Old 08-13-2011, 10:12 PM   #1 (permalink)
Default Kontronik made it right with the HELIJIVE, and new v bar sensor and gov
I went to Ircha and met with Kontronik personally today, they apologized and said they will fix this, and they did.
They gave me another helijive and looked out for me, they fixed the other problem I had, that had nothing to do with them, NO ONE SHOULD USE MODE 8. The fix will come from both sides, the new governor mode on the v bar will be 5.2, (in case no one knew when they change from 5.17 to 5.18 there are minor changes when they change from 5.18 to 5.20 these are bigger changes.)
You can use the bailout on the helijive, I FLEW THE HELIJIVE ALL DAY in mode 4 of course. VERY IMPORTANT if you are programming a helijive in any mode when you pull the jumper out and then go into programming and let's say your programming mode 4 and you hear 4 beeps than move to high stick once it recognizes mode 4 you DO NOT MOVE THE STICK DOWN this is only used for bail out.
You will have to send the helijive in to Kontronik when the update is available it might come when the v bar is updated, maybe a little later, 5.2 should be out in a couple of weeks and is simpler, it also has a saftey feature, so if you plug your heli up first and the radio is not on it will not ARM nor will it spool up this is a saftey feature they added.
There will be a new sensor for the v bar even less prone to vibes and it will be interchangeable.
CSMIC Cant speak on this but wow.
The best combination is helijive with v bar gov together words from mikado.
Kontronik made it right, what more can I ask, I am happy.
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
KONTRONIK, OPTIPOWER, PRC, CANOMOD
jhheli is offline        Reply With Quote Quick reply to this message
Old 08-13-2011, 10:41 PM   #2 (permalink)
new sensor for the v bar even less prone to vibes would be nice if it was like the futaba sensor. hard mount and fly! hope this new sensor isn't to pricey !!!
thanks for sharing!
flyfishsick is offline        Reply With Quote Quick reply to this message
Old 08-13-2011, 11:27 PM   #3 (permalink)
New sensor thats coming isusing same sensor as futaba (futaba not making it, its silicon sensing)
Its not immune though, but better to handle vibes.
http://heli.dacsa.net
Old 08-13-2011, 11:49 PM   #4 (permalink)
Does Kontronik plan to make HeliJives in other sizes as well (100LV PLEASE!)?
ChrisH is offline        Reply With Quote Quick reply to this message
Old 08-14-2011, 07:10 AM   #5 (permalink)
Does it mean this new sensor is for nitro?
What about the cost of the 5.2version? Hope that it will be free for 5.1 upgrade
mingming is offline        Reply With Quote Quick reply to this message
Old 08-14-2011, 07:39 AM   #6 (permalink)
Its free.
Fredrik
Team Scorpion
Fredrik R is offline        Reply With Quote Quick reply to this message
Old 08-14-2011, 07:39 AM   #7 (permalink)
Not just for nitro but both and the upgrade is free to all 5.1 pro users .
Sponsored by :
Old 08-14-2011, 03:13 PM   #8 (permalink)
There goes Futabas one advantage, man that will upset the Cgy boys.
Typical as I just bought a spare Blue sensor.
Trex 700/600/500/450EPro,Ikon,Spirit, BeastX,180cfx, Taranis, Futaba 18SZ, Tricopters,Qav 500.
panzlflyer is offline        Reply With Quote Quick reply to this message
Old 08-14-2011, 04:53 PM   #9 (permalink)
But what is the real reason for sensor less sensitive to vibes? I never had issue (only flying electrics) surely if it affects black or even blueline vbar you have an issue???
helicraze is offline        Reply With Quote Quick reply to this message
Old 08-14-2011, 05:11 PM   #10 (permalink)
Yeah. For me the question is: in a "vibeless" heli, will it fly better?
MSH Prôtos CF FBL Stretch
E-flite HABU 32, Parkzone HABU 2
Ikarus F3A
Multiplex Parkmaster 3D
whisperdancer is offline        Reply With Quote Quick reply to this message
Old 08-14-2011, 05:14 PM   #11 (permalink)
Answer: no
Flightperformance is not changed.
Old 08-14-2011, 05:23 PM   #12 (permalink)
Try getting a 90 size nitro vibration free and let me know when you do.
Old 08-14-2011, 08:28 PM   #13 (permalink)
Answer: no
So how are the 5.1pro users getting the free sensor? Sending something to readyheli and waiting for them to send it to mikado takes 4-6weeks..
AndrewAZ is offline        Reply With Quote Quick reply to this message
Old 08-14-2011, 08:32 PM   #14 (permalink)
The sensor will not be free, the update is what we where referring to as free.
Sponsored by :
Old 08-15-2011, 12:31 AM   #15 (permalink)
Got a TDR on the way in the next couple of weeks. Any estimates on when the updated Heli Jive will be available?
Have laser, will travel.
cbdane is offline        Reply With Quote Quick reply to this message
Old 08-15-2011, 07:56 AM   #16 (permalink)
Answer: no
I know that the old sensors have high resolution.
I guess it all relies on the control loop and software, which Mikado is very good at.
Ikarus F3A
Old 08-15-2011, 08:50 AM   #17 (permalink)
My response from Kontronik regarding HJ80Hv was that there will be one but no time frame as of yet.
Never thought to ask about a 100Lv.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 08-15-2011, 09:24 AM   #18 (permalink)
So there's going to be a software update(5.2) but also a new physical blueline sensor?
Old 08-15-2011, 09:31 AM   #19 (permalink)
The new sensor is on the testing stage right now.
Fredrik
Team Scorpion
Old 08-15-2011, 09:35 AM   #20 (permalink)
Yes.
I don't know exactly when the updated version will be out, but I do know they are working on it now, it can possibly be done faster with them working together, it may happen with the update in 5.2, maybe shortly after.
Sponsored by :
