Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage RC
Outrage RC Outrage RC - and XP Li-Po Factory Support Forum
Old 08-22-2007, 09:26 AM   #1 (permalink)
Default Rotorworkz frames and Parts
Hey guys to give you a heads Up The Rotorworkz Team is working hard and fast to get you a nice Conversion frame kit. :eek: So.... I wanted to get some feed back from you. I am at the point of deciding to anodize or not to anodize the aluminum frame parts so here is some choices I can offer
Black
Clear
and try to match Guai
Also do you have anything else in frame design that you would like me to look into
Thanks Guys won't be long I will have pictures to post
Best
Charley
Charley Stephens
Charley Stephens is offline        Reply With Quote Quick reply to this message
Old 08-22-2007, 10:11 AM   #2 (permalink)
Awesome! Guess we gonna have good choices when it comes to the carbon fiber frames. These are the things I'll definitely be looking for when I'm ready to purchase the carbon fiber frames.
1.)bearing blocks. doesn't matter if its plastic or metal
2.)space to put my logictech gyro without having to mod it. I have a feeling some will go for 611
3.)perfect servo wheels for my servos
4.)breakaway skidds and battery mounts
5.)able to support one 6s 3200 at minimum
6.)ease of install and motor install
7.)price and parts availability
anodizing is cool buts its just bling so I think we all really care about stiffness and the ability to support big powerful motors with reliability!
tdsounds is offline        Reply With Quote Quick reply to this message
Old 08-22-2007, 08:53 PM   #3 (permalink)
cd5
I think it would be good if you tried to match the GAUI color, just to keep the heli looking like its not made up of bits and peices from here ,thereand everywhere.
AS Far as frame design goes, I think having it easy and quick to pull it all apart is important and also have access holes on the opposite side of the servo mounting holes to make it easy to get a nut on the bolt that holds the servos on the chassis. (yes i do have thick thumbs).
I am guessing the frame will be a 2 peice per side set up so its not to narrow, and if it is, it would be good to have access holes to the inside frame where the bolts are ,so we can easily check all frame bolts are tight, simply by sliding our hex drives through to the inside frame bolts.
And also could th bolts be the same size as whats on the heli at the moment as the larger bolts dont strip their heads as easily as the smaller ones do ,like whats on the trx 450s.
An other thing which would be cool if the amount of bolts required to spli the frame could be minimised for fast gear and bearing etc changes. Why i say this is because i have also raced rc cars and have noticed that the cars are being user freindly and quicker to strip ,change parts and rebuild. And for me ,time is important to me, as i have to young children .,work commitents etc and so on. And as parts are very affordable for this heli I carry most spares. And if when i do get a couple of hours to go flying, there is nothing more dissapointing then crashing first up and knowing a repair is not something you would rush at the feild as it is to complicated or time consuming, and so go home and thats it . It would be sweet if when that happens you could get airborne quickyl and still get a few precious flights in. I think many other people would also be in this situation also.
Although the above would be great, you wouldnt want to trade off performance or stiffness to achieve this.
Also how good is all the after market support that is starting to become available for this heli.After seeing what upgrades and improvements that are being released , i am very happy i bought this heli.
Regards
Simon
cd5 is offline        Reply With Quote Quick reply to this message
Old 08-23-2007, 05:47 AM   #4 (permalink)
My vote goes to Gaui grey or black. Anodizing is good as it gives a very hard surface, not just the bling factor. And fiberglass, not carbon fiber, for me!
ianjh123 is offline        Reply With Quote Quick reply to this message
Old 08-24-2007, 07:48 AM   #5 (permalink)
Thanks for your input guys I will be addressing all issues with the stock frame plus adding some nice features with this heli
Price even with adding anodize will be Very Affordable
Charley
Charley Stephens
Old 09-10-2007, 04:14 AM   #6 (permalink)
If it's not too late, and if you are still going to use 2 stage reduction, put bigger baerings on the one way shaft. The Gaui ones are too fragile after they upgraded from the 6mm shaft to the 8mm shaft. They should release a new frame with bigger bearings here also.
Old 09-10-2007, 08:02 AM   #7 (permalink)
if the carbon fiber frame for the Hurricane 550 is available please email me as quik as possible.
