Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 03-15-2013, 01:23 PM   #61 (permalink)
Originally Posted by Dylwad View Post
Can't use the stock tail blade on the 8000 Kv.
Is the 8000kv motor usable on the nano?
Why can't the stock blade be used?
Thanks,
BR
born ready is offline        Reply With Quote Quick reply to this message
Old 03-15-2013, 01:27 PM   #62 (permalink)
Thanks,
BR
Won't fit for starters.
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
NCcraig is offline        Reply With Quote Quick reply to this message
Old 03-15-2013, 01:37 PM   #63 (permalink)
Craig! Good reason.
What can that HP02T be used for?
Thanks,
Old 03-15-2013, 01:49 PM   #64 (permalink)
Craig! Good reason.
Thanks,
I have it on my BL nano running a V2 tail blade. I have heard others having good luck with KBDD tail blades also.
Team Newb pilot
Old 03-15-2013, 02:18 PM   #65 (permalink)
Wow! I've always considered the V2 blade as the stock blade.
I'm looking forward to using this motor on both Nano and MSR X.
I sure appreciate your help.
Thanks.
Old 03-16-2013, 11:38 AM   #66 (permalink)
Have you tried the KBDD tail blade yourself? I would very much like to know how it works because I like them more for visibility and durability.
Nano QX 3D , MQX x2, DBL Mild NCPX, stock NCPX, 130X lynx, 450x.. Dx7s
2010 wr250r/x supermoto
unit3890 is offline        Reply With Quote Quick reply to this message
Old 03-16-2013, 11:53 AM   #67 (permalink)
I'm sure it'll work fine. The V2 is a hair better, but gets warped more easily. An abused KBDD works better than an abused V2
Micro: OMP Hobby M1
Big: SAB Goblin 500
Radio: Spektrum DX8 Gen 1
Old 03-16-2013, 07:18 PM   #68 (permalink)
Default My BL Tail
Figured since I had an 8000kv HP02T laying around I thought I would see what it would do.
Based on suggestions on here I have a slightly cut down and balanced RRC Prop.
The motor mounts I created on my CNC machine out of delrin.
The HP02T, I turned the shaft around. I think it looks better this way. There is no snap ring groove this way so I put a small o-ring behind the prop to hold the whole thing together. it a bad crash if the prop comes off you might loose the rotor, might put a bit of ca on the shaft to hold it.
I mounted the XP3A esc which has BLHeli10tail flashed on the back of the 3-in-1 at the bottom.
I am not in anyway in the league of some of the flyers on here. More of a novice. but it had tons of thrust and holds very well. not tail wag at all. Just solid.
Thanks to NCcraig, litehawkdown, Dylan, DoubleCH for the insite to make this work. and of course sskaug for the BLHeli Project and 4712 for BLHeli-Setup
tmacrc is offline        Reply With Quote Quick reply to this message
Old 03-16-2013, 07:24 PM   #69 (permalink)
The HP02T has a 1mm shaft. The stock motor has a .8mm shaft.
Thanks,
BR
Old 03-17-2013, 04:28 AM   #70 (permalink)
Hi,
You're set up is with the HP02T 8000kv or the 12000kv? Looks like a good job you did man!
timox72 is offline        Reply With Quote Quick reply to this message
Old 03-17-2013, 11:31 PM   #71 (permalink)
HP02T 8000kv
Originally Posted by timox72 View Post
Hi,
Old 03-19-2013, 07:15 PM   #72 (permalink)
The 12000KV HP02T has 6 magnets and a different wind than the 8000KV, which has 12 magnets, and works with the stock tail blade on the Nano, and the Ladybird prop on the MCPx.
Ill have them in stock this weekend, along with just about everything else from Oversky
Thinking about doing a kit for the Nano that includes a solid tail boom, what do you guys think?
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote Quick reply to this message
Old 03-19-2013, 09:49 PM   #73 (permalink)
Default Re: A new BL tail to try out........
Well sign me up for a motor! Kits will sell. My only question/comment on the solid boom is since they are so easy to make I'm not sure how much added value they will provide.
muddyml is offline        Reply With Quote Quick reply to this message
Old 03-20-2013, 05:32 AM   #74 (permalink)
Kit is great, but maybe without tail rod
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 03-20-2013, 12:56 PM   #75 (permalink)
+1
I'll take a BL Tail kit as soon as its available..but I have lots of carbon rod from making my own solid booms.
Ken
Trex 450SE2 - Pro Head, Nano CPX BL Mild
kenkos68 is offline        Reply With Quote Quick reply to this message
Old 03-20-2013, 12:59 PM   #76 (permalink)
I would do it Dylan, I think for a lot of people it will make the kit even more atractive. Not everybody wants to buy 1mtr of 2mm cf rod just to use 115mm. Those who are flying with 2mm cf rod right now, know that it's pretty much indestructible. I've had so many crashes on my wild set up and never had to replace my solid cf rod.
For us clients it might be interesting to be able to in- or excluide the rod in your kits, as an option I mean
Old 03-22-2013, 01:26 AM   #77 (permalink)
Nice work tmacrc. Just missed you today at the indoor. Would of been nice to see that thing in action. Not sure what I did but glad I helped.
litehawkdown is offline        Reply With Quote Quick reply to this message
Old 03-23-2013, 05:54 PM   #78 (permalink)
OK, it's the weekend
Any news on availability yet ?
Trex600 12S/ Trex600 8S/ Trex600 10S/ Trex 500 pro x2/ Trex 450 x 2/ MX400 x 2/ Shogun 400 x2/ Century 3D Pro/ MCPX x4/ MSR/ Nano CPX brushless x2/ GWS Cobra/180CFX/Goblin 380
skeppley is offline        Reply With Quote Quick reply to this message
Old 03-23-2013, 06:15 PM   #79 (permalink)
Tomorrow, still have a lot of work to do!
Sent from tapatalk
Old 03-24-2013, 10:24 PM   #80 (permalink)
So, since it so late on a Sunday, and i still have a ton of work to do on them, kits will be in stock tomorrow.
Sent from tapatalk
