Outrage RC Outrage RC - and XP Li-Po Factory Support Forum |
02-19-2011, 07:35 PM | #1 (permalink) |
Torq 9188 Radio interference?
I was setting up my BL9188 on Vbar 5.1, I leaned in to move a slider on my laptop and the tail went crazy! Took me a minute to figure out why, whenever my TX Antenna is anywhere close to the servo it goes crazy
Chris D. |
02-19-2011, 07:48 PM | #2 (permalink) |
The Capi
What voltage you running the tail on ? And you are aware it is a narrow pulse servo ?
Spreading capibara awareness since 2006 |
02-19-2011, 08:12 PM | #3 (permalink) |
Straight 2s lipo. I'm using Vbar 5.1 and I set it to the BLS251 option because I think that is the closest choice I have? I posted in the Vbar section asking but have no received a response as of yet .
Chris D. |
02-19-2011, 08:14 PM | #4 (permalink) |
The Capi
Strange, i would look for a loose connection somewhere.
02-20-2011, 07:46 AM | #5 (permalink) |
Can you post a video of this happening?
MSH Protos FBL - Scorpion 880kv, YEP80A, SK720, 9650's/9254 Outrage 550 FBL - Scorpion 4025-1100, ICE 100, Hercules BEC, SK720, 9452's/DS650 Compass 6HV FBL - Stock motor/ESC, SK720, JR 8917HV's, BL 9188 Compass 7HV FBL |
02-21-2011, 11:18 AM | #6 (permalink) |
might just be the Rx is getting swamped from the Tx being too close and showing up as a tail servo issue. Dont really see how a 2.4ghz Tx would effect a tail servo otherwise
02-21-2011, 11:27 AM | #7 (permalink) |
Get it to do it again, and then press the bind button on the TX. If it stops then it's probably as John says. Pushing the button cuts the TX signal output.
02-21-2011, 11:22 PM | #8 (permalink) |
Will give that a try, good idea.
Chris D. |
03-18-2011, 06:38 PM | #9 (permalink) |
Not a good thread topic - i have one waiting to be used in another TDR, so i hope it will be fine.
- TDSF in a box... - TDR #2, Scorpion 4525LE, PowerJive, MKS HBL950/980, Vbar - TDR #1 (stock, sold at 700+ flights), e-Revo, Protos 500, Jeti DS14 |
