Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 09-17-2010, 03:22 PM   #61 (permalink)
Default Kind in a candy shop!
www.rcpak.com
dards is offline        Reply With Quote Quick reply to this message
Old 09-17-2010, 10:07 PM   #62 (permalink)
Been away for a couples of days..Here comes the TmMugen's poison again..
My "self proclaimed" mini studio shoots of the X50..
Kasama Srimok 90: JR8917HV all round | YS91SR | Hatori 946 | Spartan Quark | BLS251
http://nitro-magic.blogspot.com
TmMugen is offline        Reply With Quote Quick reply to this message
Old 09-17-2010, 10:19 PM   #63 (permalink)
Closer shots..
Old 09-17-2010, 10:26 PM   #64 (permalink)
Paging for all X50 potential owners..:z
Old 09-17-2010, 10:32 PM   #65 (permalink)
Last set to go..
Old 09-17-2010, 10:43 PM   #66 (permalink)
Just a teaser..Meant to be a joke among our group of fliers. The second pics seems like the guy is "praying" to the heli.
Old 09-17-2010, 10:59 PM   #67 (permalink)
Pics taken by STS..
Old 09-18-2010, 01:43 PM   #68 (permalink)
Thats 1 beautiful bird I got to save for mine cant wait love the red belt
Jerry
AMA # 891553
SpekTrum DX8
ghostrider414 is offline        Reply With Quote Quick reply to this message
Old 09-25-2010, 08:16 AM   #69 (permalink)
decided to do some PP to it..
Old 09-25-2010, 07:38 PM   #70 (permalink)
That is sooo Fricken nice, I would be afraid to fly it!!, great job!.......
Raptor 50 Titan,Align Trex 450 Sport V2, Blade 500X, Blade Mcpx V2,Blade 180 CFX,Traxxas Aton Quad,Blade 230S,Mia Microflight Gyro Copter,Jr 8103, Spektrum DX8,Spectrum DX7g2...
VortechZ230 is offline        Reply With Quote Quick reply to this message
Old 09-26-2010, 09:45 AM   #71 (permalink)
The party of TWO..Next week will be FOUR. :ts
Old 10-06-2010, 07:03 PM   #72 (permalink)
Really nice reveiw!! We actually just got these kits instock iam dien to get one built
BobbySmith is offline        Reply With Quote Quick reply to this message
Old 10-17-2010, 10:18 AM   #73 (permalink)
Guys..been flying this X50 for a while..I found that while it is light and powerful, there seems to be some CCPM interaction during the flight..
How do I know? It is because during my flight while I am doing my four points tic toc, the heli nose pointing 9 and 6 o clock is moving away (I can't seems to keep it straight facing me). Even when I started to do it from 3 to 12 o clock, I can feel some interaction..
Some might said that it is my fingers..but while I am doing the same stunt with other heli, I managed to pull of the stunt pretty well..
Wonder if there is any advice?
Old 11-18-2010, 08:02 PM   #74 (permalink)
Default Tip for cables
Hi Tim and all
I notice, Tim, that you have some cables exiting the frame through the round hole just forward of the main shaft. I have the same.
I found some spare 90SE tank grommets that are identical to those used in the frame of the X50 to get the fuel line through .
Probably a bit late now but they look real nice and are kind to your cables.
Just a thought. Nice build too Tim
Ian
Practice doesn't make perfect. It just makes you quicker at doing it wrong.
CrazyJim is offline        Reply With Quote Quick reply to this message
Old 11-19-2010, 11:47 AM   #75 (permalink)
Default X50 interactions
Hello,
First of all .. use 140 degrees eCCPM. The 140 degrees swash control has is a big advantage over the 120 degrees eCCPM. Take a sheet of paper and make a sketch showing a circle.. make some point on the circle at the back position (related to flight direction) and at 120 degrees on circle 2 points for the aileron .. now its pretty easy to see, that the back point (relates to elevator control of swashplate has one radius to the centre (=main shaft centre) .. meanwhile the 2 aileron points have only half of radius distance when applying elevator input..
That's exactly where the 135 degr. or 140 degr. swashplate arrangement jumps in.. you will have even swashplate tilt at the 135/140 degrees eCCPM when applying elevator input from the aileron servos compared to the elevator servo. So 140 degrees eCCPM is way more even swashplate control .. this improves not only by having more even swashplate control for collective and cyclic, then improves interactions as well..
