Old 03-10-2013, 04:01 PM   #61 (permalink)
Originally Posted by karl k View Post
That's an interesting tail grip design. Is that spare bolt in the base of the grip for balance? I wonder what the rationale of having that there is.
Yep, integrated Chinese weights. Means tail pitch movement balances itself, in short.
RAW 420 / RAW 580 / Kraken 580 Nitro / Goblin 700 / 2x RAW 700 / Kraken 700 S
VBC-t & Neo Pro / Scorpion motors & ESCs / MKS HBL575 SL & HBL980 / Supra X D4, D6 & S6 / OptiPower / Revolectrix 2x Bump & 5x PL8v2
https://www.youtube.com/kjoer
kjoer is offline        Reply With Quote Quick reply to this message
Old 03-10-2013, 04:26 PM   #62 (permalink)
As with previous videos, head speed sounds like only 2150rpm yet the heli moves quick. I wonder what it will be like with 2300rpm.
I'm curious what the motor was. Looks like a Xera. I hope its not a really low KV that you can't find other motors in.
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 03-10-2013, 04:28 PM   #63 (permalink)
It's a Xera 4530 Probably the 500 KV Verrsion ...
Greets, Michal
michalp is offline        Reply With Quote Quick reply to this message
Old 03-10-2013, 04:30 PM   #64 (permalink)
Witnessed Dario's flight(s) at ROTOR live 2013 in Germany in person this weekend. One of the best crowd pleasers.
Seen two Protos 700's pre-production machines up close too and had a chat with Corrado a bit.
One way bearing is located in the pinion, as familiar, but the motor has a 3rd bearing in the motor mount itself, rather unconventional. He said this and the unconventional supported tail shaft allow the belt to be removed by just removing the 3rd main shaft bearing block.
Also, when I asked how long the belt would last, Corrado said it would last about 30 flights in Dario Neuenschwander mode and about 100 flights for most people.
He also said the kit will likely come without blades (since they're expense at this size), allowing the customer to pick/buy them separately.
Old 03-10-2013, 05:46 PM   #65 (permalink)
For the Chinese weights, aren't they normally in line with the tail blade bolts?
karl k is offline        Reply With Quote Quick reply to this message
Old 03-10-2013, 06:29 PM   #66 (permalink)
Yeah, no point putting them in the same plane as the blades.
PRÔTOS 500 Plastic, Logo 550SX/600SX, PRÔTOS Max2 up and flying!
Team MSH USA, Team Cyclone, Team Xnova
trickybit is offline        Reply With Quote Quick reply to this message
Old 03-11-2013, 02:02 PM   #67 (permalink)
Is the canopy going to be held on by magnets? Notice the canopy posts and the large silver item at the center. Brilliant idea if true and they can withstand fast backwards flight. Matt
byHISgrace is offline        Reply With Quote Quick reply to this message
Old 03-11-2013, 02:06 PM   #68 (permalink)
jes hold by magnets,, its removed in 2 seconds and on in 1 very easy
silverbullet is offline        Reply With Quote Quick reply to this message
Old 03-11-2013, 02:33 PM   #69 (permalink)
ddhuans is offline        Reply With Quote Quick reply to this message
Old 03-11-2013, 03:27 PM   #70 (permalink)
Only 100 flights?
Sounds like a bad joke..
almigurt is offline        Reply With Quote Quick reply to this message
Old 03-12-2013, 06:06 AM   #71 (permalink)
Hello,
Originally Posted by almigurt View Post
Only 100 flights?
I heard "at least 100 flights", not "only 100 flights" ... with low price and less than 5 min to swap it (the design is made for it, no need to move tail boom or rotor, just the third bearing, and you can swap the belt in seconds).
I consider it a lot better than having to change gears every 50 flights on some mecanics ...
Thomas.
Otatiaro is offline        Reply With Quote Quick reply to this message
Old 03-12-2013, 06:28 AM   #72 (permalink)
Originally Posted by Otatiaro View Post
Hello,
How "low" is the price?
Old 03-12-2013, 07:51 AM   #73 (permalink)
they say that they still testing some diffrent belts.and its thrue the design is really easy to swap the belt, maybe 5 minutes only i seen it myself.Also the price is really good on belts, i cant thell you how much but it will be really low,no worrys
by the way Tareqs words when he did some flights ; this will be the new 700 killermachine ,,
Old 03-12-2013, 08:10 AM   #74 (permalink)
So where are the pictures of this????
Old 03-12-2013, 08:53 AM   #75 (permalink)
To be honest, this bad ass heli is the one which I just want to swap from my logo 600 after 3 years flying . But I am doubting the MSH's capability of production, in fact the spare part of Protos 500 is always outstock on the shelves, so don't know whether the same situation will be with the 700
-Logo 600SX, Full size Blueline 5.3 + BLS 256 HV, Cyclic Fu BLS 252 powered by Life 2s 6.6 V, HK III 4035 - 500 kv + Vbar Gov, YGE 120 HV
brain is offline        Reply With Quote Quick reply to this message
Old 03-12-2013, 11:35 AM   #76 (permalink)
Lack of Protos 500 spares on some shop shelves i am afraid has nothing to do with our production capability that is more than enough
Corrado
www.msheli.com
HighFreq is offline        Reply With Quote Quick reply to this message
Old 03-12-2013, 12:51 PM   #77 (permalink)
@Corrado, what are the teeth count on the main gear, pinion and tail pulley?
Old 03-12-2013, 03:44 PM   #78 (permalink)
You'll bring me a piece of Protos 700 to Grossalmerode meeting will you?
how much is it by the way?
Old 03-12-2013, 06:34 PM   #79 (permalink)
I didn't take any, but there should be plenty on the net.
Old 03-12-2013, 07:51 PM   #80 (permalink)
Dunno where your from but in the USA I can get any protos or mini protos part from a dozen shops that ship whitin 24 hours. If your expecting your local hobbytown USA to stock protos parts, don't hold your breath.
branmuffin is offline        Reply With Quote Quick reply to this message
