600 Class Electric Helicopters 600 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
10-18-2008, 05:23 AM | #61 (permalink) |
More Flight Graphs, this time with a 650L motor.
1220 Kv motor instead of the 1650Kv XL. Some Flight Data Graphs. Outrage 6S1P5000 and Zippy-H - 6S1P5000 Align 75G ESC. 650L motor with 14 tooth pinion. TST - VBlades. 611 Gyro combo. Belt Drive. Outrage 2S1P 2500 reciever pack with Align Reg to RX. AR7000 reciever. Seems to pull more Amps and wattage than the 600xl. Weather = Ambient temp was 38 degrees, warm day down here. ESC was coming down at 52 degrees C Motor was 57 degrees C Batterys were 52 degrees C In my opinion could do with a 100Amp speed controller as it was bursting the 75G at over 100 Amps. Other than that, a great motor. Here are some Graphs.
Trex 700E 12S Scorpion 4035-500 3DX SK360 Spartan 760 CC110 Trex 600E 10S Scorpion 4025-740 FBL SK360 Spartan 760 CC85 |
11-29-2008, 12:44 PM | #62 (permalink) |
650L with stock esc on 8S & 6S
650L Align motor with stock esc on 8S & 6S
Contains elogger charts for 12t straight pinion on 8s at 100% throttle curve at 2390 headspeed, & reduced throttle curve for 2250-2300headspeed Detailed post at: https://www.helifreak.com/showthread...929#post982929 |
12-10-2008, 08:54 PM | #63 (permalink) |
Stock 600L and ESC.
11t pinion 188t helical Align 600 blades TT with Align CF 95mm tail. Idle up 100;95,100 with +-12 pitch TP V2 5000mah 6s My headspeed is around 2k Hovering and landing...therefore spikes.. |
03-23-2009, 06:39 AM | #64 (permalink) |
Scorpion 4025-1100 16T on 6S Zippy 5000 Mah
Jive 80+HV governed to 70% HS avg 2050 RPM Motor Temp 115 Battery Temp 100 JIve Temp 97 Ambient Temp 78
Trex 700N, 700E, 600E, 500E all Vbar 5.2 Pro FBL Dji F550 WKM Data Link 900MHZ DJI F450 Naza/GPS FPV 5.8 vtx TBS Disco w Core Naza GPS FPV 1.2 vtx MT Tiger motors |
04-03-2009, 04:21 PM | #65 (permalink) |
Got my new Micro power V3 this week and gave it a test on my new ESP and a friend CF.
The first graph in my new 600ESP: Neu 1910H/1Y CC 85HV 8S 5000mAh FP EVO 25 Rotortech 610 13T Revco pinion HS about 2200 The second graph is 10S setup of my friend: Plettenberg Orbit 30-12 Heli Expert Schulze future-32.80F 10S 3850mAh TP Extreme V2 Radix 600SB 19T Mikado pinion HS around 2250
~Roei~ |
04-03-2009, 05:29 PM | #66 (permalink) |
what firmware are you running. i'm very surprised to see amp draws in the 90-100s (especially on an 85amp esc) off of an 8s setup at 2200rpm. i rarely got 70.
˙ʇı ʞɐǝɹq 'ǝʞoɹq ʇ,uıɐ ʇı ɟı |
04-03-2009, 05:33 PM | #67 (permalink) |
The firmaware is the latest 5.51
What I measured is during a real hard 3D.
~Roei~ |
04-03-2009, 05:52 PM | #68 (permalink) |
not saying anything is wrong...just a curious observation. my pic shows a 5-second 13° full collective climbout. i wouldnt think you could be much harder on it. but i didnt even hit 75 amps.
04-04-2009, 06:42 AM | #69 (permalink) |
What setup are you running ?
~Roei~ |
04-04-2009, 01:29 PM | #70 (permalink) |
that graph was from an trex 600 on FP3700mah 8s running a scorpion 4025-740kv motor on 17t governed to 2200rpm via the CC85HV.
04-09-2009, 01:19 PM | #71 (permalink) |
Trex 450 Pro Stretch Neu Scorp 1630, 8s, CC30HV. Mini V Trex 700 DFC V-bar |
04-13-2009, 05:10 PM | #72 (permalink) |
I have 3 graphs. With 14T, 15T and 16T. Which do you prefer?
