Like Tree1Likes
Old 01-23-2008, 03:26 AM   #21 (permalink)
Ive done the same as TomC ...........but will look into the tail pully-M3046
lloyd
lloyd 1 is offline        Reply With Quote Quick reply to this message
Old 01-23-2008, 09:12 AM   #22 (permalink)
Looking for a local source of "graphite" for the belt, I went to a crafts and art supply store. Found there some graphite art rendering pencils. They are called "pencils", but are actually 1/4 inch (about 6mm) square, 4 inches long, and just the bare graphite, not wrapped in wood. They came in various hardnesses (or should I say softnesses). HB is what many would say is soft. These "pencils" came in 2B, 4B, 6B and even 8B, designed for making broad shading strokes on renderings.
They are the same width as the belt, and being so soft, they deposit the graphite on the belt smoothly, enough so that if you run your finger over the belt afterwards, your finger has a light black smudge on it.
For those of you who have never counted, on a stock Logo 600, you have to turn the tail rotor about 40 times to get the belt to go all the way around one time. I know, I need to get a life .
dahld is offline        Reply With Quote Quick reply to this message
Old 01-29-2008, 06:30 PM   #23 (permalink)
Hay fellas, I found a unit to test the tail to see if it produces static. Great way to find out what is going on.
https://www.helifreak.com/attachment...7&d=1201649415
No really my discovery. It is from the gasser forum. But I just reied on my 500 boom and evidently, the boom is creating alot of static. I need to ground everything to everything else.
Eyefly is offline        Reply With Quote Quick reply to this message
Old 01-29-2008, 07:36 PM   #24 (permalink)
I've been reading over there as well. On the Logos we (sadly?) don't have a nice big conductor in the frames. Worse yet, the non-conductive pulleys make it one step further difficult to resolve.
I wonder what made the anti-static tail drive "anti-static". Is it conductive?
I'm just not sure how to electrically connect them short of that copper belt rider that another person set up on the T-Rex, or the Graphit...
Logo 600 3D V-Bar, Jazz 55-10-32, Tango 45-7, 0.7/13T, BLS451/BLS251, JR R921, Maniac623
Logo 500 3D V-Bar, Jive 100+LV, Scorpion HK-4020-1100, 0.7/15T, S9452/S9256, AR7000, RT560
T-Rex 600 CF, Jazz 80-6-18, Neu 1515/2.5D/F/H, 11T, S9451, ds760/S9254, AR7000, Radix600
T-Rex 500 CF, stock ESC/motor/rotors, 13T, HS-5245MG, ds760/S9254, JR R921
th3tick is offline        Reply With Quote Quick reply to this message
Old 01-30-2008, 06:02 AM   #25 (permalink)
I will work on this...
Old 01-31-2008, 01:52 PM   #26 (permalink)
If you think you have static on the boom,
easy fix.
Get a carbon fiber brush, have the fibers brush the belt constantly, mount it, then ground the brush to battery negative and the motor mount.
The carbon brush or a stailess steel brush is the only effective way to nuetralize static build up on a belt. they make these specaily for the application.
http://www.westmontinc.com/faq.htm#faq5
Aberdeen is offline        Reply With Quote Quick reply to this message
Old 01-31-2008, 02:24 PM   #27 (permalink)
I dunno what to say about this. even before I applied some Graphit 33 I never had any static issues show up on any 6003D. I did however apply some to all my 6003D belts because of the threads here but even then I do not see this issue.
Old 01-31-2008, 02:24 PM   #28 (permalink)
Team Taco VP
Hmmmm remember how a Van De Graf generator works... Yes the belt can and does develop a potential BUT.... it is the constant build up of the belts potential onto a metal "tank" if you want to call it that. Without the static build up being stored somewhere the belt can only develop so much charge and probably NOT enough to do anything.
An isolated tail system with metal boom is the TANK and continues to build up and collect the charge from the spinning belt. Don;t think this is just a belt build up problem but more the tail system build up.
