Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 60/70/90
Thunder Tiger 60/70/90 Raptor 60/70/90 Helicopters
Old 10-02-2008, 01:52 PM   #1 (permalink)
Default 91ST motor, the head keeps coming loose?
The head on my 91ST keeps coming loose and I'm not sure why. I've checked it and none of the bolt threads are worn and I use locktite everytime i put it back togetter but for some reason it keeps coming loose over time. Is this a normal thing to keep checking and doing maintenance on or is there something wrong?
Cheers
Trex 600E, 2 -Trex 450, Mcpx BL, Turnigy FBL 100, Assault 700
siavreg is offline        Reply With Quote Quick reply to this message
Old 10-02-2008, 07:31 PM   #2 (permalink)
what color loctite are you using?
RotaryBliss is offline        Reply With Quote Quick reply to this message
Old 10-03-2008, 04:53 PM   #3 (permalink)
Blue
Old 10-03-2008, 05:12 PM   #4 (permalink)
sounds like the motor is detonating you might be to lean!! what fuel are you running
24-7 rc is offline        Reply With Quote Quick reply to this message
Old 10-03-2008, 06:02 PM   #5 (permalink)
Blue loctite is removable with heat.. red loctite is for High heat applications.. Also remember to tighten the head bolts in a sequence across from each other, not radial. Just like an automobile.
Old 10-03-2008, 11:30 PM   #6 (permalink)
Yup I do use the radial method, but maybe will try the red loctite. It is a new fuel then I'm use to so maybe I am running a little to lean? Its Power Master 30% heli. The settings were way different from the magnum 30% heli i was running but that may have been from the head starting to loosen?
Old 10-04-2008, 12:28 AM   #7 (permalink)
was that a typo? you mentioned you do tighten the bolts in a circle. Vs alternating across from each other. use red sparingly, and make sure you do not use Permanent loctite. Semi perminent sparingly will deteriorate slow enough to last about long enough for you use the engine and be able to crack it apart when its time to rebuild if you dont replace. Good luck. yes, switching fuel brands can be a pain at times because of the different lubrication package each one uses. Thats why its always best if you can to stick with one flavor. Hard to say about the head being loose before you switched, though leaning out usually is a sign that something is leaking air aside from improper tuning.
Old 10-05-2008, 04:32 PM   #8 (permalink)
Sorry ya that was, i do go back and forth like a car tire to tighten the head down. Ok I will give it a go and see how it makes out using the semi permanent loctite.
Old 02-11-2009, 01:33 PM   #9 (permalink)
red loctite has no place on any kind of rc model period!!!
mrhp is offline        Reply With Quote Quick reply to this message
Old 03-15-2009, 07:52 AM   #10 (permalink)
Do not use red locktite !!!
The engine was not designed to use locktite on any of the bolts, the motor has to be detonating and causing a serious vibration for the head to come loose, install a new head gasket and shim the head out until your detonation is gone and your problem will go away.
steve 01 is offline        Reply With Quote Quick reply to this message