FredrickGarcia@hotmail.com
SAB Goblin 700---T rex 550 FBL---Blade MCPX(BL MOD)---T rex 450 PRO DFC---LOGO 600 SE---OUTRAGE G5---BLADE 300X---BLADE 130X---
S P E K T R U M DX 8
Fredrick is offline        Reply With Quote Quick reply to this message
Old 09-10-2007, 09:29 AM   #8 (permalink)
Guys I am awaiting on aluminum parts from machine shop so I can complete the prototype frame if All checks out good. Then kits will go right into production.
Please be patient as it WILL BE WORTH IT!!!
Charley Stephens
Old 09-10-2007, 01:17 PM   #9 (permalink)
Team Taco VP
Yea Charlie cant wait man!
Old 09-10-2007, 02:34 PM   #10 (permalink)
anything you can show us for a sneak peak charlie? my H550 CF/G10 frame money is burning a hole in my pocket lol
phil
Happy|Harry is offline        Reply With Quote Quick reply to this message
Old 09-10-2007, 02:36 PM   #11 (permalink)
YEAH!!! I hear yah Happy/ harry give us a PEAK AT THE GOODS MAN
Old 09-11-2007, 08:54 AM   #12 (permalink)
Yes, this is very interesting. A nice direct ccpm input would be great. And, hope you will make a G10 version!
Tom Viper is offline        Reply With Quote Quick reply to this message
Old 09-11-2007, 09:47 AM   #13 (permalink)
* G10
* Break-away skids and canopy mounts
* Easily fit alternative battery configurations (eg 7s to 10s A123)
* Choice of servo sizes (adapter plates maybe?)
* Includes optional boom mount for tail servo
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is offline        Reply With Quote Quick reply to this message
Old 09-11-2007, 11:55 AM   #14 (permalink)
Hey guys here is a little bit of info my apologies as I cannot say to much "yet" to many cooks at the grill
I will share this, kits will be offered in G10, CF, and Silver you will be able to mount nearly any battery you want don't know about 10s a123 :eek:
Servo mounting choice will be available (separately)
Please be patient as this model is still in prototype and I will ensure you this kit with be nothing less than top notch when it is ready to release. And Good price to boot!
Charley
Charley Stephens
Old 09-11-2007, 02:43 PM   #15 (permalink)
Charley
it's perfectly understandable you want to keep it under wraps charley, there's too many people out there that are willing to rip off other peoples work and profit from it
for the 10S A123 if a 10S brick which is 135x70x50mm wont fit on it's own do you think that mounting two seperate 5S A123 which are 135x70x25mm each will be possible? as i'm going to be setting my hurricane up for 9S li-po/10S A123 and the 2 x 5S A123 would be my prefered option , so hopefully they'll fit
phil
Old 09-11-2007, 07:08 PM   #16 (permalink)
Just for the record... the Gaui CF frame seems to be a very nice fit for 2 x 5S 2300MaH 20-30C Hextronic packs. One on the slanted battery deck and one down below between the frame plates. Plenty of scope to slide the bottom unit back to adjust CofG. I threw the tail on my unit today and put the packs and motor in place (no servos, gyro or canopy) and I could get a perfect CofG when lifting by the flybar....
ukgroucho is offline        Reply With Quote Quick reply to this message
Old 09-11-2007, 07:27 PM   #17 (permalink)
Charley
Cool
Kenneth
Old 09-11-2007, 10:02 PM   #18 (permalink)
I am waiting for my various sized Flight power packs to arrive to be 100% sure but I estimate I will be able to fit "comfortably" Flight power Evo 30 6s1p 4500
Charley
Charley Stephens
Old 09-12-2007, 06:29 AM   #19 (permalink)
Hey Charley... don't forget that some of us want to use two smaller (2000 - 2300) 4S or 5S packs to build HV rigs.
I've not finished my 10S CF Gaui build yet (should maiden this weekend) but you probably know I'm a big fan of your 450 Trex frames so I'm very interested to see where you take this - and I'm a big fan of higher votage setups 'cos it gives great power and cooler running everything.
Old 09-12-2007, 08:51 AM   #20 (permalink)
Jon,
You should be fine with your setup I specified the above size pack to give you an Idea on the amount of free space with the canopy on you will have.
Charley
Charley Stephens
