Old 06-26-2014, 01:15 AM   #1 (permalink)
Default Solder horizon hobby brushless esc to board?
I have the horizon brushless kit and the wiring is a bit messy and excessive. I've seen how the asteroid design kit has the esc power wires go right to the board (under the yellow bit). I think no can do that with the HH kit, right?
RyanRC is offline        Reply With Quote Quick reply to this message
Old 06-27-2014, 05:06 PM   #2 (permalink)
I pushed my motor w/o paying attention to the wires now i am trying to pull it out and its hard to. I'll take a picture when i get a chance.
TREX 700XN 👍🏼 / TREX600n FL HEAD\ Logo 550sx 2017\XL POWER SPECTER 700\TREX 470\Vbar NEO/VBAR CONTROL👌🏼😎Citizen 789😎 DX6I RF 7.5 ( BLADE 130s oh yeah!!) ()
doubletap is offline        Reply With Quote Quick reply to this message
Old 06-27-2014, 05:42 PM   #3 (permalink)
Default Re: Solder horizon hobby brushless esc to board?
See if this makes any sense. There's a stock esc under the tail esc. Adding the short pigtail wires to the motor plug helps big time, should have had it that way from the factory.
ID:	518676   Click image for larger version
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote Quick reply to this message
Old 06-27-2014, 06:33 PM   #4 (permalink)
Is that stick esc the HH esc that comes with the bl kit? I have thought about taking he shrunk wrap off. What for it do other than trap heat?
What gauge wire is that? I suppose that helps get more current to the motor.
Old 06-27-2014, 06:58 PM   #5 (permalink)
There are two esc's there, front one is an xp3a for the brushless tail, behind that is the stock HH esc. 24 gauge wire from the battery connector to the esc's.
It's getting a Mild V2 kit installed now because the factory brushless lacks power on this heavy nano.
Didn't see a night and day difference with the bigger wire, the little inrunner motor can only put out so much power. If any of the battery wires to the esc are damaged or frayed, upgrading the wiring might make a huge difference though.
Doesn't fly too bad
20140623190323 (3 min 30 sec)
doesn't hold a candle to a 31 gram rtf mild v2 though!
Old 06-28-2014, 01:07 PM   #6 (permalink)
@Dylwad
nice so what kind of tail motor ??? mcpx bl? also ive been thinking of trying to tote 2 batts one on just the HH bl esc and the other on the board + tail motor . to see if it helps the main motor bog.... I havent tried it yet.
Nano cpx ... mcx2...Devo-10 tx running deviation firmware
Hondawasaki is offline        Reply With Quote Quick reply to this message
Old 06-28-2014, 03:03 PM   #7 (permalink)
Originally Posted by Hondawasaki View Post
@Dylwad
This brushless tail kit http://astroid-designs.myshopify.com...-the-nano-cp-x with a 47mm lynx tail blade for the BL
2 batts is a bad idea, too heavy. Just get good batteries like the oversky 200mah 35c and treat them right.
My main trick for a good flying nano is getting rid of vibrations, and keeping it as light as possible.
Old 06-28-2014, 05:28 PM   #8 (permalink)
Looks like you also ditched the brown wire and plug and wired to directly to the contact. The plug is one wire that splits, right? Both contacts not needed?
Old 06-28-2014, 06:13 PM   #9 (permalink)
The signal wire only connects to the positive motor output terminal. The wire doesn't split, the negative pin on the stock plug is just covered in shrink tube.
Old 06-29-2014, 01:17 AM   #10 (permalink)
So today i was able to do it ryan...
Thanks again.
Old 06-30-2014, 12:40 AM   #11 (permalink)
Brushless motor cap popped off... Any remedy to this problem?
Thanks.
Old 06-30-2014, 12:43 AM   #12 (permalink)
Glue it back on after you clean it, I think they used Loctite from the factory (bearing retainer) a good CA or epoxy would work too.
Old 06-30-2014, 01:14 AM   #13 (permalink)
The problem is i lost it... Right now i installed back the stock..
Old 06-30-2014, 01:52 AM   #14 (permalink)
time for a new motor
Maybe start a wtb thread for burnt up BL tail motors, I think they use the same end cap.
Old 06-30-2014, 03:19 AM   #15 (permalink)
8 packs old! 😂 i checked and its out of stock.. Will be flying with the stock motor for now..
Thanks.
Whats your thought on blade 103x?
Old 06-30-2014, 12:39 PM   #16 (permalink)
8 packs old! i checked and its out of stock.. Will be flying with the stock motor for now..
Thanks.
130x is a gamble, it's like caviar, some people can afford it and have a taste for it, and enjoy the hell out of it, some people want to puke at the sight of it because it tastes like expensive fish bait. I lean more towards puke unless it's a full scratch build with almost no stock parts.
Old 06-30-2014, 12:54 PM   #17 (permalink)
Thank you.
Been thinking of getting it before 500 dfc, i live in the suburbs i want something small and
Enjoyable no need to drive to flying field. Might search for better one then.
B.
