Odin and 3D+ Compass Odin and 3D+ Model Helicopter Discussion |
08-24-2011, 09:57 AM | #1 (permalink) |
regulator
hi. I want to use a regulator on my compass 3d+. I will be using a v-bar, jr 8717 and 8900g tail servo. I already have a scott gray regulator but i would prefer something with less wires, something with an input(dean) and an output at 6v.
I was looking at the cc bec pro or the arizona regulator. How many amps a set-up like mine can draw? the cc bec pro is rated at 20 amps and the arizona, i did not find the specs. Any suggestions or other regulators ??? I am using life batteries but would like to return to lipo!!! |
08-24-2011, 10:36 AM | #2 (permalink) |
something like this maybe...
http://www.readyheli.com/Gryphon-Duo...r_p_37006.html or this... http://www.readyheli.com/Gryphon-Ext...r_p_37005.html Which receiver are you using anyway? What are you doing for governor? For less wires overall it is suggested to use AR7100R receiver with built-in rev limiter. it also has a built in regulator for tail and throttle but if you're running BeastX for example you can't really use the 5.2V tail output on the receiver. There are 2 connections from 7100R to BeastX which will supply 8.4V from 2S Lipo directly and tail servo would be getting the same voltage. The way I'm doing it right now is running the 8717s on direct 2S Lipo and have a high voltage tail servo. The way I plan to do it in the next couple of days is to run that 2 channel Gryphon voltage regulator between the 7100R and BeastX which will provide regulated 6V into the BeastX and run everything on that voltage essentially. Or another option is to regulate the voltage on the tail servo only. The other good thing about the 7100R is the rev limiter. The sensor attaches to the back plate of the motor and you're good to go. If using other governors it is necessary to do some modifications and custom fitting of the sensor I believe. There are so many options really but you have to plan beforehand and order what you need. Scott Gray X2 is great but it might be tricky getting it to work with 7100R receiver. However if you have a regular receiver just get it to work with X2.
08-24-2011, 10:45 AM | #3 (permalink) |
Hi, I can't really answer your question (sorry) but I have one for you if I may.
Why exactly do you wish to return to LiPo? Was there something about LiFe that you didn't like?
Airtronics SD10G, SK540 Synergy N5c, Novarossi .57 3DS MAAC #85462 |
08-24-2011, 11:12 AM | #4 (permalink) |
regulator
i have already used a 7100r on a flybarred heli but now i want to use the v-bar with 2 satellites( no receiver). So i want a regulator with an imput and an output that will plug in my v-bar at 6v. The v-bar will supply voltage to all my servos.
Nothing wrong with the life packs. It is just that it is harder to monitor voltage. Life batt have a different discharge curve making it harder to monitor. I will be using a dx-8 with telemetry so it would be easy to keep an eye on the lipo's voltage. |
08-24-2011, 12:37 PM | #5 (permalink) |
Well, ok. I understand what you mean. I am running BeastX and it can get it's power from servo lines via the receiver. I also have a mini Vbar and was just looking at the manual. They're suggesting to supply power via RX B or RX C channels. And that's the way I do it on my Logo.
Western robotics Mini Super BEC should work ok. You can set the output voltage to 5.2v or 6v and it has 2 separate wires for dual input into Vbar. Will supply both RX B and RX C with 6V for redundancy. And you don't have to use X2 and run everything at 6V with satellites. WR will be much more reliable than CC. The only concern is supplying the BEC with only a 2S Lipo. These are designed to run on 6S. It should work fine I think but maybe better to use a 3S receiver pack.
08-24-2011, 01:28 PM | #6 (permalink) |
regulator
a 10 amp regulator will be enough for my system???
What about the arizona regulator??? is it good |
08-24-2011, 01:49 PM | #7 (permalink) |
Sorry, never used Fromeco Arizona regulators but it does look interesting and is designed for 2S Lipo. Maybe it's your best bet then. Since WR spec says from 3S to 6S. 10amp will be enough.
08-24-2011, 03:34 PM | #8 (permalink) |
I run a perfect regulator on my 3D+ nitro setup with vBar. I've never had any issues with any of their regulators I have used.
They have many choices for they type of regulator you can use. http://www.perfectregulators.com/
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep. |
08-25-2011, 07:37 AM | #9 (permalink) |
WR makes an excellent BEC and is highly regarded in many circles.
On my 3DPlus, I'm running the Skookum Powerbus. |
08-25-2011, 08:06 AM | #10 (permalink) |
regulator
just by curiosity, is there a problem with the cc bec pro? i know there are some problems with their esc but what about bec pro?
08-25-2011, 01:22 PM | #11 (permalink) |
had seen a few references of them burning out and taking all electronics down with them. when it fails it sends the voltage straight from the battery and burns everything.
