Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > SR
SR Blade Helicopters (eFlite) SR
Old 03-11-2010, 10:33 AM   #1 (permalink)
Lightbulb SR battery ?
I have a larger battery from my P-51 that gets the CG, right on, and fits good with the canopy as I had to shove stock batt all the way forward and still not quite right. Deal is, this batt is1800mAhs, but 11.1Vs. It also has dean connectors, but the same balancing plug.Is there a pluggable transistion lead that will eliminate soldering...someone has to know what I'm talking about.... Or is the 1800mAh too much ?? Female dean to stock female ..
Skyranger is offline        Reply With Quote Quick reply to this message
Old 03-11-2010, 10:48 AM   #2 (permalink)
I bought some G-Force 3s Lipo's 30c Discharge, they weigh in at 92gm and the stock lipo 2s is 82gm. 10 gm difference balances it out nicely. You should be ok just means you have a longer flight time but I would watch for motor overheating ?
Blade SR - Stretch Carbon Tail Boom
EXI 450 Carbon SE
Futaba T7C 2.4 FASST
Southern Heart Soaps Lotions & Potions
hueman09 is offline        Reply With Quote Quick reply to this message
Old 03-11-2010, 10:59 AM   #3 (permalink)
That's a non-issue. Even with a higher-discharge battery or higher-capacity battery, you're not taxing the brushless motor at all on this bird. I'd be glad to show an IR photo from the brushless motor if you require, but I socked a 30C 1300mAh LiPo on the front of this bird, and the motor was barely hand-warm at the end.
Fly Cheap. Fly Hard. Fly Daily.
redgiki is offline        Reply With Quote Quick reply to this message
Old 03-11-2010, 12:44 PM   #4 (permalink)
Question adapter
is there one out there that would be willing to make me an adapter for my SR (not,stock) battery ? Male Deansplug to female stock E-Flight plug..? Just let me know your price..Dave...
Old 03-11-2010, 01:09 PM   #5 (permalink)
Wink
They're out there, but everyone is back ordered that I saw. I converted everything I own to APPs (Anderson Power Poles), including my charger. Bit bulkier (not heavier), but excellent connection and easy to connect/disconnect. These are crimp connections: no soldering. Crimper is pricey: $39.95, but hey, you only have to buy it once ! So I don't even look at what the battery comes with: 2 minute conversion and it's done !
Happy Flying,
Jake
Gyrene is offline        Reply With Quote Quick reply to this message
Old 03-11-2010, 01:18 PM   #6 (permalink)
Smile
Anderson Power Pole Pics
Quick and easy ! Love 'em !!
ID:	144579   Click image for larger version
ID:	144580   Click image for larger version
Happy Flying,
Jake
Old 03-11-2010, 01:50 PM   #7 (permalink)
Just so you know, the stock connector is a JST connector. You should be able to find some at your LHS, they're quite common in the 2S LiPo world.
bassplayinDude is offline        Reply With Quote Quick reply to this message
Old 03-11-2010, 02:10 PM   #8 (permalink)
Does anyone know where I can buy a connector that has a male deans plug and a female JTS plug.. Thanks...Dave
Old 03-11-2010, 02:16 PM   #9 (permalink)
Is this what you need?
Old 03-11-2010, 06:28 PM   #10 (permalink)
Default SR Aftermarket battery Options
Hey Helifreaks
Looking to compile a list w/ links for the best batteries everyone is using for the new tasty SR.
here are a few i found at hobbyking to get the list started, Plus I included the ones folks listed on this thread here:
https://www.helifreak.com/showthread.php?t=193607
Please add your good battery finds
The complete list could be stickied for easy reference...
First, as a baseline:
The stock Battery: 1000mAh 3S 11.1V 15C LiPo 20AWG JST Balancer Dimensions/ weight: 3 1/4" X 1" X 5/8" - 2.7 OZ
83mm X 26mm X 16mm -76.5 g
LHS price in Denver, CO $26.99 + TAX OUCH!!!!
