Old 01-06-2009, 07:06 PM   #1 (permalink)
Default SK360 VS other brand
Hey guys,
We have been tossing the idea of going flybarless on one of my MinAir Razors back and forth for a long time. And what I would like is if you guys that have used either the Skookum and/or other brands and give me the pros and cons of each setup.
Team MA
PG 378
Paul G.
You'll be the end of me
PG 378 is offline        Reply With Quote Quick reply to this message
Old 01-06-2009, 08:29 PM   #2 (permalink)
If you already have a tail Gyro, then you don't need a v-bar. I use a Skookum on a Gasser and it works well. I'm still testing and playing around with stock settings, but it performs well. I've had to do some mechanical mods to get everything right, but I am well on my way. It is also reasonably priced.
The 2 banks on the Skookum allows you to fly two set ups, so I have a 'normal' set up and a 3D setup. I have it attached to my flight mode switch. Not that I fly 3D. I did notice a significant increase in power due to less drag and loops are huge and beautiful.
Art is good to deal with and set up is really easy. Again it can't be over emphasized that the settings provided work very well.
Lou
Vector 550 Quad/Octo Multirotors
DJI WooKong Multirotor Controllers
Twin Bergen 44 Magnum Turbines - KERO Start FBL
www.circlecityhelis.com
lperagallo is offline        Reply With Quote Quick reply to this message
Old 01-06-2009, 10:01 PM   #3 (permalink)
My only experience is with the SK360.
  • It was about as plug and play as it gets
  • the stock 3D settings are great.
  • you have to re do your level swash/servo/cyclic set up again in the SK and remove it from your radio
  • added power is great
  • autos are fantastic
  • hovers hands off but still 3D's like you wouldn't believe
  • as stable and solid as can be but an absolute rocket when wanted/need be
I know I'm not supposed to say this ...but, this little gem is making me a better pilot. It's so solid that if gives me confidence I did not know I had...almost like flying the sim
TREX 700N Flybarless custom direct to swash servos
ebay-12projectsnow12
stmpngrnd is offline        Reply With Quote Quick reply to this message
Old 01-07-2009, 02:24 AM   #4 (permalink)
It is all said above
You can get huge loops and the entry and exit in the same plane. No more cork-screwing.
Very smooth on my scale fuselage now...
Regards perfeet
perfeet is offline        Reply With Quote Quick reply to this message
Old 01-07-2009, 03:56 AM   #5 (permalink)
You can see the quick set up reference in my site (in signature) to find out how easy to set up the SK 360
www.Heli-RND.com - we ship worldwide free; SK 720, SK 360, DS 760, GyroBot .....mostly FBL only, the good products only
www.Heli-RND.com
Heli-RND is offline        Reply With Quote Quick reply to this message
Old 01-07-2009, 04:24 AM   #6 (permalink)
I agree it's not hard.. but it isn't easy either. There's a whole lot of settings you have to check and understand and if you get something wrong you'll find out in flight. check out my video to see what happens when you screw up.
But that holds for any flybarless system.
I noticed on my first 8 seconds of flybarless flight that my headspeed was the same at 80% throttle as it was before at 100%. So I expect a noticeable power increase in future flights.
jvthert is offline        Reply With Quote Quick reply to this message
Old 01-07-2009, 01:55 PM   #7 (permalink)
Wow, guys! Thanks for such quick replies!
I am really looking forward to doing this!
Team MA
PG 378
Paul G.
Old 01-07-2009, 01:57 PM   #8 (permalink)
Cant go wrong with the SK (when properly setup).
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 -
JaggedEdge is offline        Reply With Quote Quick reply to this message
Old 01-07-2009, 05:08 PM   #9 (permalink)
Team MA
PG 378
Paul G.
You are in for a treat. Just follow the very good instructions from Skookum and don't rush to get the heli in the air even if you are excited.
Follow the instructions and tripple check before flying the first time. Good luck and don't hesitate to ask for help on this forum.
Regards perfeet
Old 01-07-2009, 05:22 PM   #10 (permalink)
Perfeet, good comment
www.Heli-RND.com
Old 01-07-2009, 10:11 PM   #11 (permalink)
Hey, Heli-RND, your site is very informative!
Well put together and easy to understand!
Team MA
PG 378
Paul G.
Old 01-08-2009, 04:31 AM   #12 (permalink)
Thanks Paul, that credit should some from Art who approved it
www.Heli-RND.com
Old 01-19-2009, 07:30 PM   #13 (permalink)
I purchased my Sk and had the bird in the air in about 3-4 hrs. Flys like a dream. I will not go back to flybars.
Blade 130x. Gaui X5 Forumla
I'm Back Snitches!!!!
maxxteezy is offline        Reply With Quote Quick reply to this message
Old 01-20-2009, 10:46 AM   #14 (permalink)
I will agree with everyone's comments here, just had my successful maiden and I cant wait until the weather improves so I can get out and really put it through its paces. It setup was simple and you are not locked in to converting your head a particular way. I am planning to put one in my 600N after I get some holiday bills paid off
c_forthofer is offline        Reply With Quote Quick reply to this message
Old 01-20-2009, 04:48 PM   #15 (permalink)
If you will go for another one, I offer option with USB and free shipping to save you a few dollars. Have fun.
www.Heli-RND.com
Old 01-24-2009, 04:46 AM   #16 (permalink)
Hello Jvthert, what 's your problem on your video please.
I' m french excuse me for my english!
nounours94130 is offline        Reply With Quote Quick reply to this message
Tags
flybarless, razor, setup, skookum
