Outrage RC Outrage RC - and XP Li-Po Factory Support Forum |
05-08-2007, 08:15 PM | #21 (permalink) |
One concern I have with this new frame design is the reduction of available swashplate vertical travel due to the increased distance between the top and middle main shaft bearings (to accommodate the servos). Some guys wanting to run extreme amounts of collective pitch may be disadvantaged. I'm guessing there's about 7mm less vertical travel available.
Also, Align were very clever to position their bellcrank rod right in between the rear and front (pair) of swashplate balls when viewed from the side. This is what gives it that near "perfect" geometry without any noticeable interactions. kenkamm, you're right about the ccpm interactions on this new frame, but as you say, it can be worked out with a mix. I've been considering going without the bellcranks on a stock frame. Even in that config there is a slight interaction because the pushrods are not at the same angle from vertical between ele and ail/pit, but it's less severe than the interaction on this new frame since all the arms can be configured to come from the "outside" if you flip the rear servo over. But again - a mix in the right place will resolve it. It's just a matter of being able to tolerate those "crooked" links. |
05-08-2007, 08:42 PM | #22 (permalink) |
Charlie I want 2 sets what is the ETA Approx. ?
Fly it like you stole it!! |
05-08-2007, 08:46 PM | #23 (permalink) |
Lovetofly, there are changes not seen in the pics that will accommodate pitch :wink:
As for interactions you are correct but... they will be very minimal as servo throws have changed. Lets just say this set up has SUPER FAST servo response :mrgreen: yes it is responsive!!! All ccpm machines have interaction and yes you can take the time to fine tune it out wiht a mix or Swash menu that is all ihave flown is ccpm machines ........My comment was based upon throwing a swash tool on and squareing the swash center top and bottom and flying it i havent even bothered to fine tune it and it flies really square Bobby
Charley Stephens |
05-08-2007, 08:49 PM | #24 (permalink) |
Super D,
ETA I hope soon I am hoping to be at the Jacksonville funfly next weekend with the final prototype
Charley Stephens |
05-08-2007, 09:06 PM | #25 (permalink) | |
So, what's your trick to allow enough pitch? I've studied the movement of the stock head and this would be a problem unless you modify the head linkages a bit. |
05-09-2007, 04:17 AM | #26 (permalink) |
Man, I should've waited! :mrgreen:
T-Rex 600 HFE-stretched to 700, 10s, Tango 45-08, Jazz 55, JR7703D/S8900G, DJ Vegh nose cam mount. T-Rex 600 HFX-stretched to 700, 10s, Orbit 30-12, Jazz 55, GY611/S9256, Askman 360 mount. JR X9303. |
05-09-2007, 07:44 AM | #27 (permalink) |
All ccpm machines have interaction and yes you can pmix it out .. My comment was simply based on squareing the swash center top and bottom and go fly... I havent even took the time to fine tune it and it flies really square
And it is VERY QUICK!! Bobby |
05-09-2007, 02:06 PM | #28 (permalink) |
I wonder if a straight shot cylinder devise might work better. Like a cylinder that moves in and out of a sleeve.
Just a guy and his heli.... |
05-09-2007, 06:31 PM | #29 (permalink) |
I have the HFE frames with the 600XL motor and had to cut the top of the canopy for the motor to fit. Would it be worth it to go with these new frames when they come out?.....will it save much weight over the stock align frames? My HFE's come in at 6.3lbs RTF with the 9650's on the cyclic (a little weary of them on my 600 to be honest)
05-09-2007, 10:14 PM | #30 (permalink) |
Jet,
you won't have to cut the canopy on this frame. I am making these frames because I was asked by many people to make a frame similar to HFE but with full size servos So I have. As for weight savings over stock I don't know will know after prototype is complete Charley
Charley Stephens |
05-10-2007, 07:31 AM | #31 (permalink) |
Thanks Charlie, I'll look forward to pick up these new frames when available. Will they be offered in CF as well?
05-10-2007, 08:03 AM | #32 (permalink) |
Jet yes they will be offered in CF g-10 is the cheapest way to get them tested
Bobby |
05-10-2007, 08:47 AM | #33 (permalink) |
alright thanks Bobby...I've flown with chandler a few times down here in vero beach, maybe we can all get together one weekend and fly somewhere. I use to go to school in Daytona (Embry Riddle).
In Thrust We Trust. |
05-11-2007, 09:57 PM | #34 (permalink) |
The new frames look sweet Charley ! Hope they aare out before a break my stockers lol.
Chris |
05-13-2007, 02:39 AM | #35 (permalink) |
These are going to be hot!
...Once upon a time there were Nitros, flybars & frequency pins...Shawn |
05-13-2007, 09:42 AM | #37 (permalink) |
Registered User
Another masterpiece Charley!!
SWEETTTTTTT!!!! Bobby was THRASHING Greg's T-REX at SEFF to the point of shedding a V Paddle and half a flybar. If he says this new HFX is sweet, I believe him. Thanks guys for making a fine heli even better!!
William James Crazy wife still trying to kill me. |
05-13-2007, 12:08 PM | #38 (permalink) |
I want a set how long before we can order them.
Team Outrage OPM - Fly it like it aint yours! JR X9303 2.4 Baby. I have felt the difference and I like it! Don"t make me list 'm all ! |
05-13-2007, 04:02 PM | #39 (permalink) |
Yeah... What's the tentative release date on these? They look very nice! Do they come with those sweet carbon control arms for the servos?
-Kyle |
05-13-2007, 05:20 PM | #40 (permalink) |
Thanks Shawn and Will !!!
The plan so far is a little more testing before releasing. But not much longer on the time frame. So if any plan to attend Jacksonville event this up coming weekend Bobby and I plan to be there wringing out some prototypes stop by and take a look The pictures shown earlier in earlier posts don't show all that has been done to make this thing well.... lets just say
Charley Stephens |
