Go Back   HeliFreak > R/C Helicopter Support > Electric Micro/Mini Helicopters > Zoom/Shogun 400
Zoom/Shogun 400 Electric - Zoom - Shogun 400 Specific Discussion
Old 07-25-2004, 01:33 PM   #1 (permalink)
Default Zoom Belt drive and Axi installation pics
I snapped some pictures to help people with their belt drive installation either with or without the axi motor. With the axi motor it is a bit more involved because you have to run a large pinion (18T). If you are running a more conventional motor with a normal size pinion the install is very straightforward and simple.
With the axi the only pinion I could find locally was pretty tall, because of this height I had to make a light ply spacer to move the motor down a bit so that it wouldnt contact the bottom of the belt drive bearing plate. If you can find a shorter pinion then you wouldnt have to deal with this step.
In addition you need to either dremel or carve some clearance from the bottom side of the carbon bearing plate that comes with the belt drive.
So really those are the only things that need to be modified, I would recommend that you try and find a shorter pinion then mine since it would make the install much easier, but if you cant it can still be done.
Pics will follow, another tip I thought I would thow in here is that the stock hex tailshaft the heli comes with is total garbage, for a cheap and very effective replacement head to your local bike shop and buy a 14 guage stainless spoke, it is exactly 2mm and runs much truer then the stock hex shaft.
It may take some time and effort to get the belt drive in with the Axi but I promise it is worth it. It turns this heli into such a tough little beast and is totally worth the time so that you never have to screw with the tail again.
Hope this helps, let me know if you have any other questions.
Tabb
Tabbytabb is offline        Reply With Quote Quick reply to this message
Old 07-25-2004, 02:52 PM   #2 (permalink)
Thanks!! Looks good!
falconpilot is offline        Reply With Quote Quick reply to this message
Old 07-25-2004, 03:04 PM   #3 (permalink)
Registered User
Sweet Tabb!!! Thank you!!!
Can't wait to get my Belt Drives from Dave!!
William James
Old 07-25-2004, 06:33 PM   #4 (permalink)
Sar
I wish the guy who built the full carbon frame for the Zoom and the guy that does the belt drives would get together.
Sar is offline        Reply With Quote Quick reply to this message
Old 07-25-2004, 06:38 PM   #5 (permalink)
I contacted Dave today and he said that it would be about two weeks before I could expect a belt drive. He is very busy.
Bob
Samuel Adams field rep
Buffalo Wings field rep
Success is the ability to go from one failure to another with no loss of enthusiasm.
Churchill
capebob is offline        Reply With Quote Quick reply to this message
Old 07-25-2004, 06:57 PM   #6 (permalink)
Sar, dave has a full frame made for the belt drive in the works, should make it so that you dont have to add much if any weight and have a cool CF frame.
Tabb
www.freeflycinema.com
Old 07-25-2004, 08:13 PM   #7 (permalink)
Sar
I think I'll wait for that one, thanks for the info
Old 07-27-2004, 01:00 PM   #8 (permalink)
Registered User
WHere did you find out about mounting the servo back on the tail Tabb? Where did you get the CF Frames? Thanks for the info!!
William James
Old 07-27-2004, 03:56 PM   #9 (permalink)
Hey Will, it looks like he just has the tail servo taped to the vertical fin with double sided tape???
Hotshot Charlie is offline        Reply With Quote Quick reply to this message
Old 07-27-2004, 04:49 PM   #10 (permalink)
Registered User
Thats what it looked like or hot glued. I found a bunch of cool upgrades at MJP Carbon. Did you have to swap the tail rotor over to the other side of the boom like hte other guy on RCGroups that is running the AXI did? I just started reading the MANY zoom threads there for like 4 hours today. I am going to put an AXI in my #2 Shogun. Any other tips that could help me would be much appreciated Tabb.
Thanks in advance!!
William James
Old 07-27-2004, 04:49 PM   #11 (permalink)
They arent really CF frames, they are the pieces that come with the Belt Drive kit to rejoin the frame after the install.
I have been mounting the servos on the tail fin on my Hornet 2's for quite some time. Eric Larson I believe brought about this idea on the micros. Gets rid of the long pushrod and ensures a slop free direct connection. Just my preference, some seem to get it to work well in the stock or other locations
hope that helps
Tabb
Old 07-27-2004, 04:50 PM   #12 (permalink)
Registered User
You just Double Stick tape it there on the fin?
Thank you!!!
William James
Old 07-27-2004, 05:03 PM   #13 (permalink)
yeah, you can either use a good double stick tape, or goop (shoe goo is another name I think)
Works good!
Tabb
Old 07-27-2004, 05:33 PM   #14 (permalink)
Registered User
It looks fron your pics like you swapped the tail rotor over to the left side of the boom when looking at the heli from behind. Does this make the blades rotate downword from teh main rotor instead of up into the main rotor wash like it comes stock. If so does this effect the flying?
Thanks again for even more info. I am going for the AXI!! Now gotta get an 18T Pinion for 1/8 shaft and the belt drive. MJP Stuff looks really good as well.
William James
Old 07-27-2004, 07:46 PM   #15 (permalink)
I had it flipped in that pic since I had just put on the belt drive and hadnt switched it yet.
I flipped it initally because of the way I had the pinion setup when using the stock tail drive
The axi is a great little motor!
Tabb
Old 07-27-2004, 07:51 PM   #16 (permalink)
Registered User
So you don't need to flip it with the AXI and belt drive? Cool!!
Thanks for the information, sorry to be a PITA.
William James
Old 07-27-2004, 08:25 PM   #17 (permalink)
nope, dont need to with the beltdrive, I just flipped it since I was running the tail rotor off the opposite half of the pinion as it normally is.
you are not a PITA at all, I am happy to share the info, will save you the growing pains I had to endure along the way
Tabb
Old 07-28-2004, 05:05 AM   #18 (permalink)
excellent thread Tabb, and others I've read through. I want to thank you for your kind words about me, I also want to thank Baja for inviting me here, very cool.
Im really glad the belt drive is working out.. I have a webpage im just about to finish and will post the url as soon as it is up.. It will be basic info for purchase as to lighten up on the pms maybe. :wink:
thanks again guys im back to the shop.
hubdave is offline        Reply With Quote Quick reply to this message
Old 07-28-2004, 05:15 AM   #19 (permalink)
Registered User
Thank you for joining Dave. We are trying to get the most enjoyment out of our Zoom/Shogun helis, and looks like your belt drive is the ticket!!
Thanks again!!!
William James
Old 07-28-2004, 07:50 AM   #20 (permalink)
Hey HubDave,
As soon as I get my Shogun, I will be ordering your belt drive kit !!! Welcome to HeliFreak !!!!
