Kontronik Drives Jazz and Jive ESC's and other Kontronik equipment support |
01-15-2012, 12:28 AM | #41 (permalink) |
Any new news on this?
Avant RC Scorpion Power Systems ThunderPower RC Kontronik Drives |
01-20-2012, 01:13 PM | #42 (permalink) |
What would be the flight differences between both modes. Would you loose performance in KSA?
"Sort your head out and fly with your heart" Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc, Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251 |
01-20-2012, 09:49 PM | #43 (permalink) |
I don't know for sure but, I would venture to guess that in non-KSA, where the Jive is not dynamically adjusting to the motor, you're going to be much closer to 100% efficiency. Then again, I'd gladly accept a 5-10% performance degradation that was always there over a 100% performance degradation that showed up at the most inopportune times!
John Compass Knight 600E, Blade 450, Blade 400, Blade SR, Blade mCPx, Blade 120, Blade mSR, Blade mCX, Blade CX2 |
01-20-2012, 11:03 PM | #44 (permalink) | |
But it's kind of arbitrary as the reason for using KSA in some cases is that the motor produce more power and EMF spikes so the controller cannot handle it. Meaning, if you REALLY need that last x% power, your setup from start is not optional, you should have chosen differently. |
01-21-2012, 03:25 AM | #45 (permalink) |
The reason I ask is my motor has low resistance issues with my Jive 100+LV. I would have chosen differently but KDE told me the two were compatible when I asked so I bought their KDE/NEU when they first came out (now discontinued). I have problems arming the esc at times and have never tried the KSA mode. I remember someone else having the same issues with this motor who tried KSA but didn't solve the problem. Worth a try I guess as long as there are no adverse effects or damage to the motor/ESC?
"Sort your head out and fly with your heart" Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc, Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251 Last edited by markleyland; 01-21-2012 at 10:16 AM.. |
02-05-2012, 10:54 AM | #47 (permalink) | |
i was asking few weeks ago about v-bar gov + helijive + 4525-520 that i have for my goblin and i want to use... that was what you said... so... How was that telephone call? any details about the problem? and is this problem related to helijive or is it the same with all ESCs? Thanks for your time again Toni |
02-05-2012, 11:10 AM | #48 (permalink) |
They really did not have any info on the topic, sorry.
what I talk about above is Mode 8 on HeliJive and should not occur on other Jives. |
02-06-2012, 03:11 AM | #49 (permalink) | |
if i get some other brand esc (scorpion comander etc..) is there the same problem waiting for me? i have also read about align 700MX motors that has burned with that setup so is it related to motor choice at all? sorry for bombing you with questions but i have a very expensive setup waiting and i dont want to kill it for not knowing something... v-bar gov still seem very intresting if it works... -Toni |
02-06-2012, 03:38 AM | #50 (permalink) | |
02-08-2012, 06:31 PM | #52 (permalink) | |
Thanks for the warning. This is the first time iVe heard of this. I have only 1 Kontronik ESC so far and I dont frequent this site. What happens if you have damaged your ESC by doing so and not knowing about it? Will Kontronik still honour their warranty? I will read my intructions manual again regarding whether this warning is included in the intructions manual. If its not then it should be included in the front page i reckon. Thanks
LOGO 600se, Scorp 5020-450,HeliJive 120, V-Bar Blue FS LOGO 500se, Scorp 4025-1100 6s on 550 Blades PROTOS 500 Stretched , Scorp, YGE, Beast-X (Retired) Trex 600 Npro FBL 3GX ,Trex 550 FBL 3GX ,Trex 450 FBL 3GX-X2,Trex 250 FBL 3G |
02-08-2012, 10:09 PM | #53 (permalink) | |
02-08-2012, 10:22 PM | #54 (permalink) | |
02-08-2012, 10:24 PM | #55 (permalink) | |
No, as long as motor is driven it's even more safe than anything else. (that's why when using VBar you should run "Idle at AR") The problem have potential when a) ESC has stopped driving the motor (turn off) b) Motor still spinning but nothing drives it. c) ESC tries to restart the motor. It's a very short timeframe, drag from main gear and pinion usually makes this short, and with lighter motors even more so, but if you have a very big motor like a Scorpion 50xx series etc, it takes a little while before motor stops. |
02-08-2012, 10:27 PM | #56 (permalink) |
Gotcha. Just wanted to make sure. I didn't want people cooking their ESCs following advice that I had given. Good way to get a BAD reputation!
02-08-2012, 11:06 PM | #57 (permalink) | |
