Old 11-27-2013, 11:13 PM   #1 (permalink)
Default T-Rex 250 Pro DFC setup
Finally got my night time setup in the air for a quick test.
Pictures and Video here
*edit* Didn't know the amazon links would overwrite the text. Maybe someone should fix that in the thread preview =)
On each main blade:
100mAh battery
All LEDs and resistors are 1206 size
2x Blue on top
2x Red on bottom
4x 270 ohm resistors
3-pin micro server plug male, special female plug with loop from pin 1 to 3 to turn on lights
Batteries and plugs held on with double sided tape, then covered with heat shrink tubing.
On the tail:
6x Green LEDs
6x 270 ohm resistors
Copper tape
2-pin mini JST battery plug
The tail uses a 180mAh battery that I scavenged from a cheap coax heli, mounted under the receiver.
Pulls around a bit in the air, so I'll keep tweaking it, but pretty happy with the visibility so far.
Amazon and Ebay links:
http://www.ebay.com/itm/Mini-Micro-1...item27daeba96b
http://www.amazon.com/gp/product/B00BXHXJD4/
http://www.amazon.com/gp/product/B008MX8WQ6/
http://www.amazon.com/gp/product/B003ICY2H4/
ID:	468168   Click image for larger version
zortness is offline        Reply With Quote Quick reply to this message
Old 11-28-2013, 04:10 AM   #2 (permalink)
AWESOME!!!
rodo1268 is offline        Reply With Quote Quick reply to this message
Old 11-28-2013, 08:59 AM   #3 (permalink)
Banned User
Post
Nice job on the 250 size night blades. Not an easy task.
Did you weigh and balance them?
kavic5150 is offline        Reply With Quote Quick reply to this message
Old 11-28-2013, 10:55 AM   #4 (permalink)
Thanks!
Yup, weighed and balanced. 15.9g for each of the main blades.A bit heavy for the 250, but I like this setup better than some of the other lighter attempts I made. First try was using CR1220 button cell batteries, but I could only power 2 LEDs, and not for a long time (pics attached). I might try to make a set of night blades for my Solo Pro 180 and v120d02s using the button cells.
ID:	468249   Click image for larger version
Old 11-28-2013, 11:20 AM   #5 (permalink)
Banned User
Post
There are some mighty small lipos out there if you google hard enough. Like 20 or even 10mah. No need to use yesterdays tech and sling around the extra weight of button cells IMHO.
At least for main blades. Off the shelf night tail blades seem to use them for some reason.
Old 11-28-2013, 08:26 PM   #6 (permalink)
That is really cool how you made your own setup. I plan on doing the same hopefully for my Blade4503D. Hopefully its not too tough
Usman is offline        Reply With Quote Quick reply to this message
Old 11-29-2013, 02:26 PM   #7 (permalink)
You are in the right spot plenty of help here.
HankAz is offline        Reply With Quote Quick reply to this message
Old 11-29-2013, 04:16 PM   #8 (permalink)
Any idea how to search for those smaller lipos? I haven't had much luck. I think the 100mAh would be more appropriate for a 450 than the 250.
Old 12-03-2013, 03:14 PM   #9 (permalink)
Thanks, this certainly is the place. I might as well ask for a good set of night blades for my Blade4503D, can anyone come up with a good list of things I would need....like the right size components; lights-batteries, excertera? Thanks !
Old 12-03-2013, 04:15 PM   #10 (permalink)
Banned User
Post
I did some searching the other night but was unable to find 10 and 20mah single cell lipos. Jayconsystems no longer has them in stock.
Finding single cell 50mah and up is easy enough. On ebay just do a search for "3.7v lipo" or even "3.7v battery." From there just sort by price low to high.
Old 12-03-2013, 04:53 PM   #11 (permalink)
Gotcha, then I would just use the components in the first post of this thread?
Old 01-05-2014, 10:59 PM   #12 (permalink)
Just FYI. Had a crash the other night. While hovering inverted, the pinion gear spun on the shaft, moved up, shredded the main gear. Pretty instant loss of power and plowed into the grass.
It's likely due to the increased pressure put on the blades with these large batteries protruding from the top, exacerbated while inverted. I'm thinking the 100mah batteries I have on there are too large for this little guy to handle.
Old 01-07-2014, 09:03 PM   #13 (permalink)
Nice!
crizyal is offline        Reply With Quote Quick reply to this message
Old 01-08-2014, 05:18 AM   #14 (permalink)
Banned User
Post
I'm not so sure that a few extra grams near the root of a 250 would be a problem. Going from 100mah to 50mah cells will only save a couple of grams.
Guys flew the Gaui 200 with 5 blade heads and no upgrades except for the stock v1 esc which wasnt up to the task.
You might want to look into grinding a small flat spot on the motor shaft. I suspect there isnt one. The grub screw inside the motor pinion has a small sharpened cup which usually bites into whatever metal its tightened down on. But in the case of a hardened motor shaft all it does is flatten the end of the grub screw.
I would make a thread in the 250 helicopter section. Other Trex 250 owners would know better than me, I'm not familiar with that model.
Old 01-08-2014, 12:56 PM   #15 (permalink)
Yea, there's no grub screw on the stock 250 pinion gear, it's a "glue-on" style. I will likely replace that entire setup soon, but I just wanted to throw this out there as a warning to the 250 night flyers.
I don't think it's the weight of the batteries, is the disturbance in the control surface on top of the blades, which is significant percentage wise to the size of the blades in these small helis and at these super high head speeds. I definitely noticed a drop in performance while inverted with the night blades on, but didn't think much of it until my gears stripped. Smaller batteries mean less surface area disturbance.
Old 01-09-2014, 07:50 AM   #16 (permalink)
I agree with Zort. I have the perfect regulators kit with the 50mah batts. It's a fine kit, but I could notice a definite difference with the batts on the small blades of my Gaui X2. The lift has been cut down, it's noticeable to me in flight. There is no way I would go up in battery size.
GravityJunkie is offline        Reply With Quote Quick reply to this message