My setup: Scorpion HK4025 730KV - CC85HV - 10S Zippy-H 3300mAh []s
Outrage 550 - Scorpion 740KV - Platinum 70HV - JR 8717 - MiniVbar 5.0 - Turnigy 10S 3600 Synergy E9 - Neu 1920H 510KV - Power Jazz - JR 8717 - Vbar 5.1 - Zippy 12S 5000 Synergy N9 - YS 91 SR- Hatori pipe - JR 8717 - 611 - MultiGov Pro |
06-04-2009, 10:08 PM | #73 (permalink) |
600e, 12s30c2650, Scorpion 4025-630, Jive 80HV.
This flying machine thang may be an illness like Alcoholism. If there isn't a support group yet someone should start one... Current addiction: Align 250, 2x 450s, 500,12s 600e, 700e CX2 and several 3D planks. |
06-07-2009, 12:13 AM | #74 (permalink) |
Trex 600E
10S Zippy-H 5S1P4000 Flybarless 4025-740 on 16 tooth pinion with 700N main gear. SAB 600mm Blades. Same setup with older Polyquest 5S1P 3700 packs, dont know the cycles. as you can see the Zippy with 2 cycles on them put out alot more power, not far off a good 12S setup. Full Chopper specs are in this thread - http://www.ausheli.com/apps/forums/t...10s-flybarless
06-07-2009, 11:57 PM | #75 (permalink) |
Some more data from today.
Very Windy conditions. Fixed end point mode on the ESC CC85HV 4025-740 16tooth pinion, 164 T700N main gear SAB 600mm blades Flybarless Basic foward flight most of the time, in idle up 1 which is 85% throttle and then in Idle 2 100% throttle. Some airleron rolls during circuiting. Bigger spikes are Negative pushouts with Piros and some Tic Tocs thrown in for good measure. Climbouts in both modes on initial phase of flight. First chart is Polyquest 5S1P3700 in 10S - older packs, still good Second chart is Zippy-H- 5S1P4000 in 10S - 3 cycles Pulls about 22 amps in hover at 85% throttle Pulls about 27 Amps in hover at 100% throttle Basic Circuits are about same amperage if flown sedate. MAH Used is very good per flight if flown sedate but a few big power moves were included in this chart for measure.
06-13-2009, 10:24 PM | #76 (permalink) |
Same Config as above just new Rhino 5S1P3700 packs in 10S.
First cycle and putting out a whopping 4.9 HP thats alot more than an OS50 at 1.9 HP
07-19-2009, 08:04 AM | #77 (permalink) |
OK some more Data Logs.
Remember this is a Flybarless machine. Same Configuration. This time running 15 tooth Pinion instead of 16 tooth. Tached the head speed at 2400 RPM so i could imagine what 16 tooth was before hand, LOL !! As you can see it is an improvement over the 16 tooth pinion. Both flights consisted of a fair bit of backwards circuits, inverted backwards circuits and tic tocs and aileron tic tocs and well as a few Piro flips and also large forward loops and a few stall turns. Now with a 14 tooth Pinion and more respectable head speed, no tach but i will do it soon to find out the exact Head Speed. As you can see its pulling way less amps overall and also using ALOT less MAH and also flys very good, still plenty of pop and more flight time, much easier to fly with the lower head speed and less brown trouser time. It shows that with a lower Pinion tooth count the peak wattage is lower than with a higher tooth pinion showing that temps and flight time and battery life should improve vastly and for little to no loss in performance. Seems to me that 14 tooth is alot better and has a more respectable head speed thats not excessive and performance is still there, so the 14 tooth will be the keeper atm as the graphs show its alot less stressfull on the machine and it flys great. As you can see from the initial Data graphs after the initial 10S conversion i have gone from 3700 Watts " 5HP, shit thats alot " to 2700 watts " 3.6 HP " with basicaly no loss in performance and increased flight times and less temps due to wasted output in heat. Also gained an extra Minute in flight times.
08-03-2009, 08:55 PM | #78 (permalink) |
EDIT sorry, that was my 500 graph.. not 600