BLADE SR BATTERY LIST:
Rhino 1050mAh 3S 11.1v 40C Lipoly Pack - $14.95 http://www.hobbyking.com/hobbycity/s...idProduct=9608
Capacity : 1050mAh
Constant discharge: 40C
Burst rate: 50C (15sec)
Configuration : 3S 11.1v
Pack size: 69x34x18mm
Weight : 103g
ZIPPY Flightmax 1000mAh 3S1P 25C - $9.99
http://www.hobbyking.com/hobbycity/s...idProduct=6470
Capacity: 1000mAh
Voltage: 3S1P / 3 Cell / 11.1v
Discharge: 25C Constant / 35C Burst
Weight: 90g (including wire, plug & shrink wrap)
Dimensions: 73x36x18mm
Balance Plug: JST-XH
Rhino 1050mAh 3S 11.1v 20C Lipoly Pack -$7.19
http://www.hobbyking.com/hobbycity/s...idProduct=7309
Capacity : 1050mAh
Constant discharge: 20C
Burst rate: 30C (15sec)
Pack size: 73x18x35mm
Weight : 100.3g
GForce 30C 1000mAh 3S 11.1V LiPO - $12.99
http://www.valuehobby.com/product_de...=8&item_id=111
1000mAh Capacity
3S - 11.1 Volts - 30C Discharge
Discharge Rate of 30 amps
68mm X 36mm X 19mm (2.66in X 1.42in X 0.75in)
93 grams (3.3oz)
Perfect for electric helicopters such as Honeybee King
Comes with Align/E-Flite balancing taps standard
Dean's Ultra connector installed
30 Day Money Back Guarantee
CX3-Living room flier B400 ULTRA -Sonix Head & Tail/ CF Frame,Boom & Fins/ GY520 w/9257 / 3x HS65MG /Ice Lite 50A / 440H / 11T pinion/Trex550E-V1 & DX8i
Twistfish is offline        Reply With Quote Quick reply to this message
Old 03-11-2010, 06:56 PM   #11 (permalink)
Well that is what I was thinking would or should be the case but new as I am I didn't want to "overspeak". Thanks for confirming. My thinking was thus, the 3900kv BL is only going to draw so many amps regardless so any battery that is capable of providing more will only have a longer service life since it won't heat up nearly as much, hence longer batt life.
EXI 450 Carbon SE
Old 03-11-2010, 06:59 PM   #12 (permalink)
Originally Posted by Twistfish View Post
Hey Helifreaks
Capacity : 1050mAh
Weight : 103g
Capacity: 1000mAh
Capacity : 1050mAh
Weight : 100.3g
1000mAh Capacity
93 grams (3.3oz)
I chose the Value Hobby 3s because they use a air baffle separator between the cells to aid in cooling. Have only yet to do spool ups in the house due to rain so can speak to the difference in the batt from stock but expect from spool ups that it will def outperform.
EXI 450 Carbon SE
Old 03-11-2010, 07:03 PM   #13 (permalink)
I just ordered some JST male leads and took off the deans connectors. I use a jig and have a Weller ML500MP butane solder tool (it's the bomb), two mintues and i'm in business.
U send em to me with shipping paid both ways and all parts I'll do it for free but If you are near a LHS I suspect they will do it for ya cheap esp if you buy from them.
EXI 450 Carbon SE
Old 03-11-2010, 07:38 PM   #14 (permalink)
Hey Helifreaks
Capacity : 1050mAh
Weight : 103g
Capacity: 1000mAh
Capacity : 1050mAh
Weight : 100.3g
1000mAh Capacity
93 grams (3.3oz)
I've been looking at all of theses. Problems is that all theses batteries are out of stock!
