Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Ufly
Ufly Walkera Ufly Helicopter Support
Old 01-12-2011, 02:06 PM   #1 (permalink)
Default What is the function of the green wire between the RX2435 and the UFLYS ESC ???
I've bought a RX2435 to try a 3-axis gyro in my GURU-Z FP. I will use the TX2401 of my CB100, a very fast Inolab servo for the tail and 2 MKS DS480's for cyclic.
Everything seems to work ok, only the ESC won't make the motor turn. Starting up, I hear the usual beebs, but that's it.
I noticed the original UFLYS has an extra green wire between the RX2435 and the ESC; what's the function of this wire? is there some kind of workaround?
WOW Hobby recommends me a Feigao ESC, but that one doesn't have the extra wire, just like my own Hobbywing, so I'm unsure the Feigao will be the solution.
I hope anyone can help me out. Thanks for the replies!
ZamBeZi is offline        Reply With Quote Quick reply to this message
Old 01-14-2011, 12:31 PM   #2 (permalink)
Well, I just gave it a try.
Took an old servowire, plugged it in the BATT-port of the RX-2435 and connected the white wire to the JST-balancerconnector of my 3S lipo: the middle one of the 3 positive pins, which has the volts of only 2 cells (didn't have the guts to put 11,1 volt on the RX-2435).
It worked!
Very happy! Now nobody needs a RX-2433 with those adaptercables!
Old 01-16-2011, 12:17 PM   #3 (permalink)
A quick primer on servo leads... For Walkera (and many others, but not all), the arrangement of red, white and black breaks down like this: red is + voltage power supply; black is - voltage power supply; white is neg going signal line. You know (ok, assume) that its negative because of the order of the wires in the lead and on the board (ie the plug can be reversed without blowing up the servo amplifier- this is not carved in stone, tho).
The outer most black wire/plug rx board is the negative buss on the receiver board and is to the outside of the rx. The red + lead is in the centre, and the white signal line is on the inside edge of the buss strip. Usually all black negative buss lines and red pos buss lines on the rx connector strip are connected together (thats why it usually doesn't matter where a power lead( red/black) get plugged in). The white signal lines are isolated from one another for channel function.
I'm guessing the green wire is plugged into the signal (white) line on the receiver. If so, its purpose on that plug circuit is to provide low voltage cutoff signal back to the esc to shut down the esc in the event of receiver lockout or power supply failure, in order to prevent a runaway. Putting 7.4v on that line may not be wise... If the circuit only uses voltage sensing, then a single batt cell voltage of 3.7 should be adequate to keep the ESC alive unless voltage drops well below 3.7v.
Schluter Champion, Kavan Allouette, TRex550E-FB, HC500SE, CloneT450pro-4bladed, Blade 400, WK 4F200, Xaircraft X650, and a CB180D, usually in a tree.
60something is offline        Reply With Quote Quick reply to this message
Old 01-17-2011, 08:13 AM   #4 (permalink)
just did a test:
3,7 volt doesn't work
5,0 volt idemdito
it's really a cut-off for 2S
