Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum |
08-23-2012, 12:20 PM | #61 (permalink) |
Hey there.
This is why I'm gonna fix those batteries. I fly every day with every model I own on the 14mz. I'm on vacation until the 28th, I ordered batteries that will add up to 3600 MAh, similar to those first discussed in this thread. No clue why the original guys dropped the work I guess they just bought new futaba batteries.
I'll take one of my bad batteries and use the pin hole contacts. The new batteries I think come with some charging electronics also. I'll post my findings hopefully next week. Thanks for the interest, talk to you guy soon!
OMP M1, M2, 180cfx, 180Fusion, 400 FBL-6S, 450x, Mostro 700, Goblin 500, 32MZ Spectrum Module wired through training port. |
08-27-2012, 03:21 PM | #62 (permalink) |
Really interested in how you get on, please post some photos etc.
09-01-2012, 04:05 AM | #63 (permalink) | |
Sorry to hijack this and I know its been a long thread but I checked it and did not find the reply on this. Is it possible to power the 14mz via charging port? I know its always suggested to power down tx when charging. Thanks. |
09-02-2012, 09:51 AM | #64 (permalink) |
I have the new battery
I have the new 1800 li-on batteries just need to solder them up. Probably tonight or tomorrow I'll see if i have a cheap alternative solution for more power.
I completely forgot about the charge plug, I'll test that too this evening with an external battery.
09-02-2012, 07:30 PM | #65 (permalink) |
Awesome looking forward to your photo and result. Just in case I tried to cut in half a cheap knock-off and remove the batt and board. But the charge plug would be a great way to plug in external batts. Either way your mod looks promising to extend flying time
09-03-2012, 10:29 AM | #66 (permalink) |
We need pics please..
Kasama Srimok 90: JR8917HV all round | YS91SR | Hatori 946 | Spartan Quark | BLS251 http://nitro-magic.blogspot.com |
09-03-2012, 10:34 AM | #67 (permalink) |
Hello, can you post us some pics on this DIY? Thanks..
09-04-2012, 10:31 AM | #68 (permalink) |
Requested pics...
For some reason I didn't get a pic of the wires inside but all I did was solder the leads to the connector pins inside the gutted battery case and drilled an access hole in the battery case for the wires to come out. I made NO mods to the radio whatsoever.
Rotormast V-22 Osprey, 2 450 Clones, BL P-51, Micro P51, Stryker, 2 Vapors, Last edited by hoot; 09-06-2012 at 07:39 PM.. |
09-04-2012, 08:46 PM | #69 (permalink) |
Thanks Sire for the pics..!! Superstar..!! Time for me to "operate" the F570.
09-05-2012, 08:23 AM | #70 (permalink) |
Nice
I soldered up the 1800 mah cells last night. Spent a good few hours making sure all the connections and balance plug were good. Taped the wires down, shrunk wrapped unit, go to the charger with the little beauty thinking now I can show you guys a nice internal solution and the charger starts beeping! Ahhhhhhh dead cell. Piece of junk all that and a dead cell. I'm off to complain to the seller.
Nice external solution though, more than enough options and power when you mount the cells on the back.
09-06-2012, 05:58 PM | #71 (permalink) |
Sorry to hear 'bout your tx cells. Was looking forward to your results specially charging port.
This is how I currently have my tx batts. |
09-07-2012, 10:49 AM | #72 (permalink) |
Ordering new batteries!
Not gonna give up, ordering new ones.
Where did you get that rig for the back of the transmitter? It's perfect for hidding the battery if you run external. Also the charge port plug of course is smaller than a regular servo or balance port plug so I'm looking for a small adaptor that fits. I'm guessing that Futaba made this plug custom and very small for its charger so we wouldn't get the idea of playing with it. Eitherway still plugging away, the cells I orders fit perfect inside and if there 1800 MAh times 2 (3600) then should be more than the 2200 stock we have.
09-07-2012, 11:29 AM | #73 (permalink) | |
Now with my battery on the outside, the charging plug is right there and standard.
Rotormast V-22 Osprey, 2 450 Clones, BL P-51, Micro P51, Stryker, 2 Vapors, |
09-07-2012, 06:21 PM | #74 (permalink) |
Its a Secraft TX tray, the batts are stuck with velcro to the tray and sits well between tx module and Battery door of 14mz
09-10-2012, 03:22 PM | #75 (permalink) | |
09-12-2012, 11:43 AM | #76 (permalink) |
correction
Yes sorry each cell is 3400 when coupled in series. I forgot they are both 3400 and voltage is doubled not MAh. So it ends up to be a 2 cell 7.4V battery.
Dimentions of the bay looks like it will hold 70mm by 20mm max. These cells are 65mm by 18mm. I don't plan on using the electronics from a regular battery seems it is used for charging of the cells, maybe balancing. 2mm female plugs, slide onto the internal pegs quite well, so all we need is to shrink wrap the batteries do the soldering and charge them up. New batteries should be here next week. I'm so frusterated at how long it takes to order!
10-17-2012, 10:00 AM | #77 (permalink) |
I ordered two of the Duracell DR5 batteries and they are working very well in my 12Z. I can get at least two hours of ON time. They are rated at 2100 Mah and I cycled them on my PL8 and came out at 1900 Mah. . I also got one of these camcorder chargers for $5 off of Amazon. The charger can be powered directly off either 12V or 120VAC. There are two thumb grips where you can slide off the part the holds the battery and has the banana plugs. Remove the four little screws and you can solder in your own connector to fast charge the battery as a 2S Li-Ion (unbalanced) on your field charger. . If I'm planning an all-day flying session, I keep one in the charger, and one in the Tx. . |
10-19-2012, 07:19 AM | #78 (permalink) |
I think you will find anything under 2000 mah doesn't hold up long enough. Remember, you don't get to use all of it before the low capacity beep kicks in.
10-19-2012, 12:43 PM | #79 (permalink) | |
Yes, that's why I keep one in the charger and one in the Tx and swap out thru the day. Its a "kludge" solution until I can get the 2600 Mah Li-Ions installed in the old Sanyo cases and see how they work. . I don't think Futaba is going to help us in this area, so it'll be a project over the winter hibernation season. . |
