Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage RC
Outrage RC Outrage RC - and XP Li-Po Factory Support Forum
Old 10-06-2007, 01:42 AM   #21 (permalink)
Nicely put Kenneth.
Thanks for the investigation!!. I'm Flying A123 at the moment, and I guess that I’m one of those that want to invest in a 6S lipo solution. Thinking about an airthunder 5000 6s pack. That should give me some reasonable flight times. Hope that one will fit.
But from what I notice seeing the picture: The lipo is right in the middle of the frame .. Wouldn’t the heli be tail heavy? Right now with the 7s A123 sticking out from the front the balance is o.k. So IMO the hurri needs quite a bit of "nose" weight to get the CG right.
I hope I'm wrong about that, because I really like the idea to have the "root canal without anesthesia pain" expensive lipo to be within the frame
I love the looks of the frame !! I hope they will be available soon !!.
Maurice
dutch_anykey is offline        Reply With Quote Quick reply to this message
Old 10-06-2007, 12:41 PM   #22 (permalink)
I just took time to 'stack' two of my HXT 2300MaH 5S packs and it looks like my initial thoughts were wrong.
Whilst the 'main' part of the pack is just low enough (measuring the cell stack) the end where the cells connect and the power cables come out is slighly taller... so you end up needing 53 to 54 mm. The battery bay is wide enough but not tall enough.
ukgroucho is offline        Reply With Quote Quick reply to this message
Old 10-06-2007, 06:54 PM   #23 (permalink)
OK Guys As it stand I cannot make the frame wider due to to much $$$ But have considered taller I will look at it to see what I can do
AS for CG those pics in the first post just Show the room available to install Lipo packs My Heli CGs with the 3300 pack flush to the front of the frame I also have a boom mounted servo
I will post more pics soon
Charley
Charley Stephens
Charley Stephens is offline        Reply With Quote Quick reply to this message
Old 10-06-2007, 07:36 PM   #24 (permalink)
Thanks for looking at it Charley. If you can manage to make it 56mm tall and if it is feasible to use washers/spacers to add 3mm to the width to get to 52mm then that opens up more options, including the possibility of A123 shotgun packs (standing on edge or at an angle) or A123 triangle packs as well as a greater range of lipo combinations. Still won' t help the folks flying 2 x 3s 2200 AT though which would need 60+mm
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is offline        Reply With Quote Quick reply to this message
Old 10-06-2007, 07:58 PM   #25 (permalink)
If you can get the battery bay taller Charlie then I'll be hanging on your web site...56mm would be just fine.
Old 10-08-2007, 11:24 AM   #26 (permalink)
OK Guys,
This is what I was able to achieve 54mm in height complete. If you were to remove the base tray you gain almost another 2mm and for those who would like to run A123 in triangle packs you can also remove the upper tray for an additional 1.5mm for a total of 57.5mm in height
I will have pics later on of my ready to fly heli
Charley
Charley Stephens
Old 10-08-2007, 05:15 PM   #27 (permalink)
Here is some pics specs are
Z30-1100 with 14 tooth
MAH 515's
Flightpower 6s1p 3300
6100t gyro / servo
Futaba 9650's using Rotorworkz sevo adapters
Kool flight 6 Volt UBEC
CC80
Spektrum 7channel RX
Also note the Boom mounted Servo. I will have Boom mounts with plates for Standard and 9650 servos
Charley
ID:	28143   Click image for larger version
ID:	28144   Click image for larger version
Charley Stephens
Old 10-08-2007, 05:36 PM   #28 (permalink)
Very Cool!
When do you expect this to be ready for purchase?
stefank is offline        Reply With Quote Quick reply to this message
Old 10-09-2007, 05:08 AM   #29 (permalink)
Originally Posted by stefank View Post
Very Cool!
Dito!!!
Before X-mas??
Patrik J is offline        Reply With Quote Quick reply to this message
Old 10-09-2007, 07:07 AM   #30 (permalink)
Charley,
I really do like that blue frame and sort of hoping that will be your de-facto standard. It just looks cool and not like the others. Makes it stand out in the crowd.
Carl
quickster47 is offline        Reply With Quote Quick reply to this message
Old 10-09-2007, 08:05 AM   #31 (permalink)
Very Cool!
Well... I hope to have some kits Soon generally it will take 2-3 weeks to get all the CNC Parts.
Soo Yes I really hope way before Christmas.
The blue with silver is done by me the base color of those frames is like a cream color so I painted them does look cool I think I will do neon stuff with a pattern next
Charley Stephens
Old 10-09-2007, 02:48 PM   #32 (permalink)
charley have you settled on a price for the G10 frame? and the boom servo mounts?
phil
Happy|Harry is offline        Reply With Quote Quick reply to this message
Old 10-09-2007, 07:47 PM   #33 (permalink)
Hmm, any extra canopy post mounting holes so we can use better looking canopies?
Razor_Racer is offline        Reply With Quote Quick reply to this message
Old 10-09-2007, 07:52 PM   #34 (permalink)
I quite like the H550 canopy but I am interested to know which others you have in mind ?
Kenneth
Old 10-09-2007, 08:05 PM   #35 (permalink)
I dont really know, I dont know too much about these 500 sized helis... I just dont like the hurry canopy, because the entire canopy just looks like its pointing down. Maybe a logo 500 canopy if it fits?
Old 10-09-2007, 08:19 PM   #36 (permalink)
Oh, OK. I don't like the Logo canopies at all myself, but it's very subjective.
BTW, just to clarify, the H550 is not a 500 size heli, it is 30-size. The naming is confusing but works something like this:
400/450-class = 300-350mm blades, under 1kg (eg TRex450, DragonusII, miniTitan e325, Diablo, Blade400 etc)
500-class = 400-450mm blades, under 2kg (eg Lepton, QJ-EP8, HDX500, RCT-500, Dragonus500, TRex500 etc)
30-size = ~500mm blades, under 3kg (eg Swift, Logo10/500, eRaptor550, Hurricane550 etc)
50-size = ~600mm blades, under 4kg (eg TRex600, Logo14/600, eRaptor620 etc)
90-size = ~700mm blades (eg TRex700)
Kenneth
Old 10-09-2007, 08:36 PM   #37 (permalink)
Dragonus 500? please elaborate,I havent seen it.
Todd
hopntod is offline        Reply With Quote Quick reply to this message
Old 10-09-2007, 09:29 PM   #38 (permalink)
Todd
I don't want to take this thread off-topic. All I know is that it is in the works and rumoured to be due out before Christmas.
Kenneth
Old 10-09-2007, 09:54 PM   #39 (permalink)
Cool Its a little off topic also so maybe we will create another topic
But there will also be a Rotorworkz heli ummmm... 550 size
more later at another time another place
Charley Stephens
Old 10-10-2007, 12:45 AM   #40 (permalink)
Charlie, WHAT ABOUT PRICE?????????
Piranha is offline        Reply With Quote Quick reply to this message
