Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba 14MZ - 12Z
Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum
Old 04-20-2007, 05:27 PM   #41 (permalink)
Going back a rev or 2 simply to get the non-official calibration tool running is not a good idea. There are changes in the new releases that the old ones know nothing about and could result in unknown failures. For example, latest release has the cyclic ring which is stored as part of each model; don't know what might happen if the old code sees this feature's data where it probably didn't expect it. Also, there's no guarantee that the format of the calibration data structures don't change from release to release; hence you may perform a calibration and when you upgrade it may change things around. Best thing to do is to wait for someone to leak the tool again or bug Futaba to incorporate it into the GUI (it's already in their code, just disabled in code).
RCfan is offline        Reply With Quote Quick reply to this message
Old 04-22-2007, 09:10 AM   #42 (permalink)
Yepp, I agree that it is probably not a good idea to downgrade to a prevoius version to run the utility. ( I have tested it and the radio seems to be working ok after the donwgrade, but I have not fully tested it with a real flying model-memory)
The best solution would be that Futaba enabled the calibration in a similar way as for the 12Z.
RJ
Hirobofly is offline        Reply With Quote Quick reply to this message
Old 04-25-2007, 08:12 PM   #43 (permalink)
What do you do with the calibration program?
Rotormast V-22 Osprey, 2 450 Clones, BL P-51, Micro P51, Stryker, 2 Vapors,
hoot is offline        Reply With Quote Quick reply to this message
Old 04-25-2007, 10:04 PM   #44 (permalink)
Calibrate
David
DavidH is offline        Reply With Quote Quick reply to this message
Old 04-26-2007, 08:03 AM   #45 (permalink)
Old 05-10-2007, 03:24 AM   #46 (permalink)
Hi everybody!
I just bought a 14MZ with the last year firmware. I want to update it but I am afraid that doing so I will mess with the region and band capability. My TX is set for ASIA.
Available downloads are from japan or USA. Is it safe to use them on another region TX?
I don't want to end up with a USA bands restricted or worse Japan bands restricted TX.
pilou2 is offline        Reply With Quote Quick reply to this message
Old 05-10-2007, 03:31 PM   #47 (permalink)
Hi there.
It should not be a problem, I've done the last 3 updates with the software-release distributed in the US on my 14MZ with European region setting. Works like a charm!
Good luck.
RJ
Old 05-14-2007, 08:10 AM   #48 (permalink)
OK,
I will try it,
Thank you Hirobofly
Old 05-14-2007, 08:10 AM   #49 (permalink)
OK,
I will try it,
Thank you Hirobofly
Old 05-14-2007, 05:38 PM   #50 (permalink)
Hello,
I also have a 14MZ bought at cyberheli (Asia zoned) and did the update coming from a French website. It's working like a charm wo any problems.
sambogosse is offline        Reply With Quote Quick reply to this message
Old 05-14-2007, 07:24 PM   #51 (permalink)
Gentlemen:
I just purchased a 14MZ. The current firmware is 4.2, 1.0.5, and 1.13. I noticed that there are several updates. Do I need to update all or just the most current?
Banker1 is offline        Reply With Quote Quick reply to this message
Old 05-14-2007, 10:41 PM   #52 (permalink)
You only need to install the latest -
[4.20(0)/1.1.0.1766/1.37] 2007-03-21-T14MZ_1766.zip
--Felix
Old 06-04-2007, 01:05 PM   #53 (permalink)
I confirm I did it and it works perfectly!
Old 06-04-2007, 05:13 PM   #54 (permalink)
Worked great here as well. Thanks
Old 06-12-2007, 06:25 PM   #55 (permalink)
Hi, I have to say first that I found this forum very interesting and useful.
I have a 12Z which I just received from HK. The radio came in 72Mhz, which I wanted, but the number of available frequencies were restricted.. my previous 9Z had access to all the 72band, and this one was limited..
After playing a bit with it (I opened the box an hour ago), I upgraded the software to 1.37 and found (thanks to this forum) the service menu (good, no more need for a special connector instead of the campac module in the 9Z)
I then changed the area to Americas, finding it strange that I could not select 72mhz for Europe.. I am in Europe and 72 is allowed here.. (LO only) well, once in Area America, I have access to all 72 mhz frequencies, but, but, but, when I start the readio it says Mistatched RF module...
My module has a sticker CN on it.. which I believe means china..
I hope that there is a trick here to make the TX module international, and that I do not need to buy a new TX module for this brand new radio..
thanks in advance for your replies..
charles
papymouzot is offline        Reply With Quote Quick reply to this message
Old 07-12-2007, 11:40 PM   #56 (permalink)
Default Re: 14MZ / 12Z / FX-40 Software Update 2007-03-21
Originally Posted by RCfan
FFC posted new updates for Futaba's 14MZ, 12Z and FX-40 radios.
If you're an FFC member, get them from the official site. I'll have them up on my site shortly, but for now, here they are (READMEs inside each file):
14MZ - http://rcfan.com/files/14MZ/updates/...T14MZ_1766.zip
12Z - http://rcfan.com/files/12Z/updates/2...date_1_1_0.zip
FX-40 - http://rcfan.com/files/FX40/updates/...-FX40_1766.zip
--Felix
hi
can you tell me if the fx 40 update has any worthwhile changes, and how exactly do I get the data into the x mitter?
thanks for any asstance, as I have not used the memory stick..
mj
H
human21354 is offline        Reply With Quote Quick reply to this message
Old 08-14-2007, 02:13 AM   #57 (permalink)
Wink
Papymouzot,
you don't need to buy a new module just to reprogram the eeprom.:wink:
Have a look at this file:
EDIT:
As requested by the moderator I deleted the link. It has already been done by WillJames but for any reason it came back and all the last messages concerning this link were removed too...
Sorry for those who were interested but you still can PM me.
It is a donkey or emule link if you don't know. I hope it is not forbidden here.
If you can't download it PM me.
Good luck!
MZFAN is offline        Reply With Quote Quick reply to this message
Old 08-15-2007, 04:02 PM   #58 (permalink)
Hi MZFAN, does this software works with a 14MZ Radio?
Nicoleto is offline        Reply With Quote Quick reply to this message
Old 08-16-2007, 12:40 AM   #59 (permalink)
Hi MZFAN
Is the T14mzUtility.exe for 14mz?
benben is offline        Reply With Quote Quick reply to this message
Old 03-14-2010, 01:47 PM   #60 (permalink)
Default T14mz utility
Hello MZFAN
16f84 is offline        Reply With Quote Quick reply to this message
