Old 09-19-2008, 09:34 AM   #41 (permalink)
I usually fly in temps that range from 70-95+F, typically over 80F. This is why I could not get away with the 16t as the batteries were just too hot.
Currently running one old FP25 (coolest temps, but power drop in 2nd half of flight) and one older and two newer (thicker) Evolite 5350's. The Evolite's offer consistent power throughout the flight but do come down hotter if there are higher ambient temps and/or flown hard. (I'm not noticing a difference between the older/newer Evolites.) As my skills are improving, I'm demanding more of the power system and seeing where the limitations are.
Looking forward to your report!
zguy is offline        Reply With Quote Quick reply to this message
Old 09-22-2008, 04:41 AM   #42 (permalink)
oicu812, what blades are u guys running 550mm?
allistar is offline        Reply With Quote Quick reply to this message
Old 09-22-2008, 11:19 AM   #43 (permalink)
Yes 550mm on the Vstabi machine and 560mm RTs' on the flybar one.
Old 09-22-2008, 11:50 AM   #44 (permalink)
Same here...560mm RTs' on the flybar. Great blades!
Old 09-23-2008, 12:53 AM   #45 (permalink)
think a jazz55 will work with this motor on 6s?
they seem to be able to take a beating on 10s but i guess the current is lower then?
Old 09-23-2008, 12:54 AM   #46 (permalink)
I would not, jazz 80 at least
helicraze is offline        Reply With Quote Quick reply to this message
Old 09-24-2008, 01:07 PM   #47 (permalink)
For folks using this with a Jive, did you use the 4mm plugs on the jive wires (which are BIG), or replace the 4mm on the motor for bigger ones?
John
Logo 600 3D V-Bar, Jazz 55-10-32, Tango 45-7, 0.7/13T, BLS451/BLS251, JR R921, Maniac623
Logo 500 3D V-Bar, Jive 100+LV, Scorpion HK-4020-1100, 0.7/15T, S9452/S9256, AR7000, RT560
T-Rex 600 CF, Jazz 80-6-18, Neu 1515/2.5D/F/H, 11T, S9451, ds760/S9254, AR7000, Radix600
T-Rex 500 CF, stock ESC/motor/rotors, 13T, HS-5245MG, ds760/S9254, JR R921
th3tick is offline        Reply With Quote Quick reply to this message
Old 09-24-2008, 09:09 PM   #48 (permalink)
KTH
John
I managed to get the 4mm on the jive 100 wires but I had to heat the wire to do it, bunt my fingers a little too .
-Keith
KTH is offline        Reply With Quote Quick reply to this message
Old 09-24-2008, 09:35 PM   #49 (permalink)
You can use a dremel to make the ends smaller, just a few quick touches with dr dremel and you can fit it into any end you like.
Old 10-01-2008, 09:42 PM   #50 (permalink)
Anyone else here having KV issues with this motor? I mentioned it on another thread, but didn't get much response, so I thought I'd check here.
On my Jive 100+LV set at 75%, 16T pinion, I'm getting over 2600 head speed. Calculating that out, I'm over 100% efficiency. I'm guessing my motor is hotter than 1100KV, but I'm wondering if anyone else has seen this, or has any other ideas what might be going on.
John
Old 10-01-2008, 10:43 PM   #51 (permalink)
John
Sounds like you somehow got a 1390kv one or something, I would contact Scorpion or who you got it from and get the 1100. At that % mine is more around the 2300 tops mark.
Old 10-02-2008, 04:45 AM   #52 (permalink)
Well got my 4020 1100KV motor today, installed the motor (removed the old 40/10L 8P) both were running 15T pinion.
RPM seems to hold better under load. Only got 1 quick flight in.
Seems like a good motor.
Old 10-03-2008, 09:16 PM   #53 (permalink)
Shawn would the Scorpion 1100kv but a upgrade to the Z-Power 1100 that I have now?
Align Trex 700 V3 DFC HV - Vcontol Touch ¦ Mikado Logo 200 ¦ SAB Kraken 580 ¦ Align Trex 500X ¦ Sab RAW 500
Raydee is offline        Reply With Quote Quick reply to this message
Old 10-03-2008, 09:39 PM   #54 (permalink)
The z power 1100 works great. Good power to flight time (5 1/2 minutes about). A good compromise. The scorpion may give a bit more power but you'll trade that for flight time. There's always a trade off with the electrics. I see some guys with super hot set ups but 4 min flight time or less.
jizammy is offline        Reply With Quote Quick reply to this message
Old 10-03-2008, 10:45 PM   #55 (permalink)
The scorpion is "very" efficient imho, you will get more power and still get same flight times as the Z1100, "I have them both". The scorpion is a much higher quality motor then the Z.
Old 10-21-2008, 03:18 PM   #56 (permalink)
have any1 tried the neu 1910/1Y in a L500?. how is it compered to the hk 4020-1100?
clayboy is offline        Reply With Quote Quick reply to this message
Old 10-21-2008, 04:54 PM   #57 (permalink)
Had one; loved it. Tended to overheat the Jazz, and the Jive controller wouldn't power on with it. Thus, came here.
Old 10-21-2008, 09:22 PM   #58 (permalink)
One of the last few posts caught my attention. While I do want to eventually have a 'hot' setup, I'm still in the sport flying stage and was wondering if going with the 4020-1100 would be wasteful flying time wise. I know motors are governed by a bunch of different characteristics, but I noticed the Hacker A40-10L has a lower no-load current, 1.7A, compared to the 4020-1100, 2.45 A.
~Dan
Ninjak2k is offline        Reply With Quote Quick reply to this message
Old 10-21-2008, 09:49 PM   #59 (permalink)
I ran the 40/10L and then went 4020 1100KV and did not notice difference in flight time, timer is still set the same.
Old 10-21-2008, 09:54 PM   #60 (permalink)
I had to drop my timer by 20 seconds but that is only because the Scorpion gives so much reserve power on tap that harder 3D moves will use that and drain the power more. If I just flew around and did really light 3D to simulate how I flew with the Hacker I'd probably get more time with the Scorpion. Now I find myself doing more punch outs and harder 3D because its more fun and that takes the power.
Logo 500 3D /Scorpion HK4020-1100KV (16T)/Jazz80/BLS451/Spartan DS760/BLS251/RT 560mm/AR9000
TRex 450SE
/Scorpion HK-2221-8 (13T)/ AlignESC35(X)/ HS65MG/Spartan DS760/S9650/AR6100
Spektrum DX7
BruceW is offline        Reply With Quote Quick reply to this message
