Eagle Tree Systems Onboard data loggers, telemetry, and OSD support |
10-25-2009, 08:19 PM | #1 (permalink) |
Eagletree question
Please view the attached graph. A bit confused here. I recorded one flight tonight, got back, hit download and got this graph. Looks like it includes a previous test flight I did? Does all the saved data on the recorder stay on it until you delete? Also, how do I only get the latest flight on the graph?
Lastly, what are those 2 gray bold lines running vertical throughout the graph? Thank you! |
10-27-2009, 10:11 AM | #2 (permalink) |
You need to "Clear Recorder" when you are done with what is currently stored in the logger. The gray lines separate the different "sessions" you have recorded (a session is added every time the logger is powered on). You can focus on a single session using "Sessions/Chose Session" in the menu in the 2d chart. This is also possible in the main window menu ("Data/Chose Session").
An often overlooked feature in the chart is that you can drag select a rectangle with the interesting part, e.g., exclude spool-up and the idle time after landing so the reported averages and max/min values are meaningful. /Lars
T-Rex 450 Pro, T-Rex 500 CF, Goblin 500, Logo 500, T-Rex 600 Pro, T-Rex 700E, Stingray 500, DX9 Last edited by Lajon; 10-27-2009 at 10:26 AM.. Reason: Spelling |
