Old 09-17-2014, 09:22 PM   #1 (permalink)
Default View 540 Logs
So I see on Skookum web page that the new update allows us to read 540 logs. I bought the activation key but all I can see are the stick inputs and such... No Vibration Logs! What am I missing here? lol.
7HV
HeliJive 120
Quantum 4530
MKS 950/980
SK540
Bananaslug is offline        Reply With Quote Quick reply to this message
Old 09-18-2014, 06:38 AM   #2 (permalink)
Only the 720 has accelerometers and therefore can log vibes. Its also why the 540 does not have self leveling
Tony
Synergy 516, Gaui R-5 Speed (RIP), Cypher Vtol Jet (RIP), Spirit FBL, Hobbywing and Scorpion Tribunus ESC, Xnova motors. The girl in my DX9 tells them all what to do
Xrayted is offline        Reply With Quote Quick reply to this message
Old 09-18-2014, 09:37 AM   #3 (permalink)
What he said. You will see everything except the vibe logs. However, it's still good for tuning cyclics and governor performance, and analyzing problems.
YS Powered Rave ENV Stretch Protos 500, Stretch Mini Protos, 180 Trio
gitbse is offline        Reply With Quote Quick reply to this message
Old 09-18-2014, 10:46 AM   #4 (permalink)
Well that sucks. Only thing I was interested in was vibe logs... I just assumed it meant vibe logs when it said 540 logs. Waste of $35. Should have just bought the new tail hub assembly instead of trying to prove my suspicion to myself.
7HV
HeliJive 120
Quantum 4530
MKS 950/980
SK540
Old 09-18-2014, 03:55 PM   #5 (permalink)
HSC
Same hear !
But it is fine too have chanel readings...if something went baad...
It also helps with governer optimization.
So not total waist of $$$
Regards
A je to ?
HSC is offline        Reply With Quote Quick reply to this message
Old 09-19-2014, 04:13 PM   #6 (permalink)
Don'' sweat it, if $35.00 is all you ever waste flying helis, please send us all a detailed explanation of how you did it
I'm still trying to figure out why my Cyclic gains won't adjust with my 540 and 14SG.
hrefab is offline        Reply With Quote Quick reply to this message
Old 09-19-2014, 06:50 PM   #7 (permalink)
I 2nd that notion.
Old 09-26-2014, 08:01 AM   #8 (permalink)
Will the Dataviewer Pro plot the voltage of the servo rail in the SK-540 Clear?
flyingw is offline        Reply With Quote Quick reply to this message
Old 09-26-2014, 08:23 AM   #9 (permalink)
=] yes....
Old 09-26-2014, 02:45 PM   #10 (permalink)
Ok. I bought it and got the license key. Only thing, I cannot locate the software.
I found a picture of the "Skookum Robotics Data Viewer Pro" on the wiki page. How to get that software and how do you bring it up?
Please advise. Thanks,
Paul
Old 09-26-2014, 02:55 PM   #11 (permalink)
=] try "my docs"
double click SK plot
right click the icon and "send" to desktop short cut is one way!!
Old 09-26-2014, 04:52 PM   #12 (permalink)
You can do what Georgi suggests or you can try re-installing the setup software. The plotting software is included in the setup software installer package. You can download the latest version here:
http://www.skookumrobotics.com/updates/
Make sure that the option to install the data viewer is checked when you run the installer. I think it is selected by default. The installer will also give you an option to install a shortcut on your Windows desktop. The icon looks like the one in the "SK_Plot" window in Georgi's post, above.
SpeedTape is offline        Reply With Quote Quick reply to this message
Old 09-27-2014, 09:55 AM   #13 (permalink)
Georgi and SpeedTape,
Thanks - I found the data viewer on the administrator desktop. Applied the pro license key and the logs look good. Cool stuff.
Whenever I get a new log after a flight it always has the date 9/19/2014 at 12:00pm. Is there some clock I need to set somewhere?
Thank again,
Paul
Old 09-27-2014, 10:10 AM   #14 (permalink)
There is no clock on the FBL unit. Those are Windows file stamps being placed there by your PC.
Tony
Old 09-27-2014, 11:25 AM   #15 (permalink)
=] yes, every time you "send" to the gyro it sends a fresh date-stamp....
Old 09-27-2014, 11:27 AM   #16 (permalink)
Ok, maybe I'm not "sending" to the gyro. How do I do that?
My last flight was this morning 9/27/2014, but I did not see a log with today's date.
Paul
Old 09-27-2014, 11:31 AM   #17 (permalink)
=] Paul, send as in USB send. ie change a setting / change it back....
Old 09-27-2014, 01:43 PM   #18 (permalink)
Georgi,
Just got another log dated 9/19/2014, 12pm that I know is new data. I know it is new because I changed the power source on the servo bus and the new log shows the correct (changed) voltage on the bus. The log also had a new name with the number bumped by one = LOG204. Previous ones were LOG203, LOG202, etc.
1) Do I have to keep the gyro powered on since the last flight to get a log with the current date?
2) If I remove and re-install the entire Skookum Digital Flybar 4.02b program will I be able to re-apply my same Data Viewer Pro license key I use now?
Thanks,
Paul
Old 09-27-2014, 01:55 PM   #19 (permalink)
I just purchased the software key too. Very nice implementation. Now I think I want a 720
Old 09-27-2014, 02:10 PM   #20 (permalink)
=] Paul sorry, I don't pay any attention to the log date, I know what the flights consisted of, and view them as such. the 540 keeps overwriting a small IC chip so you are only as good as your last flights can show.
If you remove the program (why?) or want to use it on another machine, SK will need to get involved, it's a one off thing..
