Kontronik Drives Jazz and Jive ESC's and other Kontronik equipment support |
02-22-2015, 07:12 AM | #41 (permalink) |
Why do you ask Linus?
Have you an idea?
---- JR Vibe SGE12 Hiroki Ito Scorpion Tribunus 200A 4525 Ultimate Spirit FBL—-Minicopter Diabolo Pyro750-56 Kosmik200 Vbar v5.3 ----- T Rex 700N DFC OS105HZR Spirit FBL --- RJX Vector 700 Pyro750-56 Comp Kosmik 200 —— |
02-22-2015, 07:40 AM | #42 (permalink) |
sure
send me a PM with your email please, I have a test firmware, would be quite interesting to see if we can "fix" this Cheers Linus |
02-22-2015, 07:47 AM | #43 (permalink) |
Ok,PM sent.
02-22-2015, 09:31 AM | #44 (permalink) |
To summarize it again: as picture book
Main message is: The BEC is not to blame! As promised: Linus just made a 1st special firmware for the UG which turns UG's functionality into a cross of battery and UG To be tested. The question is: when to turn back to UG's normal function? Nevertheless, all this is somehow a crutch: We buffering voltage drops away instead of eliminating the causes. At the same time we undermine ourselves and our product portfolio: Our Micro Power Bus would be part of the solution, if one assumes that the problem is not generally solvable: The current hunger of today's servos stands in opposition to the contact resistance of servo connectors.
Tom (j-log.eu) |
02-22-2015, 09:41 AM | #45 (permalink) |
I have the firmware and will try this out later on when I get home from work.
Sounds very very promising. I will still use the BEC guards on the Master and Slave outputs and will also remove the extension cables on my Kosmik to V Bar wiring regardless. Stand by.
02-22-2015, 12:44 PM | #46 (permalink) | ||
All working now! Thanks guys.
02-22-2015, 12:51 PM | #47 (permalink) |
Okay. Now the fine tuning on the UG firmware and perhaps this will be the new standard, a cross of (not "dumb") battery and the well-known UG functionality.
Saving money (not ours ): You can solder both, master and slave, together, - together to one servo plug or directly to ONE BG. One BG is enough. Ok.., two BGs halve the resistance. Unfortunately K has servo connectors at their ESCs.
Tom (j-log.eu) |
02-22-2015, 01:27 PM | #48 (permalink) |
Yes, some more testing to do tomorrow.
02-22-2015, 04:13 PM | #49 (permalink) |
Love these guys tom and linus rock
Diabolo S #6 Diabolo TDR N7 |
02-22-2015, 04:15 PM | #50 (permalink) |
I agree with that 100%.
You could not get any better - fact!
