Duralite Duralite Battery Li-Ion Li-Mn Chargers Support Forum |
08-02-2007, 06:25 PM | #1 (permalink) |
Excessive voltage drain?, charging problem?
Hey Freaks,
I recently purchased the Duralite Plus voltage regulator (w/ heavy duty switch). Currently, I've charge it about a dozen times. Yesterday, before my first flight I checked the voltage and it wasn't at it's normal 8.2 volts (7.7 w/ 1 amp load) it was a bit lower 8.0 volts (7.4 w/ load). This was strange because I had charged it the evening before and normally read higher voltages the next day. Nonetheless, I flew and checked it each flight and everything seemed fine. I charged the pack again, however after six hours the pack was still charging. I took it off charge and checked the voltage and it read 8.28 volts (7.75 under load). I waited 8 hours and rechecked the pack and it reads 8.08 volts (7.6 w/ load). This seems like an excessive voltage drain for sitting unused by itself. (please note that I have the switch wired correctly) Now, I have the pack back on charge (remember it was already at 8.08 volts) and it's been on the charger for 3 hours and still has not completed it's charge cycle. Any suggestions would be appreciated. Thanks in advance, Chris
MA Stratus 90, OS C-Spec (x2) T-Rex 450 SE (x2) T-Rex 600 Rappy 50 Spektrum |
