Belt CP E-Sky Belt CP |
03-05-2013, 11:10 PM | #1 (permalink) |
Esky gyro
Good day felow rc pilots. Hope somebody can help me out here. On the standard ek2-0704b gyro the led indicator light is not working at all. But it seems that the gyro is working when i move the heli tail from side to side. Is there a reason why the led light is not coming on.
03-06-2013, 06:45 AM | #2 (permalink) |
Not sure Jake, According to the specs the only time the light would be off is if there is no power or if the gyro is unlocked, however, in the latter case I am sure you would have seen it flashing prior to that point. In the case of the former, I don't suppose it can be that, as you said it is correcting.
I guess it is simply a case of the led having failed. Cheers Sutty
Regards, Sutty BeltEXI, mCX, mSR, 4G3, FBL Trex250SE µB, FBL Trex450Pro µB, FBL Trex550e VX1 Pro, FBL Trex600ESP VX1e, Parkzone P51D, QRX350Pro |
03-06-2013, 07:51 AM | #3 (permalink) |
Doesn't no light mean that the gyro is in rate mode, rather than HH mode...?
450 Bell 222, 450 Jet Ranger, HBFP Redbee Extreme, 500 size Blackhawk MH-60, 600 EP Spitfire, Sebart 342 30e, Davy Systems Flybaby, ST Models FW190, Micro SU26 & GWS P38. DX7s |
03-06-2013, 09:18 AM | #4 (permalink) |
03-06-2013, 09:42 AM | #5 (permalink) |
Yup, reading it in context, I think we are both saying the same thing; the Chinglish Manual says unlocked, which is the opposite of locked ie. on a headlock gyro, unlocked = rate mode.
