Old 12-27-2011, 05:47 PM   #461 (permalink)
Originally Posted by popokatepetl View Post
Well I've had loctite in all four radial bearings. I mean in the bearings which deatroyed them.
It wasn't problem to get them out. Maybe Align guy wanted to be sure it holds.
I've played with the new tail grips and found one thing. The inner radial bearing is 0.5mm higher in one grip then in the other one. I hope it won'thave any influence on balance. I hate vibrations!
And another thing. I had to use 0.2mm shims instead of the 0.3mm ones Align gives us. It was way too tight.
If it's the inner radial closest to the tail hub it's going to vibrate for sure as it will offset the entire tail grip by .5mm.
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
Old 12-28-2011, 07:05 AM   #462 (permalink)
BD Forum Support
I played with 0.1mm shims and found the combination. Now I have almost no vibrations on the tail. I like this V2 grips! Works like the Quick UK ones which is awesome. Good upgrade.
popokatepetl is offline        Reply With Quote Quick reply to this message
Old 12-28-2011, 10:42 AM   #463 (permalink)
Where did you get the 0.1mm shims?
NRPY is offline        Reply With Quote Quick reply to this message
Old 12-28-2011, 12:16 PM   #464 (permalink)
BD Forum Support
Some RC buggy local hobby shop.
Old 12-30-2011, 12:11 PM   #465 (permalink)
Originally Posted by Dino Spadaccini View Post
Does this new hub work with the V2 A tail blade grips?
Lean not on your own understanding.
Goblin 500
silas3d is offline        Reply With Quote Quick reply to this message
Old 12-30-2011, 08:32 PM   #466 (permalink)
I think the combo should work, as the stack is only critical from the hub viewpoint. Actually, in my my pack of 2 V2A hubs, one worked without slop or bind, and the other had binding. Again, I think it is Align's tolerances that make the difference. If you get a set of the -B hubs, and one doesn't work try the other one.
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Hobbies Team Rep
rcflyerheli is offline        Reply With Quote Quick reply to this message
Old 12-31-2011, 09:43 PM   #467 (permalink)
Thanks. Well I bought 2 V2 "A" tail assemblies and between the two of them was successfully able to cobble one non-binding tail together using .1mm shims. I'm going to order a set of the "B" hubs to see if I can get another one up and running.
It's been said before, but this is ridiculous...
Goblin 500
Old 01-12-2012, 09:13 AM   #468 (permalink)
I have 4 new in box HN6103BT, V2 Metal Tail Rotor Holder / Silver.
Still coming without shims... but wait.... upon closer look, they ARE in there. Had to heat and remove the outer radial bearing to tell. They stick together quite well.
cshutchinson is offline        Reply With Quote Quick reply to this message
Old 02-16-2012, 08:54 AM   #469 (permalink)
Any update on how the "B" version is working? Will this fit on the stock Trex 700N tail shaft, I have an older 700 kit.
jadams is offline        Reply With Quote Quick reply to this message
Old 02-16-2012, 08:57 AM   #470 (permalink)
I find the B version to be quite the cat's meow.
Old 03-26-2012, 03:18 PM   #471 (permalink)
Hi, before buying this part http://helidirect.com/align-v2-metal...0e-p-25414.hdx , i need some feedback. The tail wag problem has been solved with this new part (HN6103B) ?
Thanks in advance.
msallua is offline        Reply With Quote Quick reply to this message
Old 03-27-2012, 01:10 AM   #472 (permalink)
No problems with tail wag on any of the V2B tails I have built .. about a dozen of them
ChrisH is offline        Reply With Quote Quick reply to this message
Old 05-07-2012, 07:09 PM   #473 (permalink)
Default what part number ?
Hi!
Seen both HN6103B and HN6103BT....what should i look for?
AAKEE is offline        Reply With Quote Quick reply to this message
