Old 10-12-2011, 02:21 PM   #21 (permalink)
Thank you all for the kind words, I really do appreciate it. I consider this payback time for me, a lot of people helped me here as well when I started this superb hobby, and I learned a lot, included some knowledge of Shakespeare’s language, which I needed badly.
To be honest, I couldn’t decide where to post all this in the beginning, the Futaba or Spektrum subforum didn’t seem the best place, as the post is about both these systems and more. Silently hoping that this info won’t be lost, the sticky suggestion is very nice to hear, and I hope to add more graphs in the future, as more people at our local club will be prepared without a doubt to let me measure their Multiplex, Aurora, dual ACT S3D (2 x 100 mW!) and other brands of transmitters or plug in modules.
Back to business, and as promised, a graph of a Spektrum DX8 in DSMX mode, at normal power. The system will now switch between 23 randomly selected channels all the time, instead of using only two channels in DSM2 mode, so after a very short while we get this picture on the analyzer screen when it’s set to memorize max values:
The peaks measure around -10 dbm or 0,1 mW, exactly the same as in DSM2 mode.
Logo 800 - TDR 14S - TDR 12S - Logo 500SE - Logo 400 - Furion 450 6S mini-V - 300X - 150S - mCPX - Schluter Bell Huey Cobra '74 - Aura 4 hotliner - F27D Evo
redbird300 is offline        Reply With Quote Quick reply to this message
Old 10-12-2011, 04:08 PM   #22 (permalink)
Very nice write-up Redbird. While it's a lot to take in (I would imagine it's somewhat indecipherable for non-electronics backgrounded people), it's very honest and very un-biased, which is pretty tough to do. Like you said in the beginning, there will be the fanboys who like to use the info about their system to magnify just how great it is, but that's to be expected. In reality, they're all very, VERY good and solid systems and the problems people have are typically related to user error or power supply system on the individual models themselves. It's a truly rare case when it's 100% the radio's fault, so it's funny to see some of the animosity on both sides of the fence.
Anways, the best antenna position is roughly 90* to the surface you are modulating to. Very little of the signal come straight out of the tip of the antenna, so it's best to bend it off to one side. You can leave it at a bit of an angle if you'd like, but the majority of your flying should be done as cloe to perpendicular to the antenna as possible to ensure maximum signal strength.
Tim
KBDD TEAM PILOT
--Si vis pacem, para bellum--
skunkworx is offline        Reply With Quote Quick reply to this message
Old 10-12-2011, 08:26 PM   #23 (permalink)
Interesting, Raf. It gives me an impression that S FHSS uses narrower channels compared to F. Could this explain why my DX8 goes through its stock NiMH battery pack 2-2.5 times slower than the 8FG?
Would the wider channels (more energy pumped in the air) have any bearing on the maximum range, or it's just a plain and pure waste of radio energy, defined by the SS algorithm in use? The peak power is exactly the same...
Jerry
jperkosk is offline        Reply With Quote Quick reply to this message
Old 10-13-2011, 12:50 AM   #24 (permalink)
Team Taco VP
We are working on sticking this somewhere. GREAT POST! It's just where to stick it. I proposed my tech forum but what do you all think?
Bob
Old 10-13-2011, 08:19 AM   #25 (permalink)
Bob
(chanting) sticky..sticky..sticky!! I think the tech forum is a perfect spot for the post.
Logo 600se
Redlight11 is offline        Reply With Quote Quick reply to this message
Old 10-13-2011, 10:55 AM   #26 (permalink)
Team Taco VP
So be it!
Bob
Old 10-25-2011, 08:26 AM   #27 (permalink)
Nice post. So that nobody gets confused, there are a couple of typos (or probably font symbol issues) here:
"The formulae to calculate x [dbm] as a function of P [Watt] is:
x= 10log10(1000P) or x = 10log10P + 30
And the formulae to calculate P [Watt] as a function of x [dbm] is:
P = 10(x/10)/1000 or P = 10(x-30)/10"
The first formula should be
x = 10logP + 30, where "log" is the base 10 logarithm
The second should be
P = 10 ^ [ (x-30)/10 ], where "^" is read "raised to the power of"
V120D02S x 2 :: Mini Protos x 2 :: Align Trex150 :: Proto X nano quad
Devo 6 with Deviation flies them all!
Jazzjohn is offline        Reply With Quote Quick reply to this message
Old 10-26-2011, 10:23 AM   #28 (permalink)
Thanks,
A basic lesson on how to set up the transmitter antenna was sorely needed. And I really enjoyed the explanations of the different signal patterns.
I learn a lot on this form.
Good luck and happy landings.
daveapplemotors is offline        Reply With Quote Quick reply to this message
Old 10-26-2011, 09:27 PM   #29 (permalink)
Formerly BarnStormer
Scorpion Power Systems
Jason O'Connell is offline        Reply With Quote Quick reply to this message
