Go Back   HeliFreak > R/C Electronics Support > bavarianDEMON/HeliCommand
bavarianDEMON/HeliCommand Factory Sponsored Bavarian DEMON and HeliCommand Support
Like Tree1Likes
Old 09-10-2014, 05:45 AM   #141 (permalink)
Default all the video time is much appreciated Seasick78
I can understand just how much time it takes to get the videos completed - it is so much help to those of us that haven't got the information in our heads to set up this little sucker !!
TerryRoche is offline        Reply With Quote Quick reply to this message
Old 09-18-2014, 09:53 AM   #142 (permalink)
Hi Guys
Can someone help me ??
I know it might sound silly, but is there a video showing the correct order to connect the leads between the receiver and the 3SX unit ?? I use a standard 8 channel futaba receiver and a 10C transmitter. I'm used to only connecting one gyro/tail gain lead to channel 5 on the rx, but the Demon 3SX has two gain leads and I'm not sure where the second lead should plug in ??
HELP !!!!!
Garry
Logo 600SE/Uvular Electric with Microbeast
Rave Ballistic Electric with Microbeast "Get Outa Here !!"
Logo 690SX with Demon 3SX
SAB Goblin 500 with Microbeast
Garry Bagridge is offline        Reply With Quote Quick reply to this message
Old 12-20-2014, 12:11 PM   #143 (permalink)
Need help, 36% is a good spot for my head gain. How do I save that on the pic setup program so I can remove it from RD knob?
Protos 380 NEO x2
Oxy 2
Goblin Fireball
norstaroption is online now        Reply With Quote Quick reply to this message
Old 12-21-2014, 05:41 AM   #144 (permalink)
Set 36% as the default in the BD software
With my pilot skills I have no choice but to become a good mechanic.
Smith T is offline        Reply With Quote Quick reply to this message
Old 05-03-2015, 06:00 PM   #145 (permalink)
Originally Posted by Sonixs View Post
I configured my gain at the highest head speed and then tested it running my two lower speeds...no issue. I'm no smack pilot but the 3SX handles anything I throw at it from FFF to Big Air aerobatics and some mild 3D (as I'm only starting to venture into this).
The only gain that you'll have to change is going to be your tail gain, specifically when you get your TDR into some serious speeds...also dependent on your tail blade size.
Hi,
I installed a 3SX on my 180 CFX. I have seen the tail wobbling. I am not sure how to see the head moving so I can just the head gain? What should I look for ?
proy is online now        Reply With Quote Quick reply to this message
Old 05-03-2015, 08:20 PM   #146 (permalink)
CHC Benefactor
Originally Posted by proy View Post
Hi,
If the head moves off axis from your input then you adjust the head gain. For the tail wobbling that would be tail gain adjustment required. Sounds like you need to turn it down. To do that live, you need to ensure the right channel in the Tx is set to tail gain and link that to a variable knob. Adjust it in flight till the wobbles go away and then plug it back into the 3SX software to find the value of tail gain achieved. At this point you can then lock in the tail gain.
Old 03-13-2017, 08:45 AM   #147 (permalink)
Hi There,
Thanks so much for the informative Vids. I could not find any useful vids on this for 3SX specifically and found this is pretty much the same interface as the new one. Cheers
Westy's You Tube How To Guides -
==> http://www.youtube.com/user/rent2ownnz/videos <==
Gravity has a Great sense of Reality when your Wallet is concerned.
Kiwi-heli-nut is offline        Reply With Quote Quick reply to this message
Old 03-14-2017, 09:15 PM   #148 (permalink)
Originally Posted by Kiwi-heli-nut View Post
Hi There,
My pleasure.