BXC2 ALUM UPGRADES
BLADE SR MCPX V2 B300X
keidoug is offline        Reply With Quote Quick reply to this message
Old 03-11-2010, 08:53 PM   #15 (permalink)
Gyrene and I must have gotten the last of the G-Forces.....Ooops
EXI 450 Carbon SE
Old 03-11-2010, 11:50 PM   #16 (permalink)
Turnigy 1000mAh 20C back in stock. 111 of them available.
http://www.hobbycity.com/hobbycity/s...idProduct=9163
Ivan
9sec240 is offline        Reply With Quote Quick reply to this message
Old 03-12-2010, 01:20 PM   #17 (permalink)
Default Updated battery list- post your finds here
Here is the updated battery list.
Keep posting your good battery finds here
BLADE SR BATTERY LIST // updated 3/12/2010
Capacity : 1050mAh
Weight : 103g
(added 3/12/2010)
Rhino 1250mAh 3S 11.1v 30C Lipoly Pack - $15.95
http://www.hobbyking.com/hobbycity/s...idProduct=9323
Capacity : 1250mAh
Constant discharge: 30C
Burst rate: 40C (15sec)
Pack size: 99x34x17mm
Weight : 113g
1000mAh Capacity
93 grams (3.3oz)
(Added 3/12/2010)
Turnigy 1000mAh 3S 30C Lipo Pack - $9.99
http://www.hobbyking.com/hobbycity/s...idProduct=9491
Minimum Capacity: 1000mAh
Configuration: 3S1P / 11.1v / 3Cell
Constant Discharge: 30C
Peak Discharge (10sec): 40C
Pack Weight: 93g
Pack Size: 73 x 35 x 19mm
Charge Plug: JST-XH
Discharge plug: XT60
Capacity: 1000mAh
(added 3/12/2010)
Turnigy 1000mAh 3S 25C Lipo Pack - $8.29
http://www.hobbyking.com/hobbycity/s...idProduct=9164
Constant Discharge: 25C
Peak Discharge (10sec): 30C
Pack Weight: 94g
Pack Size: 73 x 35 x 14mm
Charge Plug: JST-XH
(added 3/12/2010)
Rhino 1250mAh 31P 20C Lipoly Pack - $9.99
http://www.hobbyking.com/hobbycity/s...idProduct=7343
Capacity : 1250mAh
Pack size: 90x35x18mm
Weight : 116g
(added 3/12/2010)
Turnigy 1000mAh 3S 20C Lipo Pack - $5.49
Constant Discharge: 20C
Pack Weight: 87g
Pack Size: 73 x 35 x 12mm
Charge Plug: JST-XH
Capacity : 1050mAh
Weight : 100.3g
Old 03-12-2010, 01:25 PM   #18 (permalink)
Smile
Not anymore !! Stock shows as a -9
Hope they gave you a commisiion on that link 9sec !
Happy Flying,
Jake
Old 03-14-2010, 09:24 PM   #19 (permalink)
Default Keep the Battery finds Comin'..
BUMP!
I read somewhere in the SR forum that someone had tried out a 1300mah battery on the SR with positive results.
If you are out there reading this, please post your battery specs here so we can all find comparable batteries and post our best finds here, for all to enjoy.
Someone want to stickey this thread??
BLADE SR BATTERY LIST // updated 3/14/2010
Capacity : 1050mAh
Weight : 103g
(added 3/12/2010)
Capacity : 1250mAh
Weight : 113g
1000mAh Capacity
93 grams (3.3oz)
(Added 3/12/2010)
Pack Weight: 93g
Charge Plug: JST-XH
Capacity: 1000mAh
(added 3/12/2010)
Pack Weight: 94g
Charge Plug: JST-XH
(added 3/14/2010)
Smallsize/hobbyland 1300Mah 3S 25C - $ ?
http://shop.smallsize.no/product_inf...fc601943efb4b0
72x34x21mm, 104gr
(added 3/12/2010)
Capacity : 1250mAh
Weight : 116g
(added 3/12/2010)
Pack Weight: 87g
Charge Plug: JST-XH
Capacity : 1050mAh
Weight : 100.3g
Old 03-14-2010, 10:44 PM   #20 (permalink)
What a shame all these batteries are out of stock except the one thats quite heavy.
DustinT is offline        Reply With Quote Quick reply to this message
