Go Back   HeliFreak > R/C Helicopter Support > KDS Helicopters General Discussion
KDS Helicopters General Discussion KDS Helicopters General Discussion
Old 04-12-2014, 10:30 PM   #21 (permalink)
Default TT
The alcohol trick is the best way to do it once they are in place they don't budge !!! I use that for all my TT assemblies and I have never had a problem .
JR Forza 700 Scorp Ultimate, castle 160 HV, JR 8917's, V-bar!!!
GAUI X5 ,Scorp 890 ,Castle edge 100, JR 8717 HV's, V-bar
FPV mini quad 250 racer . Sky-Hero mini FPV Camera ship
beetlespin8 is offline        Reply With Quote Quick reply to this message
Old 03-07-2015, 07:25 PM   #22 (permalink)
I'd rather jack off with sand paper than squeeze that damn tt in the boom.
snafu9241 is offline        Reply With Quote Quick reply to this message
Old 03-17-2015, 12:28 PM   #23 (permalink)
I'm having the same problem trying to jam the torque tube with the bearings into the boom. Is there a legitimate reason the fitment is so tight or is it crappy engineering/manufacturing? I tried both the alcohol and astro-glide trick last night, but still couldn't get the damn thing in there! Tonight I'll try the dremel tool trick from GimpyGolden to sand down some of the rubber damper. Would it kill them to make the damper easier to install (i.e. smaller)??
The end won't be for everyone.
The choice, to know, will be yours.
Skeezix is offline        Reply With Quote Quick reply to this message
Old 03-20-2015, 08:17 AM   #24 (permalink)
I just did the TT on my 7.2 and they're snug too. This time I did no sanding but used my trusty MolyKote 33 and once I got the Damper in the boom it slid home no problem.
Love this stuff, good for gears, spindles and now installing TT dampers.
http://www.amazon.com/s/ref=nb_sb_no...ds=molykote+33
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 03-23-2015, 08:21 AM   #25 (permalink)
Ive fought with this myself, Ive tryed many ways on how to get the TT in the boom...so i find this works for me...
I epoxy the bearing on and let them set for awhile after that i reach for the TRI-FLOW give the boom a lube job then i lube up the dampers, now on both sides of the damper their are ridges that are a lil more bigger then the boom it self so lube up the dampers and get the first ridge in and with you thumbs push the 2nd ridge down and in, do the same thing with the other two dampers works every time and its clean they wont get pushed off the bearing...good old TRI-FLOW
MSH USA Team pilot (Lozki) Protos Maxx V2,Protos 380, jeti DS-14
Lozki is offline        Reply With Quote Quick reply to this message
Old 03-23-2015, 10:56 AM   #26 (permalink)
I finally got it, but dang......can't they design a better part? This was disappointing on a kit so expensive, and touted to be such high quality. Never the less, I'm still looking forward to flying it.
Old 03-31-2015, 09:35 AM   #27 (permalink)
I used some silicone oil, alot of swearing and quite alot of shoving to get the 3 bearings into my TT without the rubber slipping off the bearings. It took me a good 5 hours and left my hands bruised
KDS Chase 360 // Agile 5.5 // Agile 7.2
SAB Goblin 380 // 630
ZeniethLily is offline        Reply With Quote Quick reply to this message
Old 03-31-2015, 04:02 PM   #28 (permalink)
Really, 5Hrs?
I did my 5.5 yesterday with the MolyKote 33 and got both bearings in on the first try.
And I'm a cripple. Didn't sand the rubbers down or anything.
Old 03-31-2015, 08:37 PM   #29 (permalink)
Originally Posted by GimpyGolden View Post
Really, 5Hrs?
Lmfao. "I'm a cripple"? I don't know your story, but your comment made me picture the "my germs" guy from scary movie trying to install this TT
which is a pain in the arse! I got my 7.2 and it had a weird vibe. Tore down the tail and I found that the rubbers had halfway slid off when he installed the boom. I pulled it all, soaked the rubbers with silicone oil, then swabbed the boom. Slowly, carefully and evenly applied pressure until they all slid into the boom and then just pushed the TT where it needed to be. No real drama, 10 minutes maybe. I mean, they were pretty tight but they weren't impossible to fit
Old 03-31-2015, 11:32 PM   #30 (permalink)
yes 5 hours, my agile 5.5 took me 5 minutes. not the 7.2 though.. the 3 stupid bearings kept taking turns having their rubber sleeves pop out while pushing them in real slow.. Then a friend ripped one of them and i had to wait a couple of hours for spares. What i've learnt from it : don't listen to everything everyone says and lube only the outside of the rubber.. if it gets into the inside its just gonna keep slipping off the bearing everytime you push it in.
And to note the difference between the 5.5 and 7.2 - that one extra bearing really does give you a hell of a time. Try it, you'll know what i mean.
Old 04-01-2015, 08:36 AM   #31 (permalink)
Yup cripple, not that guy but anyways... My story C6 Quadriplegic, see this thread
https://www.helifreak.com/showthread.php?t=561993
Agree,little lube on the rubbers and some in the end of the boom and you'll get er in.
I did my 7.2 a few weeks ago as well. I did have the rubber pop off twice doing it but after switching to the light grease it was much easier. Just have to work the damper in even then slide it home once it is seated in the end of the boom.
Next time maybe try a light grease and also grease the end of the boom fingers length in at least. I hope you get a method down that works for you cause that sounds pretty frustrating.
Hmmmm maybe a good topic for a Team Tip vid... I'll get on that soon.
Old 04-01-2015, 10:49 PM   #32 (permalink)
I found that greasing the inside of the tube down and the edges of the rubbers helped most, just avoid having any lubricant getting into the inside where the rubber sits into the bearing. As for pushing it in, you'll have to apply even pressure as you nudge the bearings into the tube .. slowly. I was rushing it and kept popping the rubber out of the bearings... lesson learnt.
Old 04-04-2015, 06:55 AM   #33 (permalink)
I am thinking about getting me a kit but is it not only to get a wood stick just thinner then the ID of the boom and push them in ?
The you should get even preasure on the sleeves and no preasure on the bearings.
Btw i love how the MD Helis have pre mounted all bearings in the booms, had been great if more providers did that.
Rasmus Fauske
MD700 v2 for F3C, MD 700 v2 for 3D, M5-Sport, MD600 and a few Oxys and a MSH P380 Evo
rfauske is offline        Reply With Quote Quick reply to this message
Old 04-04-2015, 07:52 AM   #34 (permalink)
You could do that I am sure but manual specifies epoxying the bearings to the shaft.
Could be the only reason for that is to facilitate installation.
Next time I build one up I'll try your suggested method and see if there are and 'side effects'. Hopefully it isn't for a while cause that'll mean I dumped it
Maybe I'll take one for the team, buy the bit's and build up a spare boom w/ TT ready to go. Not like I'll never need it.
Old 04-19-2015, 10:02 PM   #35 (permalink)
I take the tube the torque tube plastic case that it comes in, I have marked at the three distances put a little lube on the rubber bearing mounts fit them in the boom by hand first then slide them down with the tube to the marks on it. then slide torque tube in glue ends and pin in and your done. this was the suggestion of one of our team members and did 4 booms like that this week. I have also done that in the past on other helis.
Kds models USA team pilot
Sky-Hero
Team jramericas.com
Spin blades field rep
Jesse is offline        Reply With Quote Quick reply to this message
Old 04-20-2015, 10:49 PM   #36 (permalink)
Just bevel the inside edge of the boom and lube boom and bearing holders with silicone grease. Bearing slide in perfect.
UPSDOC is offline        Reply With Quote Quick reply to this message
