Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum |
04-15-2014, 05:44 AM | #1 (permalink) |
What do you think about this 6S Setup?
Hi Guys,
I really love the F50 but, never been encouraged to build one. Now I am going to do it, however I want to build in a 6S Setup, which includes the following components: Kit - Fusion 50 New Gears - FBL Motor - Align 600MX - 1220KV ESC - Talon 90A Ciclic Servos = Align DS-615 Tail Servo TORQ 9188 FBL = BeastX BEC = Embedded in the ESC Blades = RJX 550mm Please, let me know what you guys think about it... Thanks, Francisco. |
04-15-2014, 05:51 AM | #2 (permalink) |
It will work but I feel the talon may be too small as well as the BEC on board. The internal BEC is rated enough but if I remember correctly there is only one wire from the esc for power. Should have two like the Castle BEC Pro.
04-15-2014, 05:54 AM | #3 (permalink) |
Hi Michael,
Ok, what about a HW 100A ESC? I am thinking about to install a Gryphon (Love these ones) instead of a CC BEC. About the short boom, is it really necessary when running the 550 Blades? Thanks! |
04-15-2014, 11:46 AM | #4 (permalink) | |
KDS INNOVA 700 TDT Robird G31 FUSION 50 Robird G31 Titan X50 TEAM ROBIRD |
04-15-2014, 12:01 PM | #5 (permalink) |
Hi Dino,
Ok, so probably I will try the Talon, are you using an external BEC? I am not a 3D guy, just sport flying, some loops and at maximum light tic tocs. Can this setup hold this? Did you shortened your boom? Thanks! |
04-16-2014, 08:14 AM | #6 (permalink) |
I have used the HW/Gaui 100 but it was on an X5 which is much lighter. Works well but like dino said about the Talon it may be limted.
Try it and see what happens. |
04-16-2014, 04:45 PM | #7 (permalink) |
I'm flying the same esc/motor combo as Dino. Talon 90 and an old 600m 1220. It has been working fine so far. It has plenty of power for what I do with it.
04-17-2014, 09:21 AM | #8 (permalink) |
I am not running an external BEC. If that is your flying style you will be fine. I have the 550 conversion.....shorter boom and 550mm blades. As long as you don't crank up the head speed and do continuous tic tocs you should be fine.
04-19-2014, 11:52 AM | #9 (permalink) | |
Hi Francisco,
This is the 6S setting that I had copied from the internet when F50 was then widely sold 6S Lipo 25C: 5000mA 6S Motor (at least 2500 watts): 1100kv ESC 120A Pinion 13T or 14T RPM 2100-2200 Still suggest a separate BEC Cheers Quote:
[TDR 1x 800 1x Speed] [Prôtos Max V2] [Kasama Dune] [Outrage Fusion 50 6HV head] [Prôtos 500] [Outrage G5] [SAB Goblin 380] [Mini Prôtos (Stretched)] [Warp 360] [vWinRC 450T (Stretched)] [FBLs 3Sx, Spirit, vBar, BeastX; mCPX BL; DX9] |
04-20-2014, 02:30 PM | #10 (permalink) |
Have a look at the YGE 120 or their inspired counterparts YEP... Or V-bar with the HW esc
04-20-2014, 07:21 PM | #11 (permalink) |
Yah, I have really good experience with YEP ESCs. Definitely better gov function than HW if you take vbar out of the equation. Lol
04-23-2014, 08:14 AM | #12 (permalink) |
yes shorten the boom.. very easy and flies better on 6s...
my set up; 1100kv scorpion 6s5000 150 amp ESC (100 is enough) seperate castle PRO bec (2 power leads) 550mm blades 2000 head speed, 6 minute flights
Outrage Fusion 50 FBL / Futaba 8FG / Beastx / Scorpion HK4025 |