Bob
Old 01-31-2008, 02:52 PM   #29 (permalink)
The key is that a Van De Graaff generator requires a dielectric belt to carry the charge. If it's conductive, it won't work. Thus a coat of graphite should be a good cure as well - probably a simpler one than grounding both ends.
John
Old 02-16-2008, 01:42 PM   #30 (permalink)
Shawn, I didn't see this either until it got dry and windy here. The tail started to kick and I'm guessing thats what took out my WR BEC. The graphite lube, while it is messy, just not as bad as nitro, works here. I put it on every other trip out to the field and takes all of a minute to apply.
A Helicopter, Brushless Motor, Esc, Battery, Servos, RX
Ticidytoc is offline        Reply With Quote Quick reply to this message
Old 02-16-2008, 03:06 PM   #31 (permalink)
I spray the Graphit 33 onto a rag and apply on with rag while spinning blades, not messy at all. In fact by the original application point comes around it is dry on the belt and even after a few flights there is no residue anywhere.....
You might be using something different but I can assure you the Graphit33 spray is clean application by rag and is a non messy product while in use. :o
Old 02-17-2008, 10:48 AM   #32 (permalink)
One app of Graphit 33 lasts 100s of flights, works on Trex 500s also.
Flybar-less is offline        Reply With Quote Quick reply to this message
Old 03-11-2008, 12:32 PM   #33 (permalink)
I think we need to find a mechanical solution for this problem and I for one dont want to spray my belts.
Any comments?
Not Sponsored= Not Biased
t-rexn8 is offline        Reply With Quote Quick reply to this message
Old 03-15-2008, 03:11 AM   #34 (permalink)
You don't really spray the belt, you apply to rag and wipe on thin layer. It does not deteriorate the belt in any way at all, it was designed for it, and as John states it last hundreds of flights. This is not a WD-40 type stuff or anything like that. I am sure you could ground this, ground that like peeps are doing with the t-rex 500 but I don't see the point of all that. The static issue on the 600s is not that big of a deal, I didn't even see it before applying Graphit 33 to be honest, I just did it as a pre caution based on a few people seeing static on the big boom. The reason some are seeing the static in dry conditions imho is due to the belt material and the large boom, I know they are working on it at Mikado but they want a 100% solution, now is that a different belt or what... at this point I do not know, all I know is a wipe of Graphit33 does the trick for now.
Old 03-25-2008, 01:51 PM   #35 (permalink)
I bought 2 cans of Graphit 33 from Bonzai Musical Effects, about 2 week delivery to Texas.
www.banzaieffects.com
I also talked to a US RC products distibuter who is looking into importing this product.
Old 03-30-2008, 12:28 AM   #36 (permalink)
Good flying with you today John!!! I just placed an order for Graphite 33 from the website you listed. $28.63 total for one can shipped from Germany.
Just a guy and his heli....
LITHIUMSTATIC is offline        Reply With Quote Quick reply to this message
Old 04-19-2008, 05:24 PM   #37 (permalink)
Hi all,
Shawn where are you getting the graphit 33? Is there somewhere local (here in Canada) that stocks it, or did you order from overseas also? Got 3 packs through my new logo and would hate to see it destroyed because of a little static.
Thanks,
Conway V
Scene From Above Photography
www.scenefromabove.ca
Gaui X7 Cameraship
SFACV is offline        Reply With Quote Quick reply to this message
Old 04-20-2008, 04:09 AM   #38 (permalink)
Got it from Real Raptorz UK a year ago or so. If you are going to SHAG funly in a few weeks in Saskatoon let me know, I'll bring it and we can treat your setup there.
Old 04-20-2008, 05:18 AM   #39 (permalink)
I had to re-apply to one heli after about 200 flights. The outside of hte belt was still dark and shiny, but the edges were really needing it.
Old 04-20-2008, 02:59 PM   #40 (permalink)
Thanks Shawn,
I haven't decided on Shag yet (not likely) but appreciate the offer. I will likely just order some, I like to own stuff. LOL Probably will have other uses for it once I get it as well.
Conway V
Gaui X7 Cameraship
