Go Back   HeliFreak > R/C Electronics Support > Thunder Tiger GT5 FBL System
Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics
Old 05-15-2012, 05:58 PM   #21 (permalink)
thanks for all the help... did it with the beastx so im thinking the servo is bad or i need to run a seraperat bec
codfish124 is offline        Reply With Quote Quick reply to this message
Old 05-16-2012, 11:46 AM   #22 (permalink)
Just finishing up my Mint Titan with the GT5,curious to see how it goes with it. I have used and we still have a fellow flying my Old Trex 550 with a GT5 and its great on it.
Reever45 is offline        Reply With Quote Quick reply to this message
Old 05-16-2012, 11:50 AM   #23 (permalink)
I am beyond happy with my mini titan and gt5. Finally am getting it tuned. Just got to fine tune the tail settings a little more. All in all I absolutely love this gyro. Wery very stable in hover and it flips and rolls so fast. Like I said before your tail has to be perfectly put together with nothing loose. Fixed all my issues
Sent from my DROID X2 using Tapatalk 2
Kyle Thomas. Compass Models USA Rep | ProStar Hobby | Compass Chronos | Compass Warp
Falcorma is offline        Reply With Quote Quick reply to this message
Old 05-16-2012, 08:44 PM   #24 (permalink)
I have the same heli and gt5 gyro. I was planning on ordering savox servos for cyclic but I don't want to have to use a separate BEC. Which ESC are you using? I am going to use the stock Ace one that came with the kit, do u think it will need a BEC with savox servos?
T-Rex 500, DFC, BeastX FBL
T-Rex 450, DFC 7200BX
130x HP08s, mCPx BL
Nano CPx Mild Brushless
salmans21 is offline        Reply With Quote Quick reply to this message
Old 05-17-2012, 10:48 PM   #25 (permalink)
I'm thinking a sbec will do it I'm running the ace esc I haven't tryed to do any thing with esc programing yet ether
Old 05-19-2012, 11:04 AM   #26 (permalink)
Default gt5
Is your gyro gain icon in the black background? if not, it will make a difference. paul.
paul nathalie is offline        Reply With Quote Quick reply to this message
Old 12-16-2013, 10:50 AM   #27 (permalink)
Default setup MT e325S GT5.1
Hi
Ute this setup and it will fly....
AKTUELLES Setting MT E325S
Swashplate
P 89
I 77
I D-stick 81
D-sense 25
Feed Foreward 92
I-lim 18
Hover 5
Tail
P 75
I 70
D-sense 22
Tail-D-DB 25
Tail Assym 0
Tail-Dyn 50
DMA -Pitch 0
DMA-cyclic 0
Smmoth stop 0
Pitch 100
Ail 90
Elev 90
Servo
Tail typ 1500 (Hitec HSG5084MG)
Tail sek 0,051
Tail-Freq 333
Sw-Plate 120°
SW sek 0,051(Turnigy S306G)
SW-freq 200
greetings from merry old germany
syberbruno is offline        Reply With Quote Quick reply to this message
Old 12-17-2013, 07:43 PM   #28 (permalink)
I just got the new FBL mini titan im useing the gt5 and savox servos.. after a hard learning curve im startting to figor this thing out....
7410
cyclic seems to be ok now from what i can test on it since my tail keeps kicking. is there some way to ajust the gain of the tail?? or is it all done with the P and I thing cause on my 8fg it the same wether im at 0% or 100% nothings changeing. pleas help thanks
It could be a mechanical issue in the tail, a tail servo or the gyro.
What kind of servo are you running on the tail?
I'd unhook the rudder push rod loose from the rudder servo and move the rod back and forth to make sure there is no binding anywhere. You can still have binding under load that doesn't show up here however. If there is none you might try a Futaba S9257 on rudder if it will fit. I've had very extremely good luck with that servo.
Make sure your belt is not slipping.
You 'll need a BEC but that's not going to solve the tail issue I don't think.
I recommend finding the stock settings for the GT 5 in the Mini Titan manual and start with that. The P and I gains may be a tad soft but not much. As well set everything else back to the default settings, everything.
If its not at least flyable then there is a problem with the servo or tail mechanism. When you start adjusting a lot of different stuff things can get crazy.
If its fixed don't break it!
