Old 06-04-2010, 07:21 PM   #1 (permalink)
Default Lost Control 500 3G
Hi all, I am new to the 500 esp 3G, was trying out idle up today, just going up and down fast, then my bird lost power and came to the ground fast, just broke a landing skid, checked it all over found nothing wrong, other than the 3G, there was no lights on? so did a rebind and all is ok now, wounder why it lost its bind? any ideas?
thanks for you thoughts.
Dx 8,Trex 500 FBL, ESC ICE 100. Fullsize V-Bar 5.0
3026-1600 scorpion motor v2.
claywake222 is offline        Reply With Quote Quick reply to this message
Old 06-05-2010, 04:41 PM   #2 (permalink)
This is just an educated guess, but you may have run out of amps for the electronics. Flybarless takes more juice to run the servos.
Two broken Trex 500 ESP helis, one unfinished Outrage Fusion 50, and one MSH mini protos in the mail.
Heechee is offline        Reply With Quote Quick reply to this message
Old 06-05-2010, 04:48 PM   #3 (permalink)
did you still have control of the heli when it lost power? i.e. was it your ESC cutting out.
m1kal is offline        Reply With Quote Quick reply to this message
Old 06-05-2010, 06:19 PM   #4 (permalink)
Are you running a separate BEC for your electronics?
"Keep it pithy."
eAurora, TREX600E, TREX 600 HFEX, TREX500, Vibe 50
(Professional grade pretzel maker).
JesusFreak is offline        Reply With Quote Quick reply to this message
Old 06-06-2010, 04:19 AM   #5 (permalink)
Hi there..
When you crash landed, were u able to move the servos?
If you lost control complete, u might have encountered the same problem I had before, which is the loosen connector. My connecting wire/connector pin was loose during flight, causing me 4 crashes in 2 weeks.
I later on shoe glued both ends of the connector, and the power cut-off problem went away.
Please double check your connector. I hope you are not as unlucky as I was.
Sincerely,
Den
DenDog220 is offline        Reply With Quote Quick reply to this message
Old 06-08-2010, 02:43 AM   #6 (permalink)
Found the problem, was the battery 6S, one of the connectors inside broke away, also had a burnt smell.
Old 06-08-2010, 02:24 PM   #7 (permalink)
Which brand?
Old 06-08-2010, 11:18 PM   #8 (permalink)
They were Mystery 6 cells Lipo battery 22.2v 30C 2800mah, cheap, now I know why.
