4717 flts, Spectra-g, Hanson 270, 3672 flts Whiplash-g V1-2, Hanson 300, 2235 flts, Whiplash-g V2, Hanson 300, 1552 flts Whiplash Turbine, TS 45i WSE, 296 flts Jewel on-board Generators, Miniature Aircraft Team Manager |
06-29-2015, 10:08 AM | #3 (permalink) | |
1. Assign a switch in Sys Setup/Channel Assignments 2. Use Digital Switch Setup also in Sys Steup 3. Use a P-mix in the Adjustment/Mix section. Does that help?
This is your brain on helicopters! Trex 700L, Trex 700N DFC HB gasser,Trex 700N V2 HB gasser, Trex 550X. Spirit or BD3SX |
06-29-2015, 06:54 PM | #4 (permalink) |
I will have another go tonight.
06-29-2015, 07:04 PM | #5 (permalink) |
If you simply assign a switch in setup/channel assign, the defaults for a 3-position switch are -100,0,+100 which should handle the on/off function.
DSS is nice because it lets you assign any three levels in any order on any switch. Before DS, only Gyro and Gov in the Adjust menu could do that. I think for your situation, a simple switch assignment is all you need.
07-01-2015, 01:56 AM | #6 (permalink) |
I gave up on the switch, as I am still breaking in the goblin I decided to just have idle up 2 on the gov, in the gv1 I set normal and idle up 1 to off for now. Once broken in I will leave normal to run on the curves and set the gov for 1 and 2.
