nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help |
04-14-2014, 01:42 PM | #1 (permalink) |
Possible to change gear ratio?
Hi,
I'm about to install a WILD HP03 outrunner on my nano, but I would really like to keep the somewhat low stock headspeed, something similar to that achieved with the stock brushed motor. (This just suits my confined flying environment) I believe tuning it down this low from the transmitter drastically reduces efficiency, so I know I could use a MILD motor instead, but I was wondering if it is possible to change the drive ratio using different pinion/main gear to achieve the same effect. If so, would this method also provide higher torque, i.e less bogging? If this is completely wrong or impractical that is fine, I am mainly just curious.
Protos380 | Oxy2 | OMP m1 | nanoCPX BL |
04-16-2014, 08:45 PM | #2 (permalink) |
You want .3 mod pinions like the ones in the link bellow.
http://astroid-designs.myshopify.com...ent-1mm-shafts
Nano CPX x 3, mCPX-BL x 3,130X, 180CFX, Lynx 450X-L, T-Rex 250 DFC, T-Rex 450L, T-Rex 500, KDS Chase 360, SAB G380, G500 Spt, BT650, BT700-T, BT700 Spt, XLP520 "More the Knowledge Lesser the Ego, Lesser the Knowledge More the Ego" Albert Einstein |
04-17-2014, 10:59 AM | #3 (permalink) |
+1 for what miracle boy said, but i have never seen a Nano cpx gear with less than 7 teeth (which is the stock/standard #). But it's not like i've ever looked that hard either.
Logo 550SX Gaui X3: 360mm 6S IKON1 HWV3 + a 2nd 325mm Night Bird Nano CPX (x2), Upgrades: AD Mild &wild BL, MH swash, Solid extended tail Blade CX2 stock, & DX8, +some quads + small fixed wings |
04-17-2014, 12:28 PM | #4 (permalink) |
Yea, it seems like 7 is the lowest I can go on the pinion. Anyone ever heard of a larger main gear?
Would there actually be any benefit in running the 16600KV in its optimal range, with a higher gear reduction, compared to just running the 13500KV?
04-17-2014, 02:23 PM | #5 (permalink) |
I would assume that the 16.600 sacrifices some torque opposed to the 13.500. Would you run the 16.600 on the same speed as the 13.500 it would bog more under load. Running the 16.600 at full speed, but geared down to reduce the headspead, youimprove torque. The torque will probably be fairly similar. The added bonus would be that the motor itself runs at a higher speed. More energy is then stored in the turning part of the motor. This mean that the motor will have a lower drop in rpm when suddenly applying pitch. This is purely theoretical. I would try it if I had a small pinion.