There are 2 kind of Tx to correct for interactions and phasing: low cost Tx and medium to high cost Tx.
- low cost Tx: (e.g. Fut T6, T7, Spektrum Dx6, Dx7 etc.) you can only use endpoints for the 3 cyclic servos and using a swashplate alignement tool having the swashplate being in the up/ medium/ down position to be lateral (in elevator and aileron direction) to the main shaft .. there is no Tx-feature to correct for interaction or phasing ..
- medium to hig cost Tx: there are software features to correct for lateral collectiv-movement, interactions at min./max. collective and phasing ..
How to find out and correct when flying? First trim your heli in hoover (=collective in the middle more or less) and set-up your gyro for the best possible:
- climb horizontally at full collective (and full negative = inversed) and observe where heli tends .. e.g. heli tends to the right/ left and/ or for/ backwards .. correct servo endpoints (cyclic servos) accordingly for full/ full negative .. (this is about interaction aile/ elevator to full/ full negative pitch)
- correcting for phasing is completely different: make half of a flip.. and if heli's tail (on its back) is not in the same plaine, it's a phasing issue .. if heli is hanging towards one side (aileron axle) it's a gyro issue .. there is a very good post here on HF of an experienced guy describing this issue ..
Phasing is way more difficult to find out than interactions .. you will have to play around with virtual swash tilt function (not available on low cost Tx) until you find the right correction ..
Reading all of this, it should become clear to beginners and average pilots, why eCCPM is not that big miracle, it is sold by manufacturers marketing ..
Is all of this a problem? It depends.. one of my buddies is that good in collective and cyclic skills, he will correct any unwanted movement .. for everybody else if you do not want any complex corrections you can:
- eihter buy and use a mechanical swash mixing (yepp, the Raptor had that) ..
- install a FBL-system that actively corrects ..
Maybe now it becomes clear, why many people changing to FBL are so happy .. FBL overcomes the drawbacks of eCCPM manufactures tried to tell us the last 4 years being the best?
Best Regards,
Oliver
P.S: There's nothing easier than a light-weighted mecanical CCPM, real modular helicopters (no servos in the side-frames) and linear carbs with no interactions .. unfortunatelly the trend is opposite .. and as long as websites as rc-heliresource are all about pushing sals without using our brains .. we are dead-meat
Raptor30_V1 is offline        Reply With Quote Quick reply to this message
Old 11-19-2010, 04:04 PM   #76 (permalink)
Default X50 Blade grips
Just setting up the blades on my, as yet unflown, X50.
Noticed a lot of play in the grip. ( Thrust bearings oriented correctly )
After measuring I found the bore for the bearing closest to the head up by 0.05mm on the bearing.
Doesn't sound like much but by the time you get that out to 600mm it's a whole lot.
Grabbed a couple of stock 30V2 grips and checked them. They were the correct bore.
Had to drill them out to 8.5 through the centre as the new feathering shaft is larger.
Much better.
I will drop a quick line to TT to bring them up to speed.
Ian
Old 11-19-2010, 04:17 PM   #77 (permalink)
Originally Posted by TmMugen View Post
The head was a no brainer. Very fast to build..!! Hopefully I locktite all the screws. :z
Hi Tim,
Did you notice the orientation of the ball cup at the end of the arms to the swash from the washout ( as in the pic ). Mine were reversed. That is to say the wide part of the cup was facing out from the swash. As these parts have rotational symetry of 1 I could not orient them any other way than they are ie the same as yours. Just wondered if yours were the same or I'm goin crazy...
Best regards
Ian
Old 11-30-2010, 04:27 PM   #78 (permalink)
put that in english?
Mikado 550sx, TT X50N, Align 470L
johnbs8 is offline        Reply With Quote Quick reply to this message
Old 11-30-2010, 06:54 PM   #79 (permalink)
Sorry about that seemed confusing when I read it back.
Ok. The ball link at the end of the washout linkage BK0016-1 has the wide part of the linkage facing out ( ie the link end that goes on the ball at the swash ) These should, as per all links, be fitted with the wider opening towards the ball.
The Washout linkages on mine are not correct
Hope that makes sense
Ian
Old 11-30-2010, 08:30 PM   #80 (permalink)
makes much more sense now lol ty for clarifying. how were yours not right and the fix?