Old 04-03-2017, 10:45 PM   #149 (permalink)
Hello, I am currently setting up this gyro. Should i be starting with my head gain on the left or right side of the bar at 50% or 0%. I have it on a 3 way switch being -50%, 0%,and 50%. Im a little nervous for the first hover and not sure how much these effect the control of it. As for the tail i think im safe to try it at 50% on normal mode, ( The values in my radio dont line up with the values on the program -So am i safe adjusting everything to the numbers on the program) Thanks in advanced!.
ktmdiesel is offline        Reply With Quote Quick reply to this message
Old 04-03-2017, 11:21 PM   #150 (permalink)
I did not play with mine and it hovers and flys well at 55 head gain
Old 04-03-2017, 11:27 PM   #151 (permalink)
If you are planning to run Rescue mode. in the 7, Horizon TAB
Tune you .. Col Pitch Travel - only to be used in Rescue dwon to 4 and work up from there as the standard 7 is really agressive
Old 04-04-2017, 12:20 AM   #152 (permalink)
So did you have the gain set to a switch or just 55% automatically
Sent from my SM-G930W8 using Tapatalk
lukeristau is offline        Reply With Quote Quick reply to this message
Old 04-04-2017, 12:25 AM   #153 (permalink)
just left head gain alone .... worked fine on My goblin 630.
As for the Tain gain .... started at 55 and used my trim switch to tune it and still have to set it into the FBL controller yet to disable my switch once figure is transfered.
Old 04-04-2017, 01:11 AM   #154 (permalink)
Okay so on the menu where you set your end points. Was the head gain at 0? And the rigid menu the gain set to 55?
Old 04-04-2017, 03:25 AM   #155 (permalink)
I did not zero the end points on the Head Gain ....
The Software will not let your progress (Continue button does not go live) to any more steps in the wizard until the important items are addressed... it was wanting absolute Zero for:
Aileron
Tail
Elevator
Pitch
Tail Gyro
everything else it seems to let you continue, So I did .
Once it is all Zeroed in your subs on your TX. and all your channels get 100%... you are good to go.
Old 05-03-2017, 10:49 AM   #156 (permalink)
Originally Posted by Seasick78 View Post
I'm seriously considering doing something like this. The only problem is that I would have to remove mine from my Goblin in order to properly show a step by step video. I hate to rip mine apart as I do not have anything other than a Nano to fly when my 630 is out of service.
I'll continue to ponder the idea though. If someone wants to send a doner model I'd be all over it.
Could it be an idea to do a full explanation video with just some pictures of the Bavarian Deamon, with some arrows to show where you mean?
The pc software and explanation of what all the tabs and the tings in the tab would be so amazing for me (for so many others as well)
Sent fra min LON-L29 via Tapatalk
TheDominator is offline        Reply With Quote Quick reply to this message
Old 05-03-2017, 11:06 AM   #157 (permalink)
I wish somebody could to some videos like "SEA.." on the spektrum DX9 black edition.
And if somebody could explain a few things to me about the tail gain, and the head gain.. It would be awesome.
Also. On my goblin 380, when I input aileron both right and left. The helicopter kinda shivers a little when I stop aileron input.. Why is this? To high or low gain? 😳
Old 05-03-2017, 12:50 PM   #158 (permalink)
Hi There .... i did part one a little while ago...
3SX Bavarian Demon Series Complete Guide Part 1 of 2 (20 min 9 sec)
here is assigning the rescue mode switches I did
DX9 SPEKTRUM TRANSMITTER - Bavarian Demon 3SX Assigning switches for RESCUE MODE (3 min 24 sec)
Old 06-27-2017, 04:09 PM   #159 (permalink)
be awesome if you could do one of the Westy's how to for the Axon.
#572, a few big Goblins,Bavarian Demon, Xnova, KDE,Scorpion,BK Servos,MKS,Protec, Kontronik, HobbyWing, Synergy N7, OMPHobby M2 V2
Blackline is offline        Reply With Quote Quick reply to this message
Old 07-28-2017, 04:44 AM   #160 (permalink)
Just as a little update: finally, we are starting to get some videos done, step by step.
Latest in September we will start putting them up to our YouTube channel, and a link on the webpage. You will surely not miss it.
The goal is to get all the main setup steps for CORTEXpro and AXON on video, as well as some additional feature and how-to videos.
Of course you are also welcome to let us know what you want to see. But please, just to mention this right away: time is very limited, so do not expect everything to be videoed within an hour or day. This takes time, and there are shows and all the main business around the vids....unfortunately
So be patient with us, but we are on it. A first impression to be out soon...
Joachim
CAPTRON Electronic GmbH
- bavarianDEMON Support, Product & Sales Manager -
DEMONjoe is offline        Reply With Quote Quick reply to this message
